Question about Acer Aspire 3680 Laptop
Replacing cd-rom drive
Acer is sending me a warranty replacement cd drive. After removing all the screws I can find to remove bottom casing to access cd unit, the cover is free everywhere except in the center rear where the battery slides into place. I can't find any other screws and am afraid of pulling too hard. There is a little round moulded notch that I thought perhaps is a release point somehow but can't seem to make it release. How do I finish taking the cover off so I can replace the cd-rom unit? Thanks for any assistance.
    Scholar:
  • 105 Answers
It is very likely the remaining securing screw is under the keyboard.
Posted on Mar 14, 2008
Removing cd rom
The optical (CD) drive on your Acer laptop connects to the side of the device and is accessed via the underside of the computer.
If you are having problems with the optical drive on your laptop you should address it as soon as possible, and one thing you may need to do is remove it.
The good news is that even if you aren't particularly tech savvy, you'll find that the process of removing and replacing your optical drive is relatively easy.
Turn your Acer off and remove any power cables that may be attached to the side of the unit. Turn your Acer upside down.
Slide the battery out of its compartment on the underside of the computer.
Locate the circular optical drive retaining screw on the underside of your laptop.
It is located just above the square WiFi compartment in the middle of the computer.
Use your Phillips screwdriver to remove the screw and set it aside.
Grip the optical drive by its edge on the side of the computer and gently pull to remove it from the computer.
Slide a new optical drive into the computer, making sure the disk opening is facing out of the laptop.
Replace the optical drive screw.
http://doube.org/aspireoptical
http://www.insidemylaptop.com/replace-hard-drive-dvd-drive-acer-aspire-3610-laptop/
Replace the CD Drive on an Acer Aspire 5000
The CD drive of the Acer Aspire 5000 is designed like most other laptop optical drives.
The CD drive is on the right-hand side of the computer and is attached with screws from the back of the case.
All you need to complete the task is a screwdriver.
To avoid electric shock or damage to the laptop, always ground your tools by touching them against a metal object like a table leg before using them on the computer.
Turn the Acer Aspire 5000 laptop off.
Unplug the power cord from the electrical outlet. Remove the power cord from the power supply in the side of the laptop.
Flip the laptop over so you are looking at the bottom of the case.
Slide the battery pack off the top of the case.
You'll see the CD drive on the left-hand side of the laptop when you are looking at the bottom of the case.
Unfasten the screws that are holding the CD drive onto the laptop with a screwdriver. Slide the drive out of the case.
Slide the new CD drive into the case and secure it with the screws.
Place the battery pack in the laptop and turn the computer back over so it is sitting on its base. Plug the power cord into the power supply in the side of the laptop.
Plug the other end of the cord into the electrical outlet.
http://www.batterystyle.com/acer-aspire-5000-drive-p-307461.html
Sep 06, 2013 | Acer Aspire 5610-4648 Notebook
How do i change the cd rom on a hp pavilion laptop
Hello Turn off your Pavilion laptop and remove the AC power cord. Slide the battery release lever to the unlocked position and remove the battery.
Read more: How to Remove a CD-ROM Drive From a HP Pavilion Notebook N5425 ' eHow.com http://www.ehow.com/how_6138972_remove-hp-pavilion-notebook-n5425.html#ixzz2BTQ7dMMi
Remove the small Phillips head screw on the bottom of the laptop. This screw is used to secure the optical drive to the laptop case.Grasp the front of the CD-ROM drive and carefully slide it out of the bay. Slide the replacement drive into the bay and secure it with the Phillips head screw. Then replace the battery, connect the AC power and turn the laptop on.
Good luck
Nov 03, 2012 | Computers & Internet
How to remove cd/dvd drive on a acer aspire 5003WMLi
Turn the laptop over, on the bottom you will find a screw about 5-6 inches in from the cd-rom drive. The screw will have a little symbol of a CD next to it. If you remove this screw the cd-rom drive should slide right out. Be sure to do this with the laptop turned off, unplugged and with the battery removed.
Sep 19, 2012 | Acer Aspire 5002 Wlci Zl5 - 5000 Series...
How to take out a sticker stuck inside the burner?
Open the computer case, disconnect the power and data cables from the drive and remove it from the case. How you do this will depend on the type of case your computer has. There may be screws on both sides of the drive, one side only, or no screws in a tool-less case where there will be some kind of release tabs so you can slide the drive out.
