You must not have a v3xx, because the v3xx uses a mirco sd card and the slot is next to the sim card slot.Also the v3xx has a camera, and there is no option to get this model without a camera. The v3 does not have a memory card, but has camera also.
If you do find the slot,if you have a v3xx,then go to your menu and then open connection, then open,phone status, then scroll down to storage devices,open it, should be left top button, pick options,now you should see,details,rename,format, format the card, this should allow the phone to see the card. There are some brands that just don't work with a phone. I have always used kingston. I have around 12 different type's and they have always been a great card.
Sure, if you connect your phone to the PC with a USB cable, you can access the photos that are on the removable MicroSD card and transfer them to your computer.
I was able to get a subsidy code by calling AT&T customer service, telling them that I had purchased a used phone that I wanted to use on their network, and needed a subsidy code. (All true, BTW.) They gave me the code that unlocked the phone for free.
You might want to call your carrier and see if they'll do the same.
all right so you purchased the memory sticks and the usb cord so your good to go first thing is the small memory stick needs to go in the phone so to do this remove the back cover of the razor and there should be underneath the battery left to the sim card a slot insert the memory stick in the slot(follow the arrows) attach the cover. next take the larger of the memory stick or the adapter and if computer compatible insert into computer (optional) next take the usb adapter cord insert the large usb side into the computer the other side in to the charge port on the razor. a window should come right up asking ou what to do click view folders now when next window comes up select the folder and drag music into appropriate folder. any further questions or more indepth instructions [email protected] only for actual help no **** please
it's turn off coz the files and folder is not compatible to the other phone.
try to formatted it to the old phone and formatted it in to the PC and try to put it to the new one and formatted it again.
Under the settings for usb connection type change the setting to memory card connection. This is subject to having a memory card (Micro sd) installed. Otherwise you may have to install motorola phone software into your computer and use this to update files on your phone. Regards, David M-G
I HAVE A 1200 MODEL MICRO 512 MB CARD AND mp3 SONGS LOADED IN IT.I WANTED TO DELETE SOME OF THE SONGS FROM THE MICRO SDCARD ,,BUT I COULD NOT DELETE THE SONGS .PLEASE GIVE THE PROCEDURE TO DELETE THE UNWANTED SONGS..
