Router problems I need a driver for a wisdom guru 2 port combo router. adsl2/2+
  • r001 Jul 04, 2008
    hii my router problems not riset no configra
    Problem Solver:
  • 8 Answers
May i have the model number of the exact device that you need driver for?
Posted on Mar 15, 2008
How do i enable ports 25 SMTP and 53 DNS on a Netgear ADSL2
It depends on your router. First you need to login your router.
Then you need to find the port forwarding field. There you tell which ports to forward. In your case its 25 with TCP transport and TCP and UDP for port 53.
For each port you need to tell the router where to send the packages to. So you need to know the IP of the computer you want to get the packages forwarded to.
Some more detailed instruction which depend on the Router version (ADSL2 is not a specific version!) can be found here: http://kbserver.netgear.com/kb_web_files/n101145.asp or http://kb.netgear.com/app/home
Mar 14, 2011 | Computers & Internet
Driver
not sure why you will need USB drivers for your adsl2+ modem/ wireless router and 4 port LAN switch. It would help you had provided the model number.
The device uses a LAN ethernet port to connect to the computer. You will need atleast one computer to be on the LAN port for setting it up. Once setup is complete you can use wireless connection for every computer.
The user manual & drivers or the DSL-2740B which appears similar to your product description
http://www.dlink.com.au/tech/Download/download.aspx?product=DSL-2740B
Not sure if you need these. Your computers will need LAN or wireless drivers to connect to this DLINK modem/ router.
Good luck
Dec 25, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Need drivers for DSL-G624t wireless router
If you're connecting to the router by ethernet cable or wirelessly, you dont need drivers unless you mean the drivers for the ethernet adapter and/or wireless adpater in your PC.
If this is what you're after, your PC's manufacturer's website is the best place to look if you dont have them on CD/DVD.
If you're connecting to the router by USB port, then the D-Link webiste should have the drivers for downloading.
Sep 13, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
GLB-502T Ethernet Port doesn't work, USB does
check whether the driver for LAN is properly installed...if not install it using your driver cd...it might your solution..check it out
Jul 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I want driver for GLB-802c
Not available at dlink for some reason, contact them directly and ask for drivers here
http://www.dlink.co.in/support/productsupport.aspx
Jun 22, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Trying ti install my dsl-2640b wireless g adsl2+modem router
If you have plugged the ethernet cable directly into the motherboard, make sure the onboard lan is enabled in the bios, if you have plugged into a pci nic adapter you will have to install a driver for it, winxp should have the driver for your adapter other than that I cannot help any further.
best of luck
Ray Winter
Dec 30, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Can't install DWL-g122 on my imac intel core 2 duo 10.5.5
If you're installing in your Imac You need a B1 or C1 revision for that USB dongle to work.
Oct 27, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
