Question about Kenmore 24032\24036 Top Load Washer
Washer fills/agitates and stops prior to draining
No past problems with the washer
Suddenly washer won't complete the wash cycle.
in any type cycle, the timer stops at the drain portion of the cycle prior to pumping out the water.
Pump works while spinning
Advancing the timer to spin portion of the cycle will pump water out as it spins.
  • Anonymous Mar 21, 2014
    Washer works properly on agitate cycle on spin it spins at 50% and agitates at same time. Brake does work well to stop it
  • Anonymous Mar 29, 2014
    My McClary washer misses a couple cycles. It goes from filling with water to spinning without agitating or draining first. I tried a different (used) timer with no luck.
  • 30 Answers
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Posted on Mar 14, 2008
  • Ron Henderson
    Ron Henderson Mar 07, 2014
    The timer is a computer on this unit---$500 plus. It does not give an error message so I think it might be a sensor issue
For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer...
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 07, 2011 | Washing Machines
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore Model 22722 will not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | Washing Machines
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
WASHER FILLED WITH WATER AND STOPPED WORKING COMPLETELY
if you hear a motot running the coupling between the motor and transmission has disinagrated.
Dec 26, 2008 | Maytag MAT12CS Top Load Washer
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    98702 Washer Drain/Spin Dead.
    My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
    Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
    Washer clothes
    Does the washer fill normally and just stop? Or, does the washer fill, go through a complete cycle, and just won't drain? There could be a couple of problems that cause a no drain issue. 1. FILL NORMALLY & STOPS, WILL NOT SPIN - This is usually a bad lid switch. If you open and close the lid, you should hear a "click", indicating the switch is working. 2. FILL NORMALLY, AGITATES, WILL NOT DRAIN - This could be a clogged drain pump, pinched hose, clogged rain line. Also, you need to make sure timer is advancing properly. If the timer never advances, the washer will fill, but won't go into agitate or spin. Let me know if this is helpful.
    Aug 09, 2007 | Whirlpool LSR5132J Top Load Washer
    Kenmore 24032\24036 Top Load Washer Logo
    604 people viewed this question
    Sal De GO PATS
    fordexpert
    Ed Mac
