Question about Apex Digital PF2720 27" TV
Password for apex tv
An unknown person entered a password into the set and i have no way of knowing what they entered. is there a way to reset the password or return to the origional default.
  • 2,337 Answers
Try factory default password 1225.
You can also download the user manual from here.
Posted on Mar 14, 2008
    Guru:
  • 1,894 Answers
For this you will have to reset the unit
  • dewan nafees ahmed Mar 14, 2008
    Try pressing the F button and the mute button at the same time on your remote control.
    try master pass 3308
    Childlock
    The CHlLDLOCK function prevents chiIdren from watching TV.
    HoId down the F button and then press the MUTE button until the symboI ? ?
    appears on the screen, and the TV enters the CHlLDLOCK mode.
    Except for the symboI? ?, the screen becomes blue back and mutes when
    you press the buton to turn the TV off, then turn the TV on after setting the
    CHILDLOCK function. To unlock the TV, hoId down the F button and then press
    the MUTE button again.
    Note:
    The CHlLDLOCK can be set or cancelIed only by the remote controI. After
    setting CHlLDLOCK, secure the remote control in a safe place
SOURCE:
I have a RCR universal remote. It turn the tv on/off but the red lock remains on my apex 2011s. What do I do?
The Apex prompts you to
enter a 4-digit code when you set up parental controls. You can block programs
according to their MPAA ratings or their content designations, such as V for
violence or S for sexual situations. You can override parental
controls on most Apex models by simultaneously pressing the F and mute buttons
on the remote control. If you own Apex models GT2011J or GT2011S, hold the
remote\'s display button for ten seconds. The red key will vanish and the V-chip
will unblock your program.
Apex\'s default parental
lock control code is 6688, so if you haven\'t set a new code, entering 6688 will
remove the red key and unblock your program. If you\'ve set a new password and
forgotten it, entering 3308 will reset the code and unblock your program. For more, http://electronicshelponline.blogspot.com/
Jul 01, 2013 | Televison & Video
Apex AT2702 27" color television under scan
well most of the modern tv today doesnt have vertical hold anymore.
this symptom is caused by a trouble in the IC integrated circuit or the vertical oscillator circuit. let the service guy do the job if u dont know anything about this. good luck!
Sep 18, 2008 | Televison & Video
PF2020 RESET CHILD LOCK
Turn your television and Apex DT250 receiver on.
Push the "Menu" button on the Apex DT250 remote control.
Press the remote's "Up" and "Down" buttons to scroll through the menu options. Stop when "Parental Controls" is highlighted. Press the "Right" button to select this option.
Enter your four-digit password. If you have not set your password, use the default code of "0000."
Use the "Up" and "Down" arrows to change or set the parental control movie ratings. You can select from "None," "G," "PG," "PG-13," "R," "NC-17" and "X." Once your setting is highlighted, press the "Right" button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
Oct 31, 2012 | Apex Digital PF2020 20" TV
Need to know how to remove the red key on tv and code
When a red key appears in the lower left corner of your Apex television screen, the set's V-chip is engaged, preventing you from watching restricted content. You can override parental controls and reset your television's pass code with your remote.
Parental Lock
  1. The Apex prompts you to enter a 4-digit code when you set up parental controls. You can block programs according to their MPAA ratings or their content designations, such as V for violence or S for ****** situations.
Disabling the Lock
  1. You can override parental controls on most Apex models by simultaneously pressing the F and mute buttons on the remote control. If you own Apex models GT2011J or GT2011S, hold the remote's display button for ten seconds. The red key will vanish and the V-chip will unblock your program.
Override Codes Apex's default parental lock control code is 6688, so if you haven't set a new code, entering 6688 will remove the red key and unblock your program. If you've set a new password and forgotten it, entering 3308 will reset the code and unblock your program.
Sep 25, 2012 | Apex Digital Televison & Video
Apex tv locked
If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time.
If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
Let me know if this helps.
May 24, 2009 | Apex Digital GT2015DV 20 in. TV/DVD Combo
How to unlock my Apex TV #at2002 with only KEY shown in the corne
Press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired. • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels..
Please rate this Fixya solution
Jan 20, 2009 | Apex Digital PF2020 20" TV
Neoware unit has a password but nobody knows what it is...
NeoLinux Password Reset
1) Restart the NeoLinux appliance.
2) On power on hold down the Shift key.
3) From the LILO Boot Menu type vga single and press Enter.
4) When you see "Starting up...open: No such device" press Alt/F2.
5) From bash# type passwd and press Enter.
6) Enter the new appliance password and press Enter.
7) Retype the new password and press Enter.
8) Type /sbin/reboot and press Enter.
Dec 17, 2008 | Neoware EON E100 64/128MB NEOLINUX...
Resetting the parental control password?
try master pass 3308 Childlock The CHlLDLOCK function prevents chiIdren from watching TV. HoId down the F button and then press the MUTE button until the symboI ? ? appears on the screen, and the TV enters the CHlLDLOCK mode. Except for the symboI? ?, the screen becomes blue back and mutes when you press the buton to turn the TV off, then turn the TV on after setting the CHILDLOCK function. To unlock the TV, hoId down the F button and then press the MUTE button again. Note: The CHlLDLOCK can be set or cancelIed only by the remote controI. After setting CHlLDLOCK, secure the remote control in a safe place
Aug 14, 2007 | Apex Digital AT1314DV 13 in. TV/DVD Combo
Apex Digital PF2720 27" TV Logo
182 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Ekse
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
