Question about Sharp UX-B20 Plain Paper Inkjet Fax
Clearing an error
Hello. The paper jammed while receiving a fax. I have cleared the jam but am unable to clear the error alert on the screen. It says that the fax is still in the memory, but I am unable to retrieve it until I clear this....
Thanks for your help,
Ryanne
You need to push the 'stop' button and wait for the fax to check itself for jammed paper.  Once this is done the faxes in memory will start printing again.
I hate this fax, this happens all the time on my machine, plus the paper will not feed properly unless I physically force it down which often leads to paper jams.  Which is how I know how to clear it.
Posted on Jul 23, 2008
  • 82 Answers
Well, one of two things have happened, 1. you haven't removed all of the jammed paper, maybe you left a small piece of a piece of paper or you may bent or broken your paper jam sensor. go through the paper path very carefully and check both things.
mikey
Posted on Mar 16, 2008
HP error code 363, what does this mean?
I went online and found the HP8600 user manual and this is their solution to the error code 363 that you reported, which I copied off their site. Hope this works for you:
  • Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly. Click this link HP All-in-One and Fax Products for more information on enabling or disabling ECM.
    beaac3qsmgaaaaaelftksuqmcc
    NOTE: Error codes that apply specifically to ECM have ECM listed next to them.
Error Code: 356, 357, 358, 359, 360, 361, 362 ECM, 363 ECM, 364 ECM, 365 ECM, 366 ECM
Definitions
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
Solutions
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
May 27, 2014 | HP LaserJet 3050 All-In-One Printer
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
Cant send nor receive faxes
dear sir,kindly follow the below instructions
Instructions
  1. Ensure that all cables are securely connected. First, make sure that the printer cable connecting your computer to your printer is connected securely. Then, make sure that the power cord is inserted into a wall outlet. Try your print job again after you have ensured that all cables are properly connected.
  2. Clear a paper jam if your printer is not responding or you are receiving a "Paper Jam" error message on your printer. To clear a jam, first open the rear output door by pushing down on the two levers on each side of the door. Opening the rear door simply makes it easier to clear a jam. Open the top cover on the front of the printer by pressing the release button on the right side of the printer. Locate the paper jam and use two hands to gently remove the paper jam. Try your print, scan, fax or copy job again.
  3. Clear stored or saved faxes if you are having trouble sending or receiving faxes. Old faxes may be stuck in the fax queue, which may be causing the printer to not respond. To remove stored faxes, press the "Menu" button on the printer and select "Fax Functions." Then select "Clear Saved Faxes." Wait for the queue to clear and try your fax job again.
  4. Remove paper from the automatic document feeder (ADF) input tray if your scan job is coming out crooked. The ADF input tray can only hold up to 50 sheets at a time. If there are more than 50 sheets in the input tray, the output may appear skewed. Try your scan job again after removing the paper.
  5. Adjust your computer monitor's display settings if your scanned image is not an accurate representation of the original image. This can be done in the "Control Panel" in Windows. Set the settings to the highest possible resolution and try your scan job again.
  6. Perform a power cycle on your printer if the previous steps were unsuccessful. To do this, turn off your printer, then unplug it from the wall. Wait a few minutes and plug the printer back in. Try your print, scan, fax or copy job again.
take care..thank you
Oct 04, 2010 | HP LaserJet 2840 Printer
Clear paper jam
may be there is small pice of paper inside just remove that.
Jan 20, 2010 | Canon FAX JX200 - Fax / copier - ink-jet...
"unable to clean"
Hi dbostrander.
First check for foreign objects in the paper path. Check if you have any faxes in memory because you will lose them when removing power; see later.
Pull out the paper tray from the front and check for paper jams or torn paper anywhere inside the machine. Also check the 'jam clear screen' at the back of the printer. Remove the cover, remove any obstacle then replace ther cover.From the front of the machine lift the top cover from the right side till it is fully open on the slide. Check for jams. If the jam is under the print head you will have to disconnect the power (losing any faxes in memory *see below) to move the print head out of the way to clear the jam.Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
Check whether the MFC has faxes in
memory
1.Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
and then reconnect it then do as above.
—OR—
If faxes are present, you can transfer them to
another fax machine
If you have not set up your Station ID, you
cannot enter fax transfer mode.
3.Enter the fax number to which faxes will be
forwarded.
4.Press Mono Start.
5.After the faxes are transferred, disconnect
the MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set, 9,0, 2 in step 1.
Hope this helps,
Mark.
Mar 21, 2009 | Brother MFC 210C All-In-One InkJet Printer
Panasonic Fax Phone Can't send or Receive fax
there maybe a small paper jam in the machine that you are missing. if you are handy, unplug the fax machine and look around where the paper is fed into. if you see paper trapped anywhere, try pulling it out with a pair of needle nose pliers. the machine will not work right till the jam is cleared.
hope this helps.
wg
Feb 10, 2008 | Office Equipment & Supplies
Fax fixable? error msg
We call the moose method of clearing paper jams, the RCMP method, cuz they only know how to shoot to kill. You did good. Except, there is no such thing as "Bending" anything. The term is "re-form."
Dec 21, 2007 | Brother IntelliFax-2820 Laser Fax
Sharp UX-B20 Plain Paper Inkjet Fax Logo
398 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
