Question about Dryers
Dryer challenge Have a two year old Whirlpool front load dryer LEN 2000 PWO that the drum has stopped rotating (still heating). Unsure how to take front off to check if belt broke etc. Thanks, Darl dlbruner@nnu.edu
  • Anonymous Jun 22, 2008
    unscrew two screw that i though was holding two bracket in place but it still didn't come off
  • Anonymous Mar 25, 2014
    whirlpool front load
  • 26 Answers
Sorry recheck that model # doesn't come up on the parts look up. I go to the parts lookup to see which dryer syle you have . Some the top comes up some have a lower front pant that removes.
Posted on Mar 15, 2008
    Problem Solver:
  • 16 Answers
Actually most are opened from the top. as accessed as needed from back, depending on your model. a simple flat screw driver will help you pry the top open. it will lift up in most cases.
first to ensure it most probable the belt. turn on the unit (if you feel safe, keep in mind this unit may begin heat cycle with burners kicking on) listen at the back of the unit and you will hear the motor ever so quietly running (cause it dosent have a load on it). try this with the heat off. this will help narrow down the possible belt issue.
gl and email me w questions
K
Take off top to see if belt is ok
Whirlpool front load dryer will not start
Does your dryer have a reset switch on the back, usually a small red button, if it does press this and ten test dryer starts again.
Dec 21, 2012 | Whirlpool Dryers
Samsung dryer DV4015J turns on and motor sounds like its working but the drum does NOT turn so clothes do not dry, they just sit in dryer container?
If this is the older type, then the dryer drum is rotated by a thin loop belt that goes around the drum and then a pulley on the motor. I had to replace my 20 year old dryer belt on a Whirlpool a couple years ago. The front comes off and the belt slips over the drum. The front of the Whirlpool is held on by friction clips that have to be pried off with a flat blade. I suspect that you can do the same. look on the internet for a diagram of your dryer or you may have one in the manual that came with the machine.
Sep 19, 2010 | Samsung Dryers
Whirlpool duet electronic gas dryer noy heating up
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Jul 17, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool Gas Dryer Model #LGR7648KQ0 has no heat - I cleaned out the vent (it was pretty well clogged!) and then replaced the Fixed highlimit thermostat, the thermal fuse and the dryer cycling thermostat...
The problem is the dryer coils are failing. They tend to fail as they heat up. There is a video at http://appliancehelponline.com/gdryertroublevideo.html this will walk you thru checking them. They are inexpensive and easy to replace.
May 26, 2010 | Whirlpool Dryers
DRUM IS NOT ROTATING, BLOWER IS WORKING AND IS PRODUCING HEAT could i have blown a belt?
Try this first:
Unplug the dryer, reach inside and try to rotate the drum 1/4-1/2 turn, sometimes motors get dead zones in them and this will rotate it out of the zone if that is your problem.
If that did not work then chances are that you have a broken belt.
If you have a front loading machine:
If you remove the front of the dryer, it will expose the drum and the belt, if you remove the drum it will expose the drum rollers, motor, and idler pulley.
I hope this helps
Oct 04, 2009 | Whirlpool Dryers
My whirlpool dryer heat up. But does not spin.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Check for belt on drum half way back on the drum running from left to right. If belt is missing or broken replace with part number 341241 later in this process.
Looking down inside dryer on left and right see a 5/16" hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Rotate front panel to right to get it out of the way watching to ensure wiring is not damaged.
Place new belt over drum groove side down if old one was broken. Check white idler pulley for free rotation before installing in holes of floor under motor pulley. Replace with part number 691366 if rotation of pulley is not free or if it appears worn. Loop belt with ribs inward and pass through the open space in the idler arm below pulley then pass loop over motor pulley rib side down. The configuration at the motor should now look like the Whirlpool model in the image below:
Belt and pulley configuration
Grasp front edge of dryer drum and rotate counterclockwise slowly to align idler and motor pulley and to remove any twists in the belt.
Reverse disassembly process to re-assemble.
Sep 06, 2009 | Whirlpool Dryers
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Kirkland Dryer drum does not rotate, but heat comes out
check capacitor next motor its a white long got three clips coming off it change good luck
shaun
Jan 16, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Dryer Motor Removal
stand that baby up!!! acess is from front, try removeig 2 screws from under lint filter and then pop top with screw driver lean top back.. youll see the tub and belt(if not broken right there),no belt??? order a 341241 whirlpool dryer belt. 2 5/16screws on either side of iside facade remoivefront caver, disconnect door switch and remove front panel. belt slips over drum , you need to reset tension pulley and wrap around motor shaft. .
Feb 26, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
209 people viewed this question
Top Dryers Experts
