Question about Sanyo EM-Z2100GS Microwave Oven
Sanyo microwave My microwave is turning on and rotates but fails to heat up any food help, I have lost the warranty!.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 32 Answers
Could be the Magnatron, Diode, HV Cap or Transfomer, some also have a high voltage fuse that blow. Unless you really are confident playing with Very High Voltages, and have a meter capable of 5000v, I dont recommend you repair yourself as a microwave will happily electrocute you. Also if the discharge resistor has burnt out on the cap (assuming it was fitted on your model) the capacitor can store enough power to kill you even when the unit is unplugged so you must discharge the cap before playing with anything else to be safe.
Posted on Mar 18, 2008
My microwave is brand new.just use for a week and suddenly the light is on all the time.eventhough i close the door still light is on..I cannot warm up my food.please help me.
Posted on Nov 19, 2008
My Sanyo microwave oven (model: EM-G4753) isn't heating my food. Everything else works, the fan, the lights. The microwave turns and sounds like everything is working but the food won't get hot. It is only...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Feb 24, 2011 | Sanyo Microwave Microwave Oven
Plate does not rotate
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
lggklj
Jun 25, 2010 | Sanyo Microwave Microwave Oven
Microwave does not heat
your magnatron tube (what heats the food) is out, if it is not still in warranty it will run 200-300 to fix, might be better to replace sorry
Jun 08, 2010 | GE Adora DVM1850 Microwave Oven
Sanyo microwave EM-3310
http://www.givemefile.net/smanuals/_microwave_ovens/sanyo/file/6419.html
http://www.repairfaq.org/sam/micfaq.htm
OK above is a service manual, this should get you into the "ball park" I have given you also a DIY repair of microwaves.
Usually, the magnetron, or High Power Diode, is what fails. Anyway perform the troubleshooting steps, and you should be able to sort it out.
BE CAREFUL. Microwaves are LETHAL.
May 28, 2010 | Sanyo Microwave Ovens
Food does not heat up
well the fuse has very little to do with the process of heating the food. It merely completes a circuit between the wall and the power supplky of the unit.
Your problem may be that the Magnatron is dead ( expensive repair) or that the fail safe has engaged, whereupon the unit has overheated because of poor airflow and has invoked the isolator switch.
If this is so it will start when it has cooled ( 2-3hrs) Make sure thyere is a good airflow around the cabinet. Those built intpo cupboard hutches often fail from overheating.
M/waves can be picked up cheaply from pawn shops now rather than repairing. People trade up and sell ofd their perfectly good oloder modles. You can pick up a good one with 30n day warranty ( prechecked) FOR about $100.00. Whcih is a lot less than a new Magnatron.
Please rate my help++++Thyanks for using FIXYA
May 04, 2010 | Sanyo EM-Z2100GS Microwave Oven
Viking 1100 watt Microwave will not heat food
heatman101
fjj
Jan 05, 2010 | Viking VMOC205SS Microwave Oven
Microwave not heating food
I have exactly the same problem - strange and annoying! Did you manage to fix it?
Cheers,
Ben
Nov 15, 2008 | Sanyo Microwave Ovens
Sanyo Microwave EM-G4775 - doesn't heat up......
It's probably a loose connection at the magnetron or a bad magnetron.
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Some manufacturers (in the US anyway) will send you the magnetron to do it yourself. If nothing else, you can save about $75US by taking it to the shop yourself.
Apparently you're in the UK, judging by the model number.
You can find Sanyo UK microwave owner's manuals here.
You can find Sanyo UK support, parts and authorized servicers here.
Oct 12, 2008 | Magic Chef CMV1000B Microwave Oven
Sanyo EM-Z2100GS Microwave Oven Logo
288 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
robert landry
Greg Cann
Greg Cann
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
