Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Brushes won't spin anymore
Hi, the brushes on my steamvac have stopped rotating. I found a spring on the floor after they stopped spinning. I can see inside that there is a sping that attaches to the switch to turn the brushes on and off, but the actuator arm doesn't seem to be moving. Can you tell me where this other sping goes? I can't figure it out. Thanks!
  • 5 more comments
  • dgshelton Mar 14, 2008
    I don't know why I need to replace the switch. Can someone please just tell me where this other spring goes? Thanks again!
    Thanks, for trying to help.
    I can't see where any part of the switch is gone. Isn't it possible that the sping just popped off and needs to go back on? Does anyone that actually fixes these machines know where this spring would go?
    The model is F9425-400.
    I have cleaned the filter and checked the brushes already. The brushes are working fine, but I believe this spring that has come off has something to do with the brushes not working, since I found it on the floor right after the brushes stopped working. I'm just not sure where it goes.
    The spring that activates the switch is still attached and is working as far as I can tell. It moves when the switch is moved, but there is another spring, that looks just like the one attached to the lever for the switch, that I found on the floor right after the brushes stopped working. I can't figure out where to attach that one.
    I'm sorry, the model is F7430-900.
    President:
  • 1,673 Answers
There is a spring that goes on an arm, #32 in the picture. It actuates the turbine so the brushes will turn when the handle is tilted back, and stopped when upright. This might be where that spring goes. You may have to take the top cover off to put in on. After you get it on, and the brushes still don't turn, look up in the square hole where the shaft on the brush block goes into, turn the unit on and see if it is turning, if not then the turbine either needs to be taken apart and cleaned or replaced. The turbine is what drives the brushes.
Posted on Mar 14, 2008
  • 2,336 Answers
What is the model number of you steamvac?
  • Jaime Hernandez Mar 14, 2008
    Check this site for an user manual. It might help you to troubleshoot your steamvac.
    Good Luck.
    Brigadier General:
  • 3,614 Answers
Have you tried looking inside the vacuum, it's possible it only there..
    Master:
  • 377 Answers
Look in to the buttom of the handle, it was attached at the end of the handle, your vacum switch is like a lever, so when you push and pull the sping attached trigger the switch..
See if the hook attaching the spring is not broken.
Thanks
  • 50 Answers
I would venture to guess that part of the actual switch casing has also come off. I think your most cost - and time - effective method of repair is to head over to Radio Shack and find yourself a replacement switch in its entirety. They are less than $5 and if the switch has come apart once, it will most likely again.
  • Michael Ansnes
    Michael Ansnes Mar 14, 2008
    I'm sorry appparently I spoke too soon. The brushes on your model appear to be suction driven. There is a filter screen behind the brush assembly on the left side as you look at the vacuum when you are operating it that must be cleaned in order to provide the power to move the brushes. Unplug the device, flip it up on its back, remove the screen and clean it out.
    Guru:
  • 1,894 Answers
Please replce the switch
  • 2 more comments
  • dewan nafees ahmed Mar 14, 2008
    the other is must be for the support of main one.
    you have it fixed by fixing the switch
    thank you
    good luck
    oops sorry. i tought the switch is nott working.
    sorry./
    sorry for the inconvinience caused
    other experts will assist you soon
    again the same solution? well dont worry sir you will get a very good solution very sooon.
Hoover steamvac 50 stopped spinning
Hi! The brushes can stop spinning if something is obstructing them such as carpet fibers, hair, dirt or debris. Remove the brushes from the cleaner by grasping the plastic outer housing and pulling firmly away from the cleaner. Remove any debris and run it under running water to clean. On the back of the brush-block assembly there's a plastic drive pin that rotates all the brushes when turned. Turn the drive pin and ensure that all brushes are making a complete 360° degree turn. If the brushes are getting stuck or if a brush falls out then the brush-block will need to be replaced. Follow the link here to order a replacement brush-block for the Steamvac Search Results. Below is a list of models this brush will fit.
F5912-900, F5914-900F5915-100, F5915-900, F5915-905, F5917-900, F5918-900, FH50041, FH50042, FH50043, FH50044, FH50045, FH50046, FH50047, FH50048CA
Hope this helps!
Jun 20, 2014 | Hoover Vacuums
Spin brushes do not turn
Hi There,
I\'ve written an extensive repair solution on how to diagnosis Hoover SteamVac\'s when the brushes stop spinning. A lot of the times the brushes just need to be cleaned, or it could also be the turbine assembly inside.
Here\'s a link to the diagnosing:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
And if you find out that you need to replace the turbine, here\'s a link that shows you step by step how to replace the turbine:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
Hopefully these were helpful to you. Please be so kind and rate the repair helpful, or leave feedback for me if you found this helpful. This is really appreciated by the Fixya community to do if this was able to fix your problem, and ensures that Fixya experts continue to post free repair solutions rather then just answering the premium questions.
Thanks so much,
Sep 16, 2013 | Hoover SteamVac F5914-900 SpinScrub...
Brushes don't rotate during floor cleaning
Check that no strings or other debris is clogging the brush wheels. If it isnt that check that the belt isnt broken connecting the brush to the motor. If that is ok, most likely the motor is blown and not turning the belt.
