Question about Toshiba Tecra A2-S119 Notebook
Reset bios i forgot password bios tecra a2-s119, i need unlock
  • stylishlalit Jul 06, 2008
    I have a toshiba tecra 2 notebook. when start it shows a whole black screen with demanding password on the top of the left side. could any one please assist me in unlocking this notebook or laptop. Otherwise it is just a piece of plastic.
    John
  • 55 Answers
If this were a desktop computer you could take off the side cover and take out the BIOS battery. (Silver and looks about the size of a quarter) And then put it in after about a minute.
For a laptop the same thing applies but I highly suggest you take it to someone who has done this before as laptops are very tightly packed and for someone who has never done it very intimidating.
I cannot recommend you open up your laptop to take out the battery yourself but this is what needs to be done.
Posted on Mar 14, 2008
Cmos password how can be remove in crack
BIOS passwords can be reset or removed in two ways:
1. using software 2. using hardware.
I would first try resetting or removing using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html&act=down
CmosPwd - Cmos password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
Good Luck!
Aug 18, 2012 | Toshiba Tecra A2 Notebook
How do i remove the key board
How to replace your Toshiba Tecra A2-S119 laptop keyboard ?
It's easy to break the flimsy keys on laptop. In order to better protect the Toshiba Tecra A2-S119 notebook keyboard, some friends, instead, use USB keyboard. But if you work outdoors, carrying a USB keyboard is not convenient. You still have to use the laptop keyboard. Once a laptop keyboard stops working, there is no option but to replace it. You can use these steps to replace the Toshiba Tecra A2-S119 keyboard.
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Tecra A2-S119 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Tecra A2-S119 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Tecra A2-S119 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
You have to remember that once you open up the Toshiba Tecra A2-S119 laptop computer for keyboard replacement, the warranty provided by the manufacturer stands void. We personally suggest that you do it on your own only if you are in a really desperate situation and there is no way you can get maintenance from the manufacturer. I hope this assists you. John
Jan 26, 2011 | Toshiba Tecra A2-S119 Notebook
Bios password
If you forgot you bios password you need to call the Toshiba support and they will give you a code to reset the password. only toshiba can unlock the bios password since they do have the tool specificall for that problem. thanks
Jan 03, 2011 | Toshiba Tecra A8-EZ8311 Notebook
I need the Toshiba driver of TECRA A2-S119 model
Here's the link where you can download all the drivers (Click Here), you'll need to select the operating system.
If you have problem, let me know with more details about your Tecra. Good luck.
Thanks for using FixYa.
Nov 06, 2010 | Toshiba Tecra A2-S119 Notebook
Does tecra a2 s119 have tv out?
no the tecra doesnt have tv out option
Nov 10, 2009 | Toshiba Tecra A2-S119 Notebook
Reinstalled windows xp on tecra a2, need all drivers
Two things to try, install service pack 3 for xp, and go to the Toshiba website look up your laptop and see if they fave drivers that are compatible with xp sp2 or sp3. Hope you find what you looking for and this info helps. GL
Jun 23, 2009 | Toshiba Tecra A2-S119 Notebook
How do I enter the bios on the Toshiba Tecra A2?
On boot up hit and hold Esc key until it goes to bios settings.
Apr 04, 2009 | Toshiba Tecra A2-S119 Notebook
Bios settings loss
Set up time and date again and see if it stays few days. After 3 months without use it can forgot some cmos settings.
Apr 02, 2009 | Toshiba Tecra A2 Notebook
Minta tolong
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
30
Aug 19, 2008 | Toshiba Tecra A2-S119 Notebook
Toshiba tecra a2 bios locked...HELP!!!!
locate the cmos battery(CR2032) on the underside of the notebook or under the keyboard and remove for 10 mins or so and the password will be deleted from memory
Oct 19, 2007 | Toshiba Satellite A55 Tecra Notebook
Toshiba Tecra A2-S119 Notebook Logo
196 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
