My usb key says it doesnt have enough space yet it is empty of files
My verbatim usb key says that it can't hold any documents on it as it has only 1mb of space available, but when opening the folder for the usb key it has no files on it? is there a way to fix this?
    Problem Solver:
  • 17 Answers
You will need to reformat it. Unplug the device, replug in a different usb port, Go to My computer, Right click the drive and select Format. Select Quick format, and try again to use the device.
Kind Regards, ACD
Posted on Mar 14, 2008
SOURCE:
Incorrect GB space free amount and space used. Doesnt change as I delete more files.
You may have hidden files on the drive. Unhide them by hitting the Alt key and going to tools
Select Folder Options
Go to "View" and select the two indicated options below and hit OK.
This will unhide what ever files you have. If you dont find the files taking up your space, just copy what ever files you need to your hard drive temporarily or another USB drive and format the disk.
Oct 19, 2012 | Western Digital 1TB My Passport Essential...
I have a Verbatim Clon 500GB external hard drive which only holds 4.65 GB; why??
Windows 7Might not be formatted correctly. Check Disc Management under Administrative tools. This will give the true size including space that has not assigned as a partition.
Aug 28, 2012 | Verbatim Computers & Internet
Verbatim 4GB USB is not letting me put any folders on it saying there is not enough space. it says there is only 6.6MB available even though the USB is empty. Don't see why that's a problem anyway...
If you are currently running windows:
open [My Computer >> locate the flash drive and right click on it >> Click Format >> Make file type NTFS (if not already) and click start.
After that is finished you should be able to copy your folder to the drive.
May 27, 2011 | Office Equipment & Supplies
I have no files on the disk but it says that I'm using space and so I can't backup -- how do I empty recycling bin?
To empty the Recycle Bin, you can right click on the Recycle Bin icon and then from the menu that pops up, choose "Empty Recycle Bin." All of the files currently held in the bin will be deleted permanently from your system.
May 13, 2010 | Verbatim SmartDisk Firelite Portable USB...
I have a Verbatim 250USB drive and have never had a problem with it until I attempted to copy some HD movie files to it from my computer's hard drive. I am attempting to copy .mkv movie files to the...
firs:
try to format your hard drive, then try again.
if you still cannot do it, do a low level format, using this tool:
http://hddguru.com/software/2006.04.12-HDD-Low-Level-Format-Tool/
if you still cannotdo it, it may be a harware problem. try to copy a big .mkv file like that from another pc, to be sure it isn't your pc's fault, if you can do it, then it's your pc, if you still cannot it's the disk.
in the firs case the troublesooting is quite difficoult but if you post your system configuration i may help.
in the second case if allso a low level format fails, then i don' think we can do something for youo... you should get assistance from the manufacturer....
hope this help,
Paolo.
May 19, 2010 | Verbatim SmartDisk Firelite Portable USB...
5.84 GB will not fit on the 8GB Store N Go
Easy Fix.. You need to reformat your USB File System to NTFS rather than FAT32 (Default). FAT32 limits the size of all downloads to 4 GB. NTFS has no upper limit so you could download an 8GB file, if you wanted..... FAT32 is the default on the unit you have. Easy fix.... right click on your drive, click 'format', 'file system' change to NTFS and click 'start'. That's it ! ! ! !
Nov 19, 2009 | Verbatim Electronics - Others
I have verbatim external drive usb 2.0. It used to function properly...but now Windows(xp) doesn't open it at all and properties reflect only 2.95MB space. Its a password protected USB and doesnt even show...
update drivers. other people are having trouble with their verbatim products not registering. If you have any more problems, like finding drivers, e-mail verbatim directly with your problem.
Sep 15, 2009 | Verbatim External, USB 2.0, 750GB...
Verbatim flash drive incorrectly reporting insufficient space
Some flashdrives have a locking device on it so you cant add or delete check to make sure that is not locked
Jun 13, 2009 | Electronics - Others
RE: Files messed up on flash drive
That means the file has been messed up during transport of some time when it was not being used if you smart enough to have a back up file or two copies of that file just copy and paste or save twice again.
Sep 13, 2007 | Verbatim CORPORATION 94933 USB 2.1GB...
Open Questions:
Computers & Internet Logo
69 people viewed this question
Ekse
Alun Cox
