Question about Kenmore 80809 Microwave Oven
Bulb out help
I have a bulb that is shooting sparks. There is a grate over this bulb and I am not sure how to remove it to change that bulb.
  • 1 more comment
  • William Miller
    William Miller May 11, 2010
    Can you provide your brand and full model number?
  • William Miller
    A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
  • William Miller
    Please reply back with your full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
    Then we can probably point you to the online manual or at least an exploded view.
    Problem Solver:
  • 9 Answers
The Bulb is always accessible from inside the oven. The grate will come off in one of three ways. Disconnect power cord first.
1. Secured with screws. Screws should be visible.
2. Grate itself unscrews. Should be in counter-clockwise direction.
3. Grate held in with clips. Should pull straight out with a wiggle.
The bulb itself should unscrew in a counter-clockwise direction. Take it in as a sample when purchasing replacement.:::Spiceweasel.au
Posted on Apr 04, 2008
Need to change a bulb
If we had your full model number, we could help you more precisely.
The first step is to unplug the oven before changing bulbs!
See a diagram which helps you find & replace many GE cooktop and cavity light bulbs http://031d26d.namesecurehost.com/mwd/ge_lamp_replacement.jpg
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding: http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs (or 20A ceramic fuses) can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Nov 26, 2013 | Microwave Ovens
Tip
CHANGE BULB- GE MICROWAVE # JES1289SK01
The folks at GE told me you need a technician to change this bulb. Phooey, I say. It was a piece of cake. Save $ 100 and follow my instructions. I did it. I would imagine most GE microwaves would be similar.
Here's how to do it. I bought this bulb (part # WB36X951) from PARTSTORE.COM for $ 18.58 total (that's bad enough). Got the bulb within a few days.
This model GE microwave, is a stainless model with stainless inside and grilling element.
The bulb is located directly behind the front control panel (on the right), but you need to remove the stainless cover to get to it. Naturally, unplug it first. You'll need one those star bits (not sure what size), a philips head won't work. There's four of those sneaky screws on the rear. Remove those screws and the cover slides off. VOILA! It's magic! The bulb, you'll see, is sealed to a base, but it has as double slide contact. Undo this before removing the bulb. It's snapped into a little fixture. Remove the old bulb and snap new one in. Replace the contact leads and that's it.
The cover is a little tricky to get back seated properly. Along with the sneaky star screws, this is another attempt to discourage consumer servicing. Make sure that the cover is flush with the back before replacing the screws. You're done.
I for one, am tired of this type of this type of rip-off and scamming. I hope this tips helps many and saves some of you from paying a ridiculous service fee.
If this tip has helped you, let know. E-mail me at cdpays@bellsouth.net.
Craig Pays
Kenner, La.
on Jun 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I don't know how to replace the charcoal filter on my Frigidaire FMV157GC microwave. There's also food between the grate and the glass on the microwave door. Help !
This is billed as the Use & Care Manual for the Frigidaire FMV156DC Microwave Oven:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Springfield/316495004en.pdf
Not sure it is the correct one but you will find instruction for cleaning the exhaust filters on page 19.
Below is the Use & Care Manual for a model direct from the Frigidaire site:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316495057en.pdf
This is more helpful as on page 20 it includes illustrated instructions for removing the charcoal filter to change the oven light. Disconnect from power, remove the ventilation grate at the top to access the charcoal filter, slide back and lift to remove. With the grate removed carry out any required cleaning.
Mar 20, 2011 | Frigidaire FMV156DC Microwave Oven
I have a Kitchenaid combo unit of Oven & Microwave. Model YKEMC308KM01, Serial # XP4603281.Can someone help me as to how to change the light bulb of the microwave. I simply dont see any openings on the...
That's covered on page 21 of your owner's manual.
If for some reason you don't have yours, you can download it free here.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven.
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
You can find handy exploded views and order parts by model number here.
Dec 18, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
While unscrewing a light bulb under a microwave a fuse blew out theirs power to the microwave but it wont turn on
you are more than likely gonna hate my answer
fist thing i would check is your inline fuse
depwnding on the model
unplug the unit
open the door, remove the screw holding the control panel in place, lift the panel up and out
do not disconnect, let hang
you should see a grate right behind the control
behind that grate you should see your fuse
looks light a little metal tube
Oct 10, 2009 | Microwave Ovens
Changing light bulb in microwave oven
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Oct 11, 2008 | Magic Chef MCD1311ST Microwave Oven
Delonghi combi/micro bulb not working , how do i change the bulb
Oct 06, 2008 | Neff H7871 Convection/Microwave Oven
Short circuited Whirlpool MH1150XM while changing the bulb underneath. Need help to fix it, thanks :)
We replaced the board behind the control panel. $130.00. If you do this make sure you can put the wires back the right way. My husband finally got it and our micro is working like brand newThanks to all who tried to help.
Sep 29, 2008 | Whirlpool MH1150XM Convection/Microwave...
Light bulb change
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
If you need more help, please reply back with your brand and model number so we can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Panasonic NN-S676WA Microwave Oven
On replacing nite-lite/under hood bulb, 1 lead broke off in the socket
Be sure to disconnect the oven from the power line before removing or installing bulbs or working on it. You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 We have critical safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 22, 2007 | GE JVM1490 Convection/Microwave Oven
Kenmore 80809 Microwave Oven Logo
63 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Jim Thurston
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
