Question about Ovens
Oven door getting too hot
Hi, please can you tell me if it is normal for the oven door to get too hot to touch. The whole of the door gets too hot, including the temperature dial.
  • 2 more comments
  • dgm98 Jun 18, 2008
    I have same problem but its a kitchen aid oven and it occurs after we turn the oven off...why does it occur after the oven is turned off and is there problem we can fix or is this a design flaw
  • Anonymous Oct 08, 2008
    Above the oven door handle, got so hot it burned my grandson's hand. Kenmore stove purchased new in June 2008. This can't be safe. Door was closed well, gasket is brand new. Door overheats every time the oven is turned on.
    New Kenmore stove. Oven door gets so hot above handle, caused burns on small child.
  • zoen Jul 14, 2013
    ive had the same. it gets too hot to touch all round-on the external areas and only after the oven being on a short time. it was recently re-fitted into my new kitchen. i dont remember it doing this when it was in the old position? im concerned as the cupboards are flush against it and it could be a fire hazard?
    President:
  • 2,651 Answers
Other than checking the door seal itself, make sure its intact and door closes properly. make sure door' doesnt spring back open after closing does the opening along sid look to be even all the way up the side. maybe the oven door opens more than 90 degrees?? if it does id look into replacing the door hinges
Posted on Mar 15, 2008
  • John Ortakales Jun 11, 2012
    My daughter's oven was doing the same thing. I had them buy another window. The new assy came with only the single glass pane just like original but you could see where a second pane can mount. I installed the old pane in the new window assy and now they have a 2 pane window behind the front glass door panel. Guess what? It is now cool to the touch and will now harm their small children. It was worth the $45 to make this change. I don't know why they have to be so cheap and only install 1 pane of glass.
Amica oven door gets so hot that my child has burnt hes hands and needed medical attention
Amica is a European brand, I recommend you contact the company headquarters or a competant local repair shop. Any oven left at a very high temperature for a long period of time gets pretty hot, though, and an eleven month old baby has pretty tender skin.
Jul 19, 2014 | Ovens
Hi, I only just installed Baumatic single built in fan oven (B0616SS). I did as instructed and left on for 39 - 40 minutes at max 250 temp. I noticed that the oven door was very hot to touch, too hot! This...
Hello- This is a brand new model, but it works the same as the rest. Heat is produced by the elements. The fan has an element that glows when heating the air. --Convection oven glass gets hotter than normal fanless models.-- This is all normal operation of the oven.  To ensure full life of oven, avoid using the 'self-clean' feature. Techs call this the 'self-destruct' cycle. Please reply to this post if info is helpful- have more if needed- Thanks- Ed
Mar 19, 2010 | Baumatic B604SS Stainless Steel Gas Single...
Oven door to hot too the touch.
check that the thermostat is working correctly.if food is cooking to quickly or burning then stat could be faulty
Aug 05, 2009 | Neff U1421 Double circotherm Electric Oven
Stove top hot when oven on
There is a vent tube that generally goes up to a back burner where you can use it for keeping something warm. There may be a problem with that tube falling out??? and all the heat is venting to under the stove top. Look fer it
Jun 26, 2009 | Magic Chef 9815 Electric Single Oven
Know display anel getting EXTREMELY hot
Laura_kucari
I think you are feeling the heat coming from the oven vent. The fan still runs as it tries to cool down the temp in the compartment housing the electronics.
Regards
Aug 31, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
GE monogram double oven display getting extremely hot
Usually the knob type controls uses the bulb for temperature regulation. There is usually only one adjustment available - otherwise the thermostat has to be replaced. - that dial with the temperature graduations on it. the whole unit - the bulb in the oven is connected to it.
Burning hot oven door
As far as I'm concerned this is a safety hazard and not acceptable be any means. No oven face should reach temperatures that can cause serious harm to the consumer. For some reason the door is not releasing the hot air built up between the glass sheets. When the oven is running, can you feel hot air escaping through the top of the door ? Also, is there hot air coming out at the sides of the door ?
Jan 21, 2008 | Whirlpool GBD307PDS Electric Double Oven
Exterior surface of oven gets hot when turned off
What do you mean by very hot? Is it too hot to touch? Hot enough to sizzle when a drop of water is put on it?
Oct 06, 2007 | Dacor MCS130 Millennia Electric Single...
Ovens Logo
2,754 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
