Question about NorStar T7316E Corded Phone
Time Change I can't change the time on the display. I tried feature **Time but when asked for password it doesn't allow me to put in a password
  • 8 more comments
  • dluciano Mar 17, 2008
    Thanks that worked
    Thanks that worked
    Thanks that worked
  • ofcbill Mar 18, 2008
    I have the same problem I have a Nortel T3716E and the user card does not address changing the time
  • LaurenP Mar 19, 2008
    I am having the same problem but after i enter feature ** TIME it asks for my user id and I don't know what to enter (I tried my extension) then when I hit ok it asks for my password (I tried 23646) then I hit ok and it says denied in admin.
  • speedirn Mar 31, 2008
    I am having problems changing the times on our phones since we had a power outage last week and the time change.
    Thanks
  • jelissa Apr 07, 2008
    i dont know haow to change the time. can you please tell me how?
  • lramos Apr 14, 2008
    I do not know how to change the time on my phone?
  • Anonymous Mar 09, 2009
    I cant change the time and date on my telephone and dont have a programming template
  • SAMANTHAH399 Mar 10, 2009
    I PUT IN THE **TIME BUT THEN IT SAYS RELEASE CALLS AND WONT LET ME CONTINUE
I have the same problem...and it works for me....thanks a lot
Posted on Apr 06, 2008
Have you tried using the password:
23646
Posted on Mar 17, 2008
SOURCE:
Changing time on my phone
Feature **8463 should ask for a password **266344 this should allow you to change the time. Note the time is the same on all phones in the system not just yours.
Nov 11, 2013 | NorStar Lands Phones
I received a reply to my original question: "How
When you enter in the password the screen won't display any input. When the correct password is entered then the screen will change to terminals&sets. If entering 266344 at the password prompt doesn't change the screen, then try 23646 as an alternate password.
Oct 29, 2010 | NorStar T7316E Corded Phone
Trying to set the time on the phone but i dont know the password
Try feature **8463 (time) or feature **266344 (config). Either way, changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 8 4 6 3" or "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Aug 16, 2010 | Nortel T7316E 2-Line Corded Phone
How do I change the time display on Norstar Startalk 180 - can't find anything in manual relating to this?
the startalk takes does not store the time, it takes the time and date from the phone system. to change the time on the phone system try feature **TIME (8463) password CONFIG (266344) from a phone with the 3 soft buttons under the display it does depend on the model and software level as to whether this will work and also presuming nobody has changed the default password
May 19, 2010 | NorStar Startalk Flash 2 Phone
How do i put a phone lock password on my samsung memoir
The Security feature enables you to restrict the use of your phone by others and to restrict the types of calls.
Various codes and passwords are used to protect the features of your phone.
1. From Idle mode, touch Menu ➔ Settings ➔ Phone settings.
2. Touch Security.
Lock Phone
When the Lock Phone feature is enabled, the phone is locked and you must enter the 4- to 8-digit phone password
each time the phone is switched on.
To change the phone password, refer to the next section.
Once you enter the correct password, you can use the phone until you switch it off.
1. Touch On or Off from the Lock phone field.
Change Phone Password
The Change password feature allows you to change your current phone password to a new one. You must enter the
current password before you can specify a new one.
Once you have entered a new password, you are asked to confirm it by entering it again.
1. Touch the Change phone password field.
2. Enter the current password and touch Confirm..
3. Enter a new password in the New password field and touch Confirm..
4. Enter the new password again and touch Confirm.
The password changed confirmation displays.
Note: If you change your password, be sure to write it down and keep it in a safe place. If you forget your password, your phone requires
service to have it unlocked.
Nov 12, 2009 | Samsung Memoir SGH-T929 Cell Phone
The time is off one hour how do I fix it...Nortel
Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 2 3 6 4 6 which also is Feature * * A D M I N.
If asked for a password enter the same 2 3 6 4 6.
If that doesn't work you may have the newer Compact ICS or the Modular 0x32 control unit which will be Feature * * 8 4 6 3 which is T I M E. Password is 2 2 7 4 2 which is B A S I C or A D M I N which is 2 3 6 4 6.
When in programming just press the next button(lower right arrow) until you see what you want to change. Then press show ( top right arrow) ,then change if you want to change it. If you pass it, press back (lower left arrow)
Example: To change the Time & Date Press next until you see Time & Date. Then show Then Chng Then change again, change it if you need to, Then next again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press next until you come to the Hour. Then Change it. Then press release RLs when your done.
Oct 28, 2009 | Nortel T7316E 2-Line Corded Phone
How do i set the time?
  • Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 2 3 6 4 6 which also is Feature * * A D M I N.
    When in programming2.gif just press the next button(lower right arrow) until you see what you want to change. Then press show ( top right arrow) ,then change if you want to change it. If you pass it, just press back (lower left)
    Example: To change the Time & Date Press next until you see Time & Date. Then show Then change Then change again, change it if you need to, Then next again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press next until you come to the Hour. Then Change it. Then press release RLs when your done.
on older systems like the 616 or 8x24, when you enter in the login and password the screen will display "A configuration", press next til you see "B general admin" press the show key the display should say "1 speed dial", press the next key til you see "3 time and date"press your show key and follow the earlier directions
Oct 12, 2009 | NorStar T7316E Corded Phone
How do you set the time and date in the display?
Aug 31, 2009 | NorStar Meridian M7310 Phone
Re-set date and time on display
Have you tried:
Feature **23646 password 23646 (if you phone admin hasn't changed this) and then select set day& time then change there
Feb 23, 2009 | NorStar M7208 Corded Phone
Changing Time and Date
i had this problem a while ago, you have to set the time from the main phone
Press FEATURE **8463 – Display shows PASSWORD:
Then type in 23646 (Note this number will not show on display)
The display will show hours.
Press CHANGE (or NEXT if you do not need to change the hour).
Enter the hour (00 to 23). If number is less than 13, the display shows AM.
Press CHANGE to select PM.
Press NEXT. The display shows minutes.
Press CHANGE (or NEXT if you do not need to change the minutes).
Enter the minutes (00 to 59).
Press NEXT. The display shows year.
Press CHANGE (or NEXT if you do not need to change the year).
Enter the last two digits of current year.
Press NEXT. The display shows month.
Press CHANGE (or NEXT if you do not need to change the month).
Enter the month (01 to 12).
Press NEXT. The display shows day.
Press CHANGE.
Enter the day of the month (10 to 31)
Press RLS (release) to exit.
Apr 16, 2008 | NorStar M7310 Corded Phone
NorStar T7316E Corded Phone Logo
222 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
