Sharp AR-201 network printer / copier H4 Error code need to self fix or a work a round
  • terry767 Mar 14, 2008
    as in power down / unplug? yes I did no change
    Guru:
  • 1,894 Answers
Have you reset the printer?
Posted on Mar 14, 2008
  • dewan nafees ahmed Mar 14, 2008
    Blown lamp. Take the fuser out and you will undoubtalbly see a failed lamp. Very common on these machines.
    Sue O
SOURCE:
5518 advanced clear
check fusing unit first and then reset error code.
Sep 19, 2013 | Sharp AR 201 Copier
SHARP AR 201 - ERROR CODE H4
# * C * den start batan the copier will re-start
Oct 07, 2010 | Sharp AR 201 Copier
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-123E, H4 error code, printer not ready
it doesn`t need to change board. code 14 clears.
May 04, 2010 | Sharp AR-M205 Copier
Display panel h4 code any clues?
This error is displayed when the Fixing heater has not reached normal operating temperature after a specified time.
It is usually a blown heater element.
You will need a technician to repair this.
May 01, 2010 | Sharp AR-235 Copier
I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Jun 09, 2009 | Sharp Office Equipment & Supplies
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error h4
it is on you fusing unit of your copier, check the fuse maybe it is open already and need for replacement... H4 means that your heater lamp is not functioning
franklin
Jan 07, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Mar 17, 2008 | Sharp AR C250A Color Copier
Open Questions:
AVAST Technical Support Phone # I:888-67O-O271 Number This AVAST USA phone number is ranked #2 out of 2 because 7,728 AVAST USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:888:,:67OO27I is to reach the AVAST USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, AVAST USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AVAST USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about ************ and ways to call or contact AVAST USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AVAST USA Calling AVAST USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AVAST USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AVAST USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AVAST USA's phone numbers against each other. Contacting AVAST USA in General While ************ is AVAST USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that ************ is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AVAST USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AVAST USA.
Oct 16, 2019 | Best Computers & Internet
CANON PRINTER Technical Support Phone # I:888-67O-O271 Number This CANON PRINTER USA phone number is ranked #2 out of 2 because 7,728 CANON PRINTER USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:888:,:67OO27I is to reach the CANON PRINTER USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, CANON PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. CANON PRINTER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about ************ and ways to call or contact CANON PRINTER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling CANON PRINTER USA Calling CANON PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from CANON PRINTER USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with CANON PRINTER USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare CANON PRINTER USA's phone numbers against each other. Contacting CANON PRINTER USA in General While ************ is CANON PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that ************ is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach CANON PRINTER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact CANON PRINTER USA.
Oct 16, 2019 | Canon Computers & Internet
EPSON PRINTER Technical Support Phone # I:888-67O-O271 Number This EPSON PRINTER USA phone number is ranked #2 out of 2 because 7,728 EPSON PRINTER USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:888:,:67OO27I is to reach the EPSON PRINTER USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, EPSON PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. EPSON PRINTER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about ************ and ways to call or contact EPSON PRINTER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling EPSON PRINTER USA Calling EPSON PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from EPSON PRINTER USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with EPSON PRINTER USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare EPSON PRINTER USA's phone numbers against each other. Contacting EPSON PRINTER USA in General While ************ is EPSON PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that ************ is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach EPSON PRINTER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact EPSON PRINTER USA.
Oct 16, 2019 | Epson Computers & Internet
HP PRINTER Technical Support Phone # I:888-67O-O271 Number This HP PRINTER USA phone number is ranked #2 out of 2 because 7,728 HP PRINTER USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:888:,:67OO27I is to reach the HP PRINTER USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, HP PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. HP PRINTER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about ************ and ways to call or contact HP PRINTER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling HP PRINTER USA Calling HP PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from HP PRINTER USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with HP PRINTER USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare HP PRINTER USA's phone numbers against each other. Contacting HP PRINTER USA in General While ************ is HP PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that ************ is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach HP PRINTER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact HP PRINTER USA.
Oct 16, 2019 | HP Computers & Internet
Computers & Internet Logo
54 people viewed this question
Ekse
Alun Cox
