What I used to do, when the head was in a tight area. I would cut the
heads off a couple of the old head bolts. And by hand screw one into top ctr. of the head mounting surface on the block then screw in the other just below it. Next. Place the gasket on the block and using the
bolts for guide pins slide the head down onto the dowels. If you don't
have a bench grinder or a cutoff wheel. Take 1 of the head bolts to a
hardware store or home depot, and pu a couple of cheap bolts 5-6" long
or a piece of threaded rod the same size as the head bolt. These will be
a lot easier to cut then the grade 9 head bolts. Hope this helps.
Please explain in more detail.... from what i understand the head should have a slot that the dowel pin fits into to make sure the head is fully aligned
