Question about Cuisinart DLC-8S Pro Custom Food Processor
Food Processor I was given a cuisinart food processor (prep 11 plus) without a manual and I have no idea how to get the lid on correctly, so machine will work! Thanks for assistance.
  • 667 Answers
Here is the link for your manual. Enjoy! http://www.cuisinart.com/share/man/404_man.pdf
Posted on Mar 15, 2008
Need user manual
Google DLC-2 Mini Prep Plus Food Processor manual and you get https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=DLC-2+Mini+Prep+Plus+Food+Processor+manual
May 03, 2016 | Cuisinart DLC-2 Mini Prep Plus Food...
Need instruction manual for Cuisinart Custom Prep 11
Try this link:
Food Processors Product Manuals Cuisinart com
And look for the one that generally matches the era (design) of your machine, and then the bowl size.
All the best to you!
May 12, 2014 | Cuisinart DLC-10S Pro Classic Food...
Can't get cuisenart pro 11 to start
I am assuming you have a DLC-8S Pro Custom 11, and not another Cuisinart food processor.
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with hollow feed tube facing the back of the food processor.
Put pusher sleeve into lid's feed tube, with sliding lock switch facing the front of the food processor.
You should now be good to go.
Apr 07, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
None of the buttons work on my Power Prep Pulse 11-CUP
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Your processor should now turn on.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Need manual for Cuisinart Prep 11 Plus
You can get the manual here at this link.
http://www.cuisinart.com/manuals/index.php?item_id=53
Good Luck and Please Rate FixYa!
Dec 25, 2008 | Cuisinart Food Processors
Lid stuck on bowl of my Cuisinart Mini Prep Plus.
Generally they twist off, but on the DLC-2, if the lid won't come off, a replacement bowl and lid is around $18.00
Dec 24, 2008 | Cuisinart DLC-2 Mini Prep Plus Food...
Cuisinart prep 11 Plus won't run.
Remove the work bowl completely and separate the work bowl, lid and pusher sleeve. Plug the base into the wall outlet and press the on switch. Use a pen to depress the dark grey or black button on top of the base of the processor. If you don't hear a sound, then call Cuisinart and get it repaired. If you do hear a sound:
1. Put the work bowl on first, making sure the handle is facing front
2. Put the lid on, making sure the hollow feed tube is facing the back of the food processor
3. Put the pusher sleeve in, making sure the sliding lock switch faces toward the front of the processor
Turn the machine on - it should now be working
-Tha Mp3 Doctor
Cuisinart Prep 11 Plus Food Processor - Help!
Not sure if you found the solution by now but we recently had a similar issue. Make sure the bowl is put on such that the handle is facing the front of the processor. There is a little black button that gets depressed when the lid gets put on. We had to get the thing to work one night and spent hours trying to get the processor on and then trying to get a blender to work before finding the problem.
Hope this helps.
Sep 26, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-8S Pro Custom Food Processor Logo
280 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
