No firewire 800 or 400 functions in Leopard for SIIG FireWire 800 + Hi-Speed USB Combo PCI Adapter
SIIG FireWire 800 Hi-Speed USB Combo PCI Adapter... I just installed this card in my G4 Mirror Doors Dual 1.25 processors with LEOPARD OS. The only function that works is the usb 2.0...neither firewire 800 or 400 work.
    Sergeant:
    Champion:
  • 326 Answers
Unistall and reinstall through control panel. use the drivers it came with. Make sure the drivers are for ur OS. If not, check with manufacturer for proper drivers.
Posted on Mar 15, 2008
SOURCE:
Firewire port usff 7010
If you're asking if a Dell OptiPlex 7010 USFF will support Firewire the answer is No...Unless you purchase and install a Firewire card
The OptiPlex 7010 USFF has the following external connections:
  • Front Panel: one microphone connector and one headphone connector
  • Back Panel: one line-out connector and one line-in/microphone connector
  • Network Adapter: one RJ45 connector
  • Serial: one 9-pin connector; 16550 C compatible
  • USB 3.0: Back Panel - 2
  • Video: 15-pin VGA connector
  • 20-pin DisplayPort connectors - 2
I don't recommend any USB to Firewire convertors but if you can find a Firewire Convertor PCI Express Card you can try installing it but remember the USFF has only one Mini PCI Express 52-pin connector, I've highlighted a possible product. It allows for Firewire 800 speeds. The included optional internal Molex power connection is only required if your Firewire device doesn't have its own power adapter
May 07, 2014 | Dell Optiplex 7010 500gb Usff Ultra Small...
Need Hi-speed usb host controller
. If you have an empty PCI bus slot on the PC motherboard, you an install a PCI card which provides you 2 or 4 USB2.0 ports which are available at around $10. There are some combo cards which provide both USB and Firewire (1394 ports).
Oct 06, 2008 | Toshiba Televison & Video
Firewire usff 7010
May 07, 2014 | Dell KIT OPTI 7010 USFF I5-3470 3.2G 2GB...
SIIG (JU-P50212) USB 2.0 Network Adapter
If you did a fresh install of Windows 7, make sure you install Windows 7 SP1.
A lot of Windows 7 drivers were not included in the original release.
http://windows.microsoft.com/installwindows7sp1
The manufacturer does not list a specific driver for this card( although it does list it as being Windows 7 compatable) so likely you will find it by updating Windows 7.
http://www.siig.com/hi-speed-usb-5-port-pci.html
Jan 05, 2012 | SIIG (JU-P50212) USB 2.0 Network Adapter
1394 Header pin-out
http://ritmotech.com.au/onlineshop/product_info.php?cPath=21_25&products_id=57&osCsid=aeefcbb79e7dab18e3439d5d6c64cb0f
Ritmo PCI to USB + 1394 (CC-C15)
PPA USB2.0 + 1394 Combo PCI Card Model 1509
http://www.ppa-usa.com/products/usb/usb_pci/1578.htm
click on get pinouts for pdf file of card
Pinouts:
USB board is slikscreened with numbers but for reference
pin 1 ground is at top edge of board
and pin 5 plus 5v is towards gold connector edge
1. case Gnd (thick black)
2. D- (green)
3. D+ (white)
4. no connection
5. +5v (red)
Firewire: (8 pin header on board)
this board uses the 4pin firewire connection standard
NOT THE 6/9 PIN!!!! you only need to connect 4 pins
and if you have a thick case ground cable you can use it
pin 7 is towards bracket towards top edge of card
pin 8 is towards bracked towards gold edge connector
card header
5 TPB- Orange
6 TPB+ Blue
7 TPA- Red
8 TPB+ Green
3 Case Gnd Thick Black (not thin black) if you have one
(white 30vdc) and (thin black, signal Gnd)
wires are not used
pins 1 and 2 are also unused for firewire connections
please note that this card has +12v on pin 2 instead of the
30v dc that a normal firewire 6 pin connection has
Sep 01, 2008 | Televison & Video
Well i don't have a fire wire connection
To my knowledge there is no simple adapter that would interface Firewire to USB. Though both are high-speed bus, there is significant difference between the technologies involved that they can't be joined/integrated nor is it possible to connect a USB device to a Firewire port either directly or vice-versa. Most if not all on the market are a dual/combination Firewire/USB hub but not an adapter.
