Question about Maytag Performa PAV2200
Set wrong load setting
I made the mistake of running my Maytag Performa top load washer model no. pav2200aww on mini load when it should have been a large load. It stopped and will not restart. I tried doing the reset on the front control button and nothing. Did I just brake my machine?
    Sergeant:
  • 351 Answers
You may have overheated the motor,try leaving for an hour or so and try on spin to see if it starts.hope this helps.
Posted on Mar 15, 2008
I have a Maytag Performa Top Loader PAV2200AWW it will not spin. Previously made a loud noise. Should I repair or invest in a new one?
This is a simple fix. All you need is the transmission pulley and bearing.
Here is a link to the kit you need. It is under $50.00 and should only take less then 30 minuets to fix. Also, I included a video to walk you thru the process.
Oct 13, 2012 | Maytag Performa PAV2200
Our maytag performa top load washer PAV2200 stopped in the middle of wash cycle and we heard a loud pop and then smelled burning rubber. My husband has pulled the belt off the bottom and its still in one...
Check the drain hose from the drum to the pump assembly. Alternativly look for the large capacitor that should be mounted to the internal framwork of the machine, see if has popped. They can make quite a bang when they go,
Jun 20, 2010 | Maytag Performa PAV2200
REMOVAL OF TOP AGITATOR ON MAYTAG WASHER
i believe all you have to do is put you fingers underneath it grab the sides and pull up,that will remove the whole agitator,if you want to change the dogs,pop off the top fabric softener dispenser and take out the 7/16 bolt and remove middle section,change your parts and put it back the same way you took it apart
Nov 03, 2009 | Maytag PAV2300 Top Load Washer
Maytag performa mod#pav2200aww leaking between rinse and spin cyc
My Performa started leaking from the Drain Pump rubber gasket. It had dryrotted. However, Maytag doesn't make a replacement O-ring gasket. You have to buy the whole new pump! Thanks Maytag.
Jul 05, 2009 | Maytag PAV2300 Top Load Washer
Maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Jun 25, 2009 | Maytag Performa PAV3200
Maytag performa washer hot/cold now reversed
Try moving hot hose to the cold side and c old hose to hot side on supply side. this should correct your problem
Feb 26, 2018 | Maytag Performa PAV2200
Water won't stop running, won't advance or wash or spin cycle
CHECK THE TIMER AND SEE IF YOU CAN FIX IT. THAT IS USUALLY THE FIRST SIGN THAT YOUR WASHER DOESN'T WORK. ON THE OTHER HAND, IT COULD BE ANY NUMBER OF THINGS, BUT CHECK THE TIMER FIRST. IT SHOULDN'T BE THAT HARD TO REPLACE THE TIMER.
RODNEY
Apr 14, 2009 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
231 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
