Brigtness of Compaq Presario v2100US
When i switch on my computer it turns on normally and works well.But after 2 mins the brightness of the screen completely goes off.
  • 807 Answers
Check the power settings in windows.
Right click in the middle of the screen, click Properties, then Screen Saver tab.
Then click Power button at the bottom. Check the settings in there.
Posted on Mar 14, 2008
Compaq presario v2000 screen blank
Hello there!
Check those hints!
1) Check the brightness, and contrast keys!
2) sometimes, taking out battery, for 1 minute solve some issues.
3) bad inverter video.
4) select internal video, instead outside video (keyboard)
Apr 28, 2014 | HP Compaq Presario V2000 Notebook
Compaq Presario CQ56
Basically, there are 2 possibilities:
1. The connection at the back of your screen is lose, so you need to tightened this connection (usually the flex cable's connector),
2. Your laptop screen is dying, so sooner or later, you need to replace your screen.
Mar 03, 2014 | Computers & Internet
Hello, My laptop turns on and begins to start up but then goes to a black screen instead of the home login screen. What should I do?
If the normal login in screen is still partially visible under a bright light, you may have a faulty backlight. Get your machine checked.
The way to work around it could be to wait until the computer has started up (look at the hard drive light) and then put your machine into standby by closing the lid or pressing the power button (according to your settings). When you start back up again the screen should turn on as normal.
Aug 30, 2011 | Compaq Presario CQ60-220US PC Laptop
I have my compaq presario cq60 laptop and i got a trouble on my screen which is the brightness become low and i can not adjust using the fn key plus f8. how can i adjust to return on the normal...
How low has the brightness gone? If it is very dark and you can barely see anything on the screen, it may be that the inverter board has failed and needs replacing.
The problem could also be caused by the screen itself, or the motherboard, but the inverter is the most common solution.
Jul 23, 2011 | HP Compaq Presario CQ60-249US Notebook
How do I adjust the brightness on my laptop? Its a Compaq Presario V2140US
1. Press down the Fn key at the lower left end of your Compaq Presario keyboard. Keep the button held down and tap the F7 key to decrease the screen brightness by one step.
2. Tap the F7 key again with the Fn key still depressed to further decrease the brightness by one step. Continue hitting the F7 key until you reach the minimum LCD screen brightness.
3. Hold down the Fn key and tap the F8 key to increase the Presario's LCD screen brightness by one step. Keep pressing the F8 key until you reach the maximum brightness for your screen
Mar 01, 2011 | Microsoft Compaq Presario C501nr Notebook
My Compaq presario f572us notebook screen turns black upon normal startup. The screen does not turn black if I start-up in the safe mode. It only when i attempt to start windows normally. Everything loads...
i also have a compaq presario f572us that's been having similar problems. when i went onto the hp website i saw that apparently they've been having similar problems with this type of computer as they offer free repairs for 2 years after you bought it. you should probably check if this works for you too
Oct 23, 2009 | Compaq Presario F572US Notebook PC
My compaq presario v5000 a 5240NR was working fine
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness
Oct 01, 2009 | HP Compaq Presario V5000T Notebook
Screen troubles
I assume you are running it under normal power supply (mains)?
Try checking your display settings, they may be set st a lower brightness level. As you switch on the computer it is taking a few seconds to catch up and dim down once the settings kick in.
Aug 26, 2008 | Compaq Presario R3000 Notebook
Compaq F700 Battery live very less
Giri,
Its normal, generally it comes with 80-90 min. You can use HP Power management to optimize the use of battery. Making screen less bright will increase the power backup.
Thanks
Iqbal
Apr 28, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
Alun Cox
David Payne
David Payne
