Question about Samsung SGH-D900 Cellular Phone
D900 limited service?ne solutions
What is wrong when my d900 displays limited service and wont make calls or sms how do you fix it
  • 2 more comments
  • rixdname May 21, 2008
    recieved a text then limited service symbol appeared and will not either accept or recieve calls or texts
  • ajuma Jun 11, 2008
    I do have the same problem, but I changed the sim and it is working fine and am not getting the message now.
  • Anonymous Jun 12, 2008
    what is wrong when my d900 displays limited service and wont make calls or sms how do you fix it
  • Anonymous May 12, 2009
    I had the same problem so I went into Menu-Settings-Network Services-Band Selection. It should then give you the option to select two different types of
    GSM Bands or Quad Band. I found that Quad Band works for me, but the GSM 850/1900 worked as well. Hope this helps!
    Dsnt work... Please assist further
    New Friend:
Samsung d900 limited service solution
Posted on Dec 27, 2013
I had the same problem so I went into Menu-Settings-Network Services-Band Selection. It should then give you the option to select two different types of GSM Bands or Quad Band. I found that Quad Band works for me, but the GSM 850/1900 worked as well. Hope this helps!
Posted on Jun 14, 2008
Limited service
it might be locked on to some network. get it unlocked from a mobile shop
Dec 27, 2013 | Samsung SGH-D900 Cellular Phone
How to unlock sony xperia acro is11s AU by KDDI
You can get the unlock code from service provider and unlock it.
Dec 28, 2012 | Cell Phones
Phone says limited service
Maybe the phone is locked. return it from where you bought it. They should be the to fix it for you.
Dec 08, 2009 | Samsung SGH-D900 Cellular Phone
I recently did a eeprom reset on my Samsung D900
I would say flash the firmware. Do a full flash, it sounds like whatever reset you did caused a problem. If flashing isn't' the culprit, it could be a loose cable or bad part. BUT, if you can make it "go bserk" at the same time, like every time you SMS or something, that will prove that it is not hardware, but is firmware and a flash should do it.
Oct 24, 2009 | Samsung SGH-D900 Cellular Phone
My E65 phone wont send sms but i can make a call and also recieve sms and calls...i wanna solution
The only way to fix this is by calling your service provider. It is a problem with the net work not your phone. You could try just taking the battery out of the phone and starting it back up and see if that fixes the problem otherwise you have to call your service provider. Sorry your having so much trouble!
Mar 23, 2009 | Nokia e65 Cellular Phone
SMS sending error!
if its a new phone / sim then you might need sms / wap settings sent from your service provider to set the sms message centre number in your phone etc.
Alternatively some SP's require you to call them and register a payg phone to enable full functionality, call your customer service line and explain, they will fix it right away.
Jul 29, 2008 | Samsung SGH-D900 Cellular Phone
Samsung d900 moblie
Hi there
You cannot view or send images because your MMS isn't set up. You must call your service provider's customer care and ask them to send you your MMS settings, they will then send you your settings via SMS, save this SMS and then the phone should ask you if you would like to change the current proxy, choose "accept" or "yes".
Please remember to rate this solution as15511b8.pngif it helps you.
Kind regards
Dustin Ellse
Jul 02, 2008 | Samsung SGH-D900 Cellular Phone
'Limited Service' displays on Samsung SGH-D900 phone on Orange network and I can't use it except for SOS calls.
GUEST - you internal antenna might need to be service or replaced.
well you may not have it on the correct band so you should check that one.....or hard reset it *2767*3855#
Apr 03, 2008 | Samsung SGH-D900 Cellular Phone
Samsung e250 limited network
phone has the virus get it checked with some one professional bye
Oct 01, 2007 | Samsung SGH-D900 Cellular Phone
Limited service continuously displayed
GO TO NETWORK SETTING N SET YOUR BANDWIDTH
Samsung SGH-D900 Cellular Phone Logo
618 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
