Question about Dell S2500 Printer
Dell s2500 printer - multipurpose feeder not taking paper - never been used
I have a Dell s2500 printer that does a very nice job from the standard tray. However, the multipurpose tray, which I have never used, does nothing. I am trying to print envelopes. The totla use on the s2500 is less than 1000 sheets. Warrenty has long expired.
  • thealple May 02, 2009
    The paper pickup roller catches the first sheet coming through EVERY SINGLE TIME. ! I just replaced the cartridge with a new one but I've watched that roller move round and round very smoothly until I put the paper tray in place.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 24 Answers
I had the same problem and resorted to making sure that there were several envelopes in the tray -- and hand feeding them. I suspect we both have a pickup roller problem, which is typical of the printer, and is the source of a lot of phantom jams.
Posted on Apr 07, 2009
I am using hp 3505 color lesser printer on windows 7 32bit, Driver that was installed automatically by windows is "HP Color LaserJet CP3505 PCL6" My tray 1 that is multipurpose tray is printing slo
Make sure that you have tray 1 set for the correct paper type. Leaving the paper type as unknown will result in very slow printing as the printer will assume that it might be printing on heavy media, envelopes or the like.
Feb 02, 2015 | HP Office Equipment & Supplies
Hi, I have a Dell printer, and it says "MPF Load Error" every time I try to print something. How do I fix this?
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
Print from the Multipurpose Feeder (MPF)
To print from the Multipurpose Feeder (MPF), perform the following steps:
  1. Click the Start button, point to Programs, point to Accessories, and click Notepad.
  2. Type the word test.
  3. Click File and then click Print.
  4. In the Print window, verify that the Dell 3000cn / Dell 3010cn / Dell 3100cn printer is selected in the Select Printer dialog box.
  5. Click the Preferences button.
  6. In the Printing Preferences window, click the Paper Tray tab.
  7. Click the Paper Source drop-down and select MPF.
  8. Click OK.
  9. Click Print.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 19, 2011 | Dell 3010cn Laser Printer
We haven't been using this long and it has been great, suddenly getting an error -load paper in the MP tray? out of the blue
Most probably either someone requested manual feed, or someone tried to print a document, which has a different page size that usual (or perhaps envelopes or something), so it is asking for this special-size media to be fed into the manual/multipurpose tray.
Just put some paper in the MPT and investigate whose documents require this special atention, and perhaps find out why is this person sending non-standard print jobs.
Jan 08, 2010 | Brother DCP-9040CN Laser Printer
What does it mean by Load MP feeder letter?
That means whatever you are trying to print is set to feed from the MP tray or Multipurpose Tray. The tray that folds out that is used to feed thicker paper or envelopes in. Just check your print setup screen and tell it to feed from the lower tray or tray1. If that is what you were trying to do.
Dec 28, 2009 | Dell M5200n Laser Printer
Dell S2500 doesn't recognize loaded paper.
Pull the paper tray out and check if the paper end sensor is out of bracket or broken.When you remove the paper tray and look inside,you should be able to see the sensor lever that can be moved up by finger.It moved up by paper stock when you insert the tray.This is how paper detection mechanism works on majority of the printers.
Oct 05, 2009 | Dell S2500 Printer
IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
CD sleeves.
Julie,
I believe that there are kits available that include sheets of CD sleeves and software to help you print to them. Otherwise, if just printing simple labels you could set up the print job to print in the section of the sheet where the sleeve you're printing resides.
If the sleeves are stacked and not like 6 to a 8 1/2" X 11" sheet, then I imagine it would be just like setting your printer up to feed envelopes (if that's possible, in the old days we would but the sleeve in a typewriter and viola. We didn't have a choice on the font though. :(
I hope another one of us posts an easier solution for you, and Good Luck.
Mar 12, 2008 | Dell 5110cn Laser Printer
Dell 5100cn Laser Printer Multipurpose Feed Problem
I had the same problem, my solution was:
1) Go into the Print dialog window, select your 5100cn printer and click the "Properties" button next to it.
2) Select the second tab, labeled "Paper Tray".
3) Select "MPF" from the "Paper Source" drop-down list.
4) Click the "MPF Settings" button and select "Envelope".
That should allow your program to print to MPF for envelopes. This needs to be done in your software, setting it on the printer's control panel didn't work for me.
Dec 17, 2007 | Dell 5100cn Laser Printer
Dell S2500 Printer Logo
323 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
