Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
TV not turning on.
TV will not turn on with or without the remote. Socket working. TV is on standby, but when button pressed on TV or remote, the on light flicks to green for a second and then reverts to red. If button is held down , this red /green light sequence flicks back and forth every second. Whats up?? Thanks Norma
unit will not turn on. green light comes on and then clicks and goes to red flashing light.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Posted on Mar 27, 2008
SOURCE:
Can I turn on a Toshiba 32L4200U without the remote?
Yes! As you face the TV screen on the left hand side panel, the top button is the power button.......it will either turn on or to standby......if it goes to standby press one of the next 2 buttons which are the channel up and down buttons!
Oct 23, 2014 | Toshiba 32L4200U - 32in Class 31.5in...
Id like to know how to unlock my samsung ht-z120 home theatre dvd player to watch other counrty dvds
Hiya,
Try this procedure:
1) Unplug player from power socket (for 1min)
2) Connect plug to power socket
3) Using the remote, press POWER button to turn unit on.
4) Press DVD button to enter dvd-mode
5) Press the following remote buttons, in this sequence:
ENTER, 8, 4, 2, 6, 9, ENTER
If done correctly, your dvd should go into Standby mode.
6) Press POWER button to turn unit on.
Cheers,
"If this works, please rate this solution with thumbs up"
Jun 16, 2011 | Samsung Audio Players & Recorders
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
How do you tune Sky+ remote into Sony KDL46W5710 Television
The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
Or try this :-
With TV and sky box on.
Press the 'TV' button on the remote.
Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
Press the 'TV' button again.
Now enter four zeros, the red light on the remote should blink twice.
Press the 'standby' button (top right).
If the TV turns off, then press 'select' and the light should blink twice again, job done.
If the TV does not turn off then press 'TV' followed by 'standby' again.
Alternate pressing 'TV' 'Standby' until the TV turns off.
When it does, finish by pressing 'Select.
Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
Dec 19, 2009 | Televison & Video
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Child lock will not allow my tv to turn on
i was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tvtv is on standby, standby light is on. can turn tv on with programable remote after pressing on button several times to set code on remote. press any function button and screen says child lock is on. can't get anywhere pressing any buttons, turn tv off with on/off button and tv goes back to stand by. don't have magnavox remote any ideas?
Jul 19, 2008 | Philips Magnavox 20MS3442 20" TV
How to turn off standby mode
Try this:
On the top of your remote near the power buttons there are a series of buttons that have names under them such as "TV" and "DVD". Press and hold one of those buttons for about two seconds.
Jul 17, 2008 | Philips FR975 Receiver
TV not turning on.
set is going into shutdown. what type of tv is this. lcd.. could be one of many problems.
Dec 19, 2007 | Televison & Video
Tv stuck in standby
If you can not turn on TV set with the power button on the TV its not a standby problem as this would by pass the standby. Theres most likly, on a set of this age, top have a poiwer regulator problem and is going to need a trained tech to assist you in this repair.
Sep 10, 2006 | Sony KV-32S42 32" TV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
1,055 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
