Question about Xerox WorkCentre Pro 555 Plain Paper Laser Fax
WorkCentre 555 Fax Drum
Installed new drum, WorkCentre 555 (fax) does not acknowledge and still says "replace drum".
  • bemcp Apr 16, 2008
    i replaced the drum but the red light still indcates it need a new drum. Should I have waited til it actually asked for drum instead of changing it when it was just a warning. Perhaps the sensor does not realize it is a new drum? Should I put old drum back and wait til it asks-what should I do.
Wow! Totally worked. Thanks.
Posted on Oct 02, 2008
    President:
  • 2,072 Answers
This will reset it for you. strange !!!!!
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode
Posted on Mar 14, 2008
My fax says replace drum, which we did, but it won't reset/restart. What is wrong? Is there a code we need to enter?
Yes there is a code, it has been so long I worked on these machines, need to find it.
I will come back later if I do find it and post it.
Jan 25, 2011 | Xerox WorkCentre Pro 555 Plain Paper Laser...
How do I turn off red light after installing new drum in Workcentre 555?
When u restart the printer automatically it will turn off.............
Jul 23, 2008 | Xerox Office Equipment & Supplies
DRUM LIFE WARNING WON'T GO AWAY AFTER REPLACING DRUM.
find the box that the drum came in. There should be directions to reset the drum light enclosed. Or go to www.xerox.com , then look under support and drivers. Good luck !
Jan 11, 2011 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Our fax machine says "change drum soon" even though we changed it yesterday. What is causing this? Thanks
When you installed the new drum, there is a sheet in the box that tells you how to reset the drum life counter. Did you perform this procedure when you installed the drum?
If you don't have it just open the front cover and press options then select 1 for drum replacement.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother IntelliFax-2820 Laser Fax
I change Drum On work center pro 555 Fax Be cause it told me it was low but i cant clear the warning message off the fax i shut dowbn and rebutted but nothing can you help
Drum units usually have an electronic counter that have to be reset through a sequence of key strokes on the number pad. Your local dealership should be able to give you the info to clear the drum counter
Oct 17, 2009 | Xerox Office Equipment & Supplies
Right side of Print Out is faded. Cleaned, and Cleaned. Doesn't say to change drum/ink. What else can we try?
You can try shaking the toner cartridge to even out the toner but most likely either need a new toner cartridge or the drum is not sitting evenly as it should.
Sep 11, 2009 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Replace Drum
your toner has nothing to do with sending/receiving faxes. If you can print to the xerox...something is wrong with the software..
delete and re-install software..Xerox website is useless
check the black sensor that dangles into the paper tray. wiggle it up and down, ahten resintalled the tray
Aug 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Replace Drum
Start by trying this.
    1. Yes
    2. No
  3. Press [Stop] to return to the Standby Mode.
If that doesn't work try this. You may not be able to perform step 1 but that's ok.
> Support & Drivers > WorkCentre Pro 555 Support > Search Results Solution: Print / Clear Documents From Memory bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif
Any documents stored in memory due to an error condition will print after the error is corrected. The errors may be: 'paper tray(s) out of paper,' 'paper jam,' or 'out of ink'.
  1. Print a Pending Jobs report to determine what types of jobs are in memory. Press the [Menu] (up arrow) button, then press [2], [2].
  2. If there is a job with the status of Resend Stored Fax, turn off the Resend Stored Fax feature to delete the job.
    To turn off Resend Stored Fax:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [3], [0], [4].
      The screen will display: Resend stored fax
      1. On
      2. Off
    2. Press [2] to disable the feature.
    3. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
  3. Print the ITU-T mailbox report to determine if there are any mailbox documents. From the Standby Mode, press the [Menu] (up arrow) button, then press [2], [4].
  4. Print any documents stored in an ITU-T Mailbox:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [1], [8].
      The screen will display: Mailbox
      1. Confidential
      2. Bulletin board
      3. Relay request
      4. Setup & delete
    2. Press [1] to select Confidential mailbox, or [2] to select Bulletin board mailbox.
      The screen will display: Confidential (or Bulletin board)
      1. Print mailbox
      2. Send to mailbox
      3. Poll from mailbox
      4. Store to mailbox
      5. Delete contents
    3. Press [1] to print from the selected mailbox.
      The screen will display: Box number (20 max)
      [_]
    4. Use the numeric keypad to enter the mailbox number, then press [Enter]. NOTE: If you entered a password when creating the Confidential Mailbox, you must enter that password now to print the document.
    5. Enter the password if required, then press [Enter].
Jan 08, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Drum Life Warning Message
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum. Yes No Press [1], then press [Enter]. The screen will display: Completed. Press [Stop] to return to the Standby Mode. These directions were found on the Xerox website, and worked for me.
Dec 28, 2006 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Xerox WorkCentre Pro 555 Plain Paper Laser Fax Logo
359 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