Once you have the drive out of the computer, there are four screws in the bottom that hold the drive together. Take those out, take off the top cover and you'll be able to get at whatever's stuck in the drive. Just be careful if the sticker is near the laser lens. If you poke too hard the pickup assembly can be damaged and you'll be replacing the drive.
In fact, with new drives only around $30, it might be easier and just as cost-effective simply to replace it right off.
Mar 10, 2010 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
I want to replace my acer laptop Cd rom , from where can i remove old one
Here are the steps on how to remove your old CD-ROM so you can replece it.
Remove all power sources from the laptop. This should include not only the AC power adapter but also the battery.
Locate and remove the screw that locks the CD-ROM in place. Some laptops may have two screws that serve this function. In addition, many will also have a sliding switch that needs to be moved in order to remove the drive.
Slide the drive out gently. It should easily come out and does not require excessive force.
Replace the defective CD-ROM drive by sliding the new one gently into place in the laptop bay, the same way the old one came out. Again, excessive force should not be applied. The drive will only fit into the bay one way.
Secure the CD-ROM drive in place by replacing the screws that were removed previously. Reconnect all power supplies to the laptop and power it on. If the replacement CD-ROM is the exact same make and model as the previous one, the system will probably recognize it right away. If it is a different make or model it will prompt you to supply the appropriate software and drivers to optimize the use of the new CD-ROM drive.
Jan 22, 2010 | Acer (91.49C37.001) CD-ROM Drive
Need to install second cd driver in desktop computer
It would be much simpler to remove your current CD-ROM drive, and install a CD/DVD-reader-writer combination drive.
1. Turn the computer off, and disconnect the AC power-cord.
2. Remove the side-panels from the case.
3. Disconnect the "power" and "data" cables from the back of the CD-ROM.
4. Remove the screws holding the current CD-ROM in position.
5. Slide the CD-ROM out the "front" of the case.
6. Slide the new device into place, until the face is "flush" with the front of the case.
7. Screw the device into position.
8. Connect the data and power cables.
9. Reconnect the AC power.
Windows will "find new hardware", and will adapt itself.
Dec 10, 2009 | Acer Computers & Internet
Acer 5100 laptop dvd/cd player is broken,how do I remove it?
Remove the access cover on the bottom of the case that houses the heatsink, wireless card and RAM memory. No components have to be removed to remove the cd drive. Now look at the cd bezel and then back toward where the RAM memory is installed in thier slots. There is a screw marked by a circle with what looks like a wedge taken out. This is the holding screw for the cd player. Once you remove this screw, there is agap next to the screw hole that you can stick the screwdriver in and push the cd player part way out of the case. Once you do that, grip the front of the drive and pull it free of the case. Refer to page 60 of the service manual I have included the link for below. Make sure you have a PDF file reader like Adobe or Fox-It Reader.
http://tim.id.au/laptops/acer/aspire%205110%205100%203100.pdf
Oct 28, 2009 | Acer Aspire 5100 Notebook
How do i remove the DVD cdrom from an acer 503
On te back side of your laptop you will see a sign on a screw like cd , unscrew this screw and pull the cddrive.
Sep 01, 2009 | Acer TravelMate 2300 Notebook
Removal cd disk drive
WRONGGGGGGGGGGGG!!!!!!! I N this case you don't have to work from the bottom of the laptop , what you need is remove the keyboard and underneath of it you 'll see a single screw , thats the one that holds the drive once removed you can slide the drive and replace it .Don't forget to remove the 3 screws in the back of the laptop , one on each side and the last one is like 3 inches from the right corner.
Sep 19, 2008 | Acer Computers & Internet
Replace CD-Rom Drive
solution: open front blue magnetic case door, look on either side of the power button, there are finger holes in the other blue cover.
lift out from bottom to top. this cover comes off, not the whole
case. inside find tabs next to cd drive, squeeze and pull out. note: the side sliders were they come out, they will come off the
cd drive when removed. it is easier to replace the top drive by removing the bottom drive, put in the top half way, then put bottom back in half way and slide them in together.
voice of experience. hope this helps
Jan 12, 2008 | Compaq Presario 5000 PC Desktop
Acer Aspire 3680 Laptop Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
