Ct32hx42 replaced items : ic500 shorted and r857 &858 both open. pix is good except top and bottem about two inches from border is distorted. pix or wording seems to pull horizontally.
  • julius escobedo Mar 14, 2008
    which horizontal i c do you refer to ? ic #
    Guru:
  • 1,894 Answers
Then it must be the horizontal IC that is needed
Posted on Mar 14, 2008
  • dewan nafees ahmed Mar 14, 2008
    just also replace the horizontal IC.
    you will get fixed surely.
    thank you sir
    good luck
SOURCE:
Fujifilm Fine Pix 80 EXA
Salt water may have caused some components to short out.
It would not be worth repairing and it would not be a DIY repair.
Sep 18, 2012 | Fuji Cameras
To widen border on Toshiba lap top
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.If you cannot change the screen resolution then most likely the incorrect video driver has been installed.
Mar 30, 2012 | Computers & Internet
I need i driver for my LW-IC500 web cam
Here's the driver link for the Light Wave LW-IC500: http://www.bioticaindia.com/lw-ic500-internet-cam.html
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
Apr 21, 2011 | FMI Portable Webcam
I need drivers for usb 2.0 camera light wave
Dear i have send two web address for your Compaq AVC00-AA Webcam drivers pleaseclick on this link and direct download.
Thanks.
download driver for lightwave lw-ic500 - Social Search Engine
in: www.zappafly.comwww.zappafly.com/download+driver+for+lightwave+lw-ic500.html
Related text in page: «Use Zapafly to find all your info download driver for lightwave lw-ic500 ... Find Download Driver For Lightwave Lw-ic500 Here. ...» Free lw ic500 driver to download at PTF
in: ptf.comptf.com/lw/lw+ic500+driver/
Related text in page: «Lw ic500 driver software downloads. Lw ic500 driver freeware and shareware. ... lightwave lw ic500 software. driver for v 2.47. driver 2.0. pci rs 232 driver ...»
Feb 18, 2010 | Computers & Internet
Double Vision (Mainly around the edges of the screen)
Look for your Convergence amps and check the solder connections on them....you may only have to resolder the amps...and if they fail in a couple weeks, then replace them...
If you don't beat up the convergence amps for WEEKS operating them with the bad connections, they can survive...
Jan 29, 2009 | Toshiba 50HDX82 50" Rear Projection...
Periphery of screen changes tint
hit crt with open palm in distorted area.if changes broken shadow mask no repair except crt replacement. if not could be magnatized. needs degaussing
Dec 07, 2008 | GE 35GT690 35" TV
Cannot minimise yahoo messenre window
Click middle icon in top right corner until only 1 rectangle shows
Drag the whole page to the left by grabbing the top border and dragging and dropping the page until you can access the right hand border
Drag and drop the right hand border to the position you want.
Do the same with left hand border
Check default by maximiize & restore down
To increase page size Crtl & + ( in stages )
To decrease page size Ctrl & - ( in stages )
To restore default Ctrl & 0 ( zero )
Dec 05, 2008 | Yahoo Messenger
Hitachi ultravision 55 inch
Check to make sure you reconnected the jumpers to connect the board that you removed. Also, check to make sure no resistors are burning. If still no pix, make sure you reconnected multi pin plug by digital convergence unit (DCU). Next, disconnect conv. plugs marked red, green and blue. This should allow power to come up if chip(s) are bad. Next, check pico fuses on board by jumper connectors or in power supply. If these are open look for solder bridges around conv. amps. Also, if any of these are open check all zener diodes beneath heat sinks where you installed conv. amps. Probably 27 v glass zeners shorted if solder bridges were created when changing chips. Good luck, sometimes you just get a bad I.C,Russmann.
Nov 03, 2008 | Hitachi 53UDX10B 53" Rear Projection...
No pix
Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.So far I have fixed four of the same make,and model TV as this,and they all had either one,or two bad capacitors.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Jan 04, 2008 | TruTech PLV1615T 15 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Ekse