Sep 20, 2012 | Hoover F7425-900 SteamVac V2 Widepath...
SteamVac F5914-900 SpinScrub Upright Vacuum: Is it ok to use the hoover steamvac on tile floors...
Yes, your Steam VAc will work on tile floors. You'll want to remove the rotating brushes and install the Bare Floor Tool attachment - Hoover part number 48417003
May 16, 2010 | Hoover SteamVac F5914-900 SpinScrub...
5 BRUSHES DO NOT ROTATE WHEN IN CONTACT WITH CARPET
HI There,
When the brushes on a Hoover SteamVac stop spinning, it can be caused by several things. The most frequent problem is that there is debris in the brushes such as pet hair, or lint, that prevents the brushes from spinning. Usually if you remove the brushes and clean them thoroughly, this will fix the problem. This sounds to me like what is the problem on your machine, as you make it seem as if the brushes spin, but only stop spinnning when you put them down on the carpeting.
The brushes on your Hoover are driven by a turbine brush gear assembly, not a belt. Sometimes this part can go bad, but usually when it does, the brushes won't spin at all, even when they are not on carpeting.
Anyways, here a helpful guide that I've done that shows you step by step how you can diagnosis the problem with your brushes:
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine.
I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
Now look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic has not broken.
If the pole has broken, you will simply need to replace the brush block. If the pole is not damaged, the next thing to try is to turn the machine on while you have the brushes out. Look inside the machine, where the pole goes into the turbine (also important, make sure the switch for the brushes is turned to "Rotating Brush Speed Hi), this female receptacle should spin when the machine is turned on. It is important the try this when the foot pedal is released, and the handle down, and not in the upright position, as there is an internal switch that shuts the brushes off when the machine is in the upright position.
If you notice that the female receptacle where the brush pole is inserted is spinning, then your turbine is fine. If this part is not spinning, then most likely you will need to replace your turbine.
If you find that your turbine needs to be replaced, I have written a step by step guide that shows you each step on how to replace your brush turbine gear. Here's a link to that repair if you need to do it:
Hope this helped you, please be sure to rate my repair or leave me feedback if you found this helpful, thanks so much!
Chris Jones
GoVacuum.com
May 01, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Brushes Stopped Working Again, What causes this to happen?
There are several things that can cause the brushes to stop spinning on a Hoover SteamVac. Usually when we see this problem come in, the brushes are usually just stuck to do carpet fibers, or pet hairs that get stuck inside of the brush block. A very easy way to clean these brushes is to take them out of the SteamVac (see the link below that is a full diagnosis of brushes not spinning on a Hoover SteamVac), and use a garden hose that has a spray nozzle on the end, and just spray each and every brush. If you start at the top of each brush, and spray water around the entire brush, each brush should spin pretty quickly from just the power of the water hose.
A lot of the times it's just stuff that got caught inside the brush block that stops them from spinning, I would say 7 out of 10 times this will fix the problem.
It also could be that the brush block is broken, or even the turbine inside of the SteamVac that drivers the brushes could be broken as well.
Here's a link to a Fixya repair solution that I did which will help you diagnosis what is exactly causing the brushes to not spin. If you examine the pole on the block, as well as the square shaped female receptacle, and that receptacle is spinning, then your brushes are just clogged up with debris.
If you need to purchase a new brush block, and you have the model that you listed this repair under, Hoover F7220900, here's a direct link to the brush block on our site:
Hoover SteamVac Brush Block, Part # 48437029.
Here's the diagnosis of the brushes:
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture I have circled one of the clips in red) Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 70% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
One you have the brushes out of the machine, the first thing you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic has not broken.
I hope this helps you with your problem. If not, please feel free to request a repair clarification and I'd be happy to walk you through the diagnosing. I also can provide you with a blown up parts schematic to your machine, please just get the model number off the back of the machine and provide, and provide me with the full model number. I would be happy to provide any technical support you need, just request a clarification on the repair.
Chris Jones
Apr 07, 2010 | Hoover F7220900 SteamVac V2 Upright Vacuum
MY WIFE BOUGHT THIS FOR ME FOR FATHERS DAY GIFT ABOUT ALMOST 2 YEARS NOW OR SO,BUT I HAVE THIS PROBLEM THAT THE BRUSH DOS'NT SPIN ANYMORE EVERYTIME I PUT THE SWITCH ON FOR BRUSH ON,THE HOSES BRUSH SPIN IS...
This unit uses a turbine assy to turn the brushes. The brushes could have something jamming them. Remove the brush unit, it is held on 2 spring hooks 1 on each side. The brush unit is driven thru a 1/4" square post, only one brush is driven and it drives the next then it drives the next etc. If something is jammed in these gears it will stop the entire brush assy. The turbine assy could be bad, but I would check the brush assy first.
Nov 10, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover SteamVac SpinScrub. The brushes
If the speed control switch on the hood is in the On position, it would appear the drive mechanism for the brushes is not spinning internally. The drive mechanism could easily be replaced by a technician.
Oct 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes wont rotate
the belt has streached go to walmart and get a new one.
Aug 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes won't spin anymore.
I left you with a solution and picture diagram in the premium solutions, did you get it?
Mar 14, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
69 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
