Question about Motorola Mobility RAZR V3
Don't know the pin to set up my bluetooth
I got a new phone and I'm trying to set up my bluetooth device but when I;m trying to pair the devices it ask me for a pin. I dont;'t remeber the pin.
I cant remember my passcode
I can't remember my buetooth device pin number,how can i reset or put a new pin number ??mike,, its a model H12
i have a motorola razr and was givein a blue tooth how do i make them conect
  • 7 more comments
  • skotty Apr 20, 2008
    Ok, so I have a razr V3 phone. I wanted to use my wife's LG HBM-710 bluetooth headset. I turned it on then went into the phone's settings (per the owner's manual), clicked on "Connection", selected "Bluetooth", it says scanning....then says devices found: 0.
    Then a screen says: please make sure the device to which you are connecting is in pairing mode.
    HELP!!!!!!!!!!!!!!!!!!!!!!!
  • jande1 Jun 30, 2008
    i heve a jabra bt250 and i need to reset the pin
  • wsappc Jul 27, 2008
    i cant get the headset to pair with my v3 phone. i held the button down until the light stayed on but the phone won't find it.
  • bluebird311 Aug 10, 2008
    given a used bluetooth , owner does not remember pin need help
  • Anonymous Sep 05, 2008
    pin code for bluetooth h12
  • mcdanielnath Sep 25, 2008
    i can't remember the pin for my bluetooth headset
  • Anonymous Oct 04, 2008
    I want to get a ringtone and put it on my phone, but I don't know what my pin # is? Help!!
  • Bigballerj27 Nov 22, 2008
    i get connection with other phones for bluetooth but when it asks for a pin number i dont remember it
  • Anonymous Jan 06, 2009
    I just got a replaced w385, cant get h681 bluetooth to stay linked. I'll allow me to link it up on set-up. Keeps asking.." Bluetooth off, turn bluetooth on temporarily?"... then i hit 'o k ', then it works. If i turn either of them off, its gotta be set-up all over. Phone then asks for Bluetooth PIN... I dont remember.
Most Motorola bluetooths have a default passcode of 0000 and cannot be changed.
Posted on Aug 15, 2008
    Brigadier General:
  • 7,752 Answers
Try 0000 - this is the default for most bluetooth headsets.
Posted on Mar 21, 2008
I had a Nokia 6085 model and i had to get a replacement phone (which is the same make and model)
but now i cannot get my bluetooth to connect. my bluetooth is a motorola H350, When i get through my steps, and get to search for audio enhancements, it asks for a passcode, I never knew my passcode, as i brought it at a store and the guy set it up there, how do i reset my passcode in order for my BT to work properly. it is reading my device, just don't know the passcode.
Posted on Nov 19, 2008
How do I reset the pin for my bluetooth headset?
Posted on Sep 27, 2008
Be sure the bluetooth is turned on.
Posted on Aug 03, 2008
Whatis the bluetooth pin for samsung c6112
check the bluetooth in settings go into bluetooth .. turn on bluetooth and phone will scan for devices to pair with. The other device will show if it has bluetooth on and set to discoverable.
Under available devices on your mobile touch with finger it will try to pair and say boothtooth pairing request. Confirm passkey is {whatever number it generates} to pair with {whatever device it is pairing with } note what the number is and press ok. At the top of the screen is a note says visable to all nearby bluetooth devices . the box needs to be ticked and other device should have same pass code when it tries to pair. It will ask you to confirm code.
Jan 12, 2018 | Cell Phones
Hello I am trying to install a new headset to my CS70 desk phone. The ruber earpiece on mine broke. How can I pair the new earpiece?.
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone, PC or other device for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your other device to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Good luck from Headsets Direct!
Oct 14, 2010 | Plantronics CS70 Wireless Headset
I am trying to pair my Plantronics Explorer 330 headset to my new phone, an HTC Eris. the phone does not recognize the device. Do you have any ideas?
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
Dec 21, 2009 | Plantronics Explorer 330 Headset
I have a new phone I am trying to pair & have lost the instructions. Have tried 0000 & 1234
I assume you are talking about paring your bluetooth head set with your phone. It would help if you list the make and model for both of your phone and bluetooth device.
But in general, you put your phone in discovery mode to search for new devices, then you can power up your bluetooth device in pairing mode, usually by holding the power button for a long time while powering on the device util it starts flashing. After a few seconds, both devices should find each other. The phone should prompt you if you want to pair with the device found.
Sep 17, 2009 | Cell Phones
I don't know the pin number to my bluetooth HBM-730
Are you trying to pair these two devices? In that case enter any number as your PIN when prompted and enter the exact number in the other device when it asks for. PIN number is asked when you try to pair two or more bluetooth devices. PIN can be any number but make sure you enter the same number in all devices.
I hope it helped.
Feb 10, 2009 | Cell Phones
Connection
Try deleting all paired device from the parrot and your phone, remove battery from you phone to reset it. Then follow below instructions from Parrot.
Pairing Devices: ** From your car kit:
** Select SETTINGS / ADVANCED SETTINGS / PAIR WITH PHONE / OTHER PHONES
* From the phone:
* Select MENU / SETTINGS / BLUETOOTH / MY DEVICES / SEARCH NEW DEVICE
* The phone will search for available devices
* Select CK3100 from the list of available devices and enter PIN code \"1234\"
* Phone and CK3100 are now paired. Wait for auto connection
Feb 04, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Motorola Mobility RAZR V3 Logo
2,711 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