Alternately:
1. If your computer is a desktop, there are PCI cards that plugs in to one of your PCI slots whose inputs are Firewire based. Here is an example; or
2. If your computer is a laptop, there are PCMCIA cards with Firewire ports. Here is an example .
Pls be reminded that there are 4-pin & 6-pin FireWire DV Cable.
Hope this be of some help/idea. Pls post back how things turned out or should you be in need of additional information.
Good luck and kind regards.
Nov 19, 2007 | Canon ZR60 Mini DV Digital Camcorder
USB problem
i think u must upgrade the USB driver on ur pc go to this link and download the driver and save it in desktop and double click on it and install it
http://usb-1394-firewire.free-driver-download.com/SIIG/31991/SIIG-USB-2.0-Controller-Driver-v0.216-Windows-98SE-ME-2000-XP.html
rate me solved if its help thx
Oct 30, 2007 | 2wire 1000-200004-000 Network Adapter
Installing a firewire pci Card onto my HP Compaq dc5000 Small Form Factor PC
Hi, Actually there are various types of customized firewire connections for your computer. Here is a link to view some products that might work with your computer. http://www.firewire-1394.com/firewire-usb-combo.htm Also, there are different sizes of PCI cards available. You have to shop around to find an apropriate size.
May 04, 2007 | HP Compaq dc5000 PC Desktop
Open Questions:
\Q;- KYOCERA customer service phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This KYOCERA USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 KYOCERA USA customers tried our tools and information and gave us feedback after they called. The reason customers call [+I8OO-8O3-1069] is to reach the KYOCERA USA customer service department for problems like Where to buy, Complaint, customer service, Repairs, Returns. As far as we can tell, KYOCERA USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. KYOCERA USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact KYOCERA USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling KYOCERA USA Calling KYOCERA USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our service call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from KYOCERA USA customer service can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with KYOCERA USA's customer service department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare KYOCERA USA's phone numbers against each other. Contacting KYOCERA USA in General While [+I8OO-8O3-1O69] is KYOCERA USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that[+ I8OO-8O3-1O69] is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact service for you to look at as well. One thing to keep in mind as you try to reach KYOCERA USA help by calling them, is that other customers give their customer service at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact KYOCERA USA.
Oct 18, 2019 | Kyocera Computers & Internet
\Q;- RICOH customer service phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This RICOH USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 RICOH USA customers tried our tools and information and gave us feedback after they called. The reason customers call [+I8OO-8O3-1069] is to reach the RICOH USA customer service department for problems like Where to buy, Complaint, customer service, Repairs, Returns. As far as we can tell, RICOH USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. RICOH USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact RICOH USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling RICOH USA Calling RICOH USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our service call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from RICOH USA customer service can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with RICOH USA's customer service department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare RICOH USA's phone numbers against each other. Contacting RICOH USA in General While [+I8OO-8O3-1O69] is RICOH USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that[+ I8OO-8O3-1O69] is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact service for you to look at as well. One thing to keep in mind as you try to reach RICOH USA help by calling them, is that other customers give their customer service at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact RICOH USA.
Oct 18, 2019 | Ricoh Computers & Internet
\Q;- KODAK customer service phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This KODAK USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 KODAK USA customers tried our tools and information and gave us feedback after they called. The reason customers call [+I8OO-8O3-1069] is to reach the KODAK USA customer service department for problems like Where to buy, Complaint, customer service, Repairs, Returns. As far as we can tell, KODAK USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. KODAK USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact KODAK USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling KODAK USA Calling KODAK USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our service call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from KODAK USA customer service can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with KODAK USA's customer service department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare KODAK USA's phone numbers against each other. Contacting KODAK USA in General While [+I8OO-8O3-1O69] is KODAK USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that[+ I8OO-8O3-1O69] is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact service for you to look at as well. One thing to keep in mind as you try to reach KODAK USA help by calling them, is that other customers give their customer service at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact KODAK USA.
Oct 18, 2019 | Kodak Computers & Internet
Computers & Internet Logo
281 people viewed this question
Ekse
Alun Cox
