Question about Samsung YP-U3 MP3 Player
Mp3 gone dead
Well, my sister dropped so many times that it wont turn on. i've tryed installing the philips device manager, but it can't detect the mp3.i know for sure that its connected to the usb drive connecting it to the computer.it charges....i think,but it is hasn't even turned on the slightists bit.i've tryed reseting it so many times i have lost count
  • 3 Answers
Buy a new one
Posted on Aug 18, 2008
My Philips go gear SA2515/97not recognized by the PC, not detected by SA25X5 Device manager and on the LCD display, it only says "Press OK to disconnect" , not turning on, only flashing the...
Hi bysvraju...
Try this method...
Go to Device Manager
To get to Device Manager you will:
Right click on My Computer>Properties>click the Hardware Tab>Device Manager.
After you are in Device Manager look for your MP3 player or Unit.
Here you should see no "Yellow" exclamation points.
If you do they they are telling you that you have a device conflict.
If you currnetly have your unit plugged in, you may notice the "unknown device" which would be your Player or Unit.
If you unit has an exclamation point by it, then you will need to click on it and delete it.
After you remove all devices with conflicts then click on refresh and search again for your MP3 player/Device.
The computer should install your device this time and solve your problem with connection of the MP3 player/Device.
Please take time to rate me thumbs up.
Sep 15, 2011 | Philips SA2515/37 MP3 Player
My GO gear Mp3 player wont be detected on any computer. even if you install the hardware, it wont still detect.
if your player don't detect . also don't detect with Philips Device Manager
try to download this driver for it usb 2.0 ADFU Driver .
i worked with 7 and in system device manager show "uknown usb device" but in XP show this "usb 2.0 ADFU Drive" and also the Xp itself install it . if your windows dosent have this so go on to download it manualy . then use philips device manager to repair it . i do it myself and it worked
Dec 13, 2010 | Philips GOGEAR SA6045 MP3 Player
HI, I am am having problems with my Philips GoGear Flash audio player SA2625. When ever I turn it ON, all it says is "Philips" then it turns off. When ever I plug it in it says "OK to disconnect", the...
I found a restore fix by pressing the return button while plugging into a PC with philips device manager open - the MP3 player then was restored to factory defaults :-)
Jun 16, 2010 | Philips GoGear SA2625/37 MP3 Player
Phillips go gear 8gb
Reset the player by inserting a paerlcip into the reset hole. If that fails, go to Philips' website and upgrade the firmware on your player to solve the freezing issue permanently. Actually, don't go to Philips website - run the Philips Device Manager and select Update. If the device manager won't recognize the player, unplug the GoGear, hold in either the shuffle button or volume + and reconnect it to the computer until a Found New Hardware Wizard window pops up.
-Tha Mp3 Doctor
Dec 29, 2008 | Philips GoGear SA5285/37 Digital Media...
My Phillps mp3 wont turn on or let meh download more songs. Wuts wrong with it? Plz help.
Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Sep 19, 2008 | Philips SA4020 MP3 Player
-Tha Mp3 Doctor
-Tha Mp3 Doctor
Sep 02, 2008 | Philips GoGear HDD1830 MP3 Player
When i start my philips mp3 player i try to access my music and it freezes. also the the title of the tracks shows up as boxes. i think there maybe startup files on the mp3 player missing or tampered with
Sounds like the memory has corrupted.
Install and run the Philips Device Manager from the product CD.
Select repair/restore option and follow the on-screen prompts.
This will format the player and re-load the system files.
If this doesn't help, please post your model number so I can asist further.
May 27, 2008 | Philips Audio Players & Recorders
It won't turn on
Could be corrupt firmware.
Install and run the Philips Device Manager form the product CD.
Press and hold the [PLAY/PAUSE] button on the player whilst connecting to the PC.
Continue to hold until Device Manager say to release, then follow the on-screen prompts.
This will format the player, deleting all tracks, and re-load the firmware.
When the process has finished, switch on the player, and it should go through the initialisation process, then switch off.
Switch on again, and the player should show "Updating", then go into the main menu.
If the player still won't switch on, you have probably damaged the player, and there's not much else to try.
This problem is a known fault, so you may be able to change the player if it is still under warranty. Could just be coincidence when you dropped it.
If not under warranty, check out E-Bay. cheapest_electrical sell them very cheaply, with 12 months warranty.
May 06, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips Device Manager - MP3 - SA1125
I had this problem twice, the player keeps displaying some pixels spreaded randomly on the screen when I press the play/pause button or when its connected to the pc, while Philips Device Manager keeps displaying the error:
"Buffer overrun detected! Program: ...hilips\SA21xx\Device Manage.exe A buffer overrun has been detected wich has corrupted the program's internal state. The program cannot safely continue execution and must now be terminated." (I have an old SA2115/02 device)
When I contacted Philips about this problem, they said to bring the device to them but it was out of service.
So I tried lots of repair/recvery programs and got to a point where I couldn't even format the player cause of the write-protected error. I was about to trash it when I tried this last method :
-I used an USB cable extender so I won't brake my PC's USB port
-I started Philips Device Manager
-I began pluggin/unpluggin the device repeatedly while Philips Device Manager was loading
-after the program loaded and recognized the player without giving me the error above, I left the device plugged
-I used the repair option, took a deep breath and waited until the operation was finished and voila!
Now I don't know if it will also work for you because I tried lots of rude methods wich I don't remember the exact order, like the first time I've repaired it, but it's worth trying.
Mar 17, 2008 | Philips HDD1630 MP3 Player
Mp3 player
Try uninstalling the version of the software that came with the CD and re-installing the new version on the Philips website (just added).
-Tha Mp3 Doctor
Jan 20, 2008 | Philips GoGear SA178 MP3 Player
Samsung YP-U3 MP3 Player Logo
52 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
