Question about Fantom Vacums CW600 Upright Vacuum
Belt is broken
I must open the vacum cleaner i need instuctions I have to replace the belt and i don't know how to open it
  • 30 Answers
Most upright vacuums will have 2 screws on the bottom of the vacuum. Remove both screws and snap off bottom cover to get inside of the head. Remove old / broken belt and slide agitator off from the head unit. Stretch new belt with both hands then place around the agitator and pulley coming out of the motor. Place the agitator back into place (there will be some resistance from the new belt, but that is common). Put back on the bottom cover and place back the screws. You should be all set then. Hopefully this helps.
Posted on Mar 14, 2008
I want to see a pictute of the bottom of the vacum cause is not working
Hello! If the brushes are not spinning your belt may be broken or stretched out. I have included steps to checking and replacing your belt. There is also a link to the owner's manual attached that shows you illustrations on how to change the belt.
  • Lay the cleaner flat and flip it to expose the nozzle base. Remove the 5 screws.
  • Pull and lift the nozzle guard off.
  • Inspect the belt for damages. (nicks, cuts, broken, stretched)
  • Replace the belt with a Dirt Devil style 15 belt.
  • Slide new belt onto motor-shaft.
  • Place belt on area of brushroll with no bristles.
  • With new belt in place, pull and slide brushroll into nozzle making sure that the brushroll end caps are in the correct orientation.
  • Reattach nozzle guard.
  • Secure by aligning the 3 tabs in the base slots.
  • Replace all 5 screws.
http://dirtdevil.com/file/956/
Hope this helps!
Oct 06, 2014 | Dirt Devil Easy Lite Quick Vacuum
How to install belt on Riccar 8750 commerical vacume cleaner?
No. There is only one belt. Remove the bottom plate to gain access to the belt.
Jan 18, 2014 | Riccar 8650/8625 s Vacuum
Where is the belt housed on the Hoover vacum cleaner model U5461-900? The belt number is 38528-033 but I can't find where the broken belt is to replace it.
Simply lay the machine down with the brush assembly facing upwards, and remove the four screws holding the bottom plate in place, and remove it. Put the new belt around the motor shaft, then around the brush assembly and push the brush back into place. Turn the brush with your fingers before replacing the bottom plate, to be sure the belt isn't caught between the brush and housing.
Jul 27, 2011 | Vacuums
The brush is not rotating but the vacum works
That would mean that either the belt has come off or broken. So it is time for new belt.
Jul 07, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
The turbo brush attachment on my bissell cleanview helix suddenly wont spin. I bought this vacum a month ago. there is nothing wrong with the vacum otherwise.
The turbo brush may just need to be cleaned. If hair or other large debris gets wrapped around the brush, it can prevent it from spinning. Since the top of the turbo brush is clear, you can look in and see if there is a lot of hair wrapped around the brush. If so, you can open it up by removing the two screws on the bottom of the brush and popping the clear cover off, then cleaning all the debris from the brush (scissors work well if its hard to get dog hair off). Be careful to see how the brush goes back together as you take it apart.
If cleaning the brush doesn't fix it, the belt might be broken. As you're looking at the top of the brush, there is a little belt that goes from the brush itself to the large blue/green gear (it's red on some models) so that if you reach your hand in and turn the gear, the brush should spin. If this belt is broken or missing, it will need to be replaced. You can probably find a replacement belt online, or you can order a whole new turbo brush from the Bissell website for $24.99.
Feb 04, 2011 | Bissell Cleanview Helix Deluxe Bagless...
Does not vacum
You may have a broken or stretched belt. The machine could also be clogged. Here is a link that will take you to a site that will show you how to open up your vacuum to look for clogs and to change belt.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps.
Jan 29, 2010 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Need instuctions on how to change a vaccuum cleaner belt
What is the make and model of your vacuum? If you need a replacement belt you can get it here:
www.vacbelts.com
Oct 23, 2009 | Panasonic Vacuums
I'm trying to find out how to install a drive belt in a kirby G4
I think this video that I shot should tell you everything you need to know about replacing the belt, and how to do basic maintenance on your vacum cleaners roller brush.
If you find the video helpful, please kindly rate it by clicking the thumbs up icon below;
Thanks for watching!
Chris
Apr 26, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
How do i open my cleaner to put a belt on
Thank you for your fast reply, I took off the screws on the lid and replaced the belt with no problem
Mar 14, 2008 | Fantom Vacums CW600 Upright Vacuum
Fantom Vacums CW600 Upright Vacuum Logo
88 people viewed this question
Top Fantom Vacums Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
