Question about Sharp AR-M207 All-In-One Laser Printer
SHARP AR-M207 CAN YOU TELL ME WHAT THE ERROR CODE L1-00 MEANS ON THIS MACHINE AND A POSSIBLE FIX FOR IT?
    President:
  • 2,072 Answers
L1:Indicates that the Main PWB sensed that the carriage did not leave home after power up or after start is pressed.
Lift the lid and watch the lamp carrage. See if its moving.
If not, remove the glass and try to slide it to the middle of the machine. replace the glass or another fault will occur.. When it is almost back to the left, watch for it hitting a sensor or screw.
If it flat out doesn't move the scan motor itself has gone bad.
Also see if one of the cables have popped off, it would be obvious if one broke.
You could have a bad main board or the connection came loose on the board where the scanner plugs into it. It is an odd connection.
Posted on Mar 15, 2008
MY SHARP AR-M207 DISPLAY ERROR CODE L4-00 KINDLY GIVE ME A SOLUTION
Hi Alafin,
An error code of L4 suggests a motor error. It could be something as simple as a loose cable but it could be a bad motor. I would suggest you call on a local dealer to repair this as you will probably need new parts.
Jun 14, 2016 | Sharp Used AR-M207 Copier Printer Scanner
My sharp AR-M207 is showing error H4.00 call for service i need solution
Enter simulation mode by pushing # * C * then type 14 and the copy button. The machine will restart and the error code will be gone.
Sep 26, 2011 | Sharp AR-M207 All-In-One Laser Printer
U2-40 error on sharp AR-M207 displayed on the digital display... what do i do
U2 04 EEPROM serial communication error
11 Counter check sum error
12 Adjustment value check sum error (EEPROM)
40 CRUM communication error
this the U2 Code Error
Jun 09, 2010 | Sharp AR-M207 All-In-One Laser Printer
I have a Sharp AR-M207 with an H4-00 error. We have installed a new fuser but still get the error the moment that we turn on the device. I have seen several responses telling which buttons to press to...
heat roller low temperture detection&check the thermistor abnormality,heatlamp abnormality,thermostat abnormality,clean the paerdust guide &use sim 5-02
check the heater lamp blinking operation
use sim 14 to clear the slf diagnostic display
Oct 19, 2009 | Sharp AR-M207 All-In-One Laser Printer
I have an AR-M207 machine scanning error msg
Is it possible to ping top this machine? My i.t tech just whispered into my ear and said perhaps the machine can't scan perhaps because the authentication name/password (login name/paddword of your pc) has changed, so the copier doesnt have the permission to write information directly to your computer.
Jun 08, 2009 | Sharp AR-M207E Black and White Copier
Sharp AR-M207 with a F9-00 message
f9-00 means the ar-nb3 and or eb9 print control boards failed to recive all packets involved in a perticular print job. weither its 1 page or 100 pdf tiff raw etc does not matter.
as a printer service technician i can ashure you there is no known all inclusive fix at this time. cycling the machine's power will clear the code.
Mar 18, 2009 | Sharp AR-M207 All-In-One Laser Printer
Error Call for Service H4-00
# - intrrup key - clear - interrup key 14 print
this all
check fuser lamp, thermost
just
Aug 18, 2008 | Sharp AR-M207 All-In-One Laser Printer
Sharp AR-M207 All-In-One Laser Printer Logo
176 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
