Question about IBM Wheelwriter 30 Typewriter
Ibm wheelwriter I loose what I store in the memory each night when the typewriter is shut off. It never used to do this before.
  • ibmhelp Mar 17, 2008
    Soooo incredibly helpful. Thanks so much!!
    Thanks so much, RadarRon!!
  • IBM Master
  • 3,594 Answers
If you have a wheelwriter there are batteries under the top cover lift it up like you were going to change a ribbon and you will find it either near the left or rt. side it will have either 2 or 3 AA batteries replace them. If they are corroded be sure to clean up the contacts with a little sand paper.
Hope this helps
DickyO
Posted on Mar 15, 2008
  • 398 Answers
There is a battery on the main board. the case cones apart with a screwdriver.
  • Ron Dufek
    Ron Dufek Mar 18, 2008
    I had the right fix but I was thinking of a different model Wheelwriter. Glade you got it fixed anyway.
    Ron
SOURCE:
I had a setting where I could use play 65, someone erased it how do I reset this feature
Hold down store, type 65, release store, type what ever you want, press store again. Be sure to check the batteries or you may loose info. again.
DickyO
Jul 23, 2014 | IBM Wheelwriter 5 Electronic typewriter P...
How do we use the memory? we need a manual
There are 3 keys on the L. side of the keyboard Store, Play And Del. To save info hold the stor, type the address 01-99, release store, type info, press store again. To print hold play, type address, release play. Delete works the same way.
BE SURE THE BATTERIES ARE GOOD OR YOU WILL LOOSE SAVED MEMORY ON POWER DOWN!!
You can get a maual @http://support.lexmark.com/index?page=content&id=SO4998&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT
DickyO
Jan 26, 2011 | IBM Wheelwriter 30 Typewriter
How to delete memory on RePrt
If you pull the R. upper bail arm to activate the auto paper insertion will clear the reprint, turning it off will also do it. There is no way to stop it from storing data as that memory is also used for correction.
DickO
Dec 10, 2009 | Lexmark Wheelwriter 1000 Typewriter
STORING MEMORY
The Brother SX-4000 typewriter does not have memory storage capabilities. I have one right here.
Nov 14, 2008 | Brother SX-4000 Typewriter
Store text
The WW1000 only has a reprint memory that can only reprint what you have just typed. to get a machine with a true memory you need a WW with store play & del keys on the L. dide of the keyboard, WW 5, 6, 30, 35, Etc.
DickyO
Jul 28, 2008 | Lexmark Wheelwriter 1000 Typewriter
How to set memory
On the L. side of the keyboard there are 3 keys store, play and delete.
To store hold code and press store type in 01-99 for an address, rel keys, type info. when complete press store.
To play press play and the address 01-99 to print.
To delete press del. and address.
DickyO
Jul 23, 2008 | IBM Wheelwriter 30 Typewriter
Memory
On the L. side of the keyboard there are 3 keys store, play & delete.
To store hold store & code then type an address 01-99, rel. keys and type data on completion touch store again.
To play hold play and address to type.
DickyO
Jun 20, 2008 | Lexmark Wheelwriter 6 Series II Typewriter
Print from the memory
If this an ibm ww30 the row of keys on the left labled store delete & play control the memory press and hold store and press 0 thru 99 to assign an address release store key type info then press store again, to print press play and the address .
DicktO
Feb 16, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
80 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
