Question about HP DeskJet 932c InkJet Printer
Printer preferences are in french
Hi- I have the 932c Ink Jet printer. When I go to the "Print" page to send my documents to get printed, it comes up in English. Then if I want to change the paper or the print quality and I hit the "Properties" screen, the properties screen comes up in FRENCH. THis is driving me crazy because I can't always tell what to change it to... no french blood in me! Anyway, is there a way to set it so that it all comes up in English?
Thanks,
SueAnn Hurst
sueannhurst@msn.com
  • Anonymous Apr 20, 2008
    I have the same problem with my HP952c. How do I fix this?
    Mike
I had this happen to me too. I uninstalled the printer software (after I realized the default settings had been changed to French...so there wasn't much you could do), and then simply reinstalled it. Worked like a charm! Most likely a virus did this. Hope that it works for you.
Posted on Aug 04, 2009
My EPSON Stylus Photo 1400 Ink Jet Printer is printing blank photos. The ink levels are fine, it's feeding photo paper fine, it's making the same noise as it does when it prints but the photos are...
Your problems states that photos are being blank when trying to print it.
Please try these tips.
  • Make sure your printer is selected in the Print window or in the Macintosh Page Setup and Print windows.
  • The print head nozzles may need cleaning.
  • Make sure your printer software settings are set for the paper size you're using.
Plus,i also wanted to know if you can print ordinary documents or print a test page.
Hope this helps.
Thanks,
FixerDelta
Sep 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
Printer only prints in black/white. have put new
It could be the print setting on your computer.
If you're using Windows, with your document open, go to File > Properties/Preferences. In the Print Setup tab, make sure to select "Print using all available ink" in the Ink Use section.
On Mac you can select Color in Print Setting in any expanded print dialog.
Sep 01, 2011 | Lexmark Interpret S405 Wireless All-in-One...
The Hp deskjet 932c went to the far left position and the light is flashing. That is supposed to mean its out of color ink but its not. I uninstalled the software and reinstalled. It will start to print a...
Follow each of these steps until the problem is resolved:
  • Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  • Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present
  • Remove and then reinsert the print cartridge(s) into the printer.
  • Print the document.
  • Try printing again. If the problem continues, replace the print cartridges.
Aug 04, 2010 | HP DeskJet 932c InkJet Printer
Color cartridge runs out even though I'm only printing b&w typed scripts. Any way to shut it off? Only have use for color printing once in a blue moon Hewlett Packard HP DeskJet Printer #932C
Even though you print a b/w document... unless you say 'black cartridge only' in your printing preferences, all the colors get used.
Find 'black cartridge only' in your printing preferences, or 'print in greyscale' and then print your document. You must specify this for your printer to know that it must use the black only.
Jul 23, 2010 | HP DeskJet 932c InkJet Printer
932c prints intermittantly
this is b coz of paper quality and sometimes due to moisture but try loosing the static and restart the system
May 07, 2009 | HP DeskJet 932c InkJet Printer
RE:Cannot print in documents
It's one of two problems, either the nozzles in the cartridge are clogged or your printing preferences are set to "print in grayscale." To clear the nozzles try running the printer through a "deep cleaning" cycle from the printer's maintenance screen (available from the printer's properties). To check the printing preferences go to the printer's properties, as well, from Start > Control Panel > Printers & Faxes > right-click on the printer and choose Printing Preferences. Make sure to uncheck "Print In Grayscale."
Nov 11, 2007 | Compaq Inkjet IJ650 Printer
Printer
What printer and software are you using?
Does it do this for anything you print. Example a word document.
Oct 10, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP DeskJet 932c InkJet Printer Logo
153 people viewed this question
Ben Johnson
