Question about Epson Stylus C84 InkJet Printer
Ink carriage jammed
Printer was working fine. Yellow ink ran out. During replacement of cartridge, process seemed to stop before the ink charging. Carriage stuck where it can't be opened (on the right). Two lights flashing. Message says turn off, clear paper jam and turn back on. No paper jam seen. Can't get carriage to move into open so I can check that. Tried turning off and back on several times. Tried unplugging and replugging. No luck. Please advise.
Well, I'm not too happy that the only response I got was solicitation for the Premium Assistance Plan.
Figuring that the printer had pretty much died, I allowed my husband, Mr. Fix-It, to give it a try. He simply pushed up on the front end of the ink carrier and slid it into the opening. This allowed him to get at the cartridges and push gently down on the new cartridge I'd installed. It had not been seated completely. Works fine now.
I'd be curious to know why I found a huge ink spot under the printer. It has probably been there for quite some time, as I usually just dust around things rather than move them.
Posted on Mar 15, 2008
Paper keeps getting jammed
There is a rod in the carriage of your printer that is meant for holding the cartridges. It keeps on moving and spreading the ink on the paper throughout the process of printing. If this rod is jammed because of any reason, you face a carriage jam. As mentioned above, the main function of the carriage rod is to spread the ink, so obviously any clog or ink failure will lead to a poor print quality. If rollers of your printer are leaving marks on the document, then you need to clean them with a wet cleaning pad. Never use the chemical cleaners such as benzine, thinner, or alcohol to clean the rollers. In extreme cases you might need to replace an old cartridge of your Lexmark Printer with a newer one. Once you get a new cartridge for your printer, you need to be very careful while replacing it, otherwise it might cause a carriage jam.
Nov 23, 2010 | Lexmark Office Equipment & Supplies
How to free carriage jam on lexmark X4550
There is a rod in the carriage of your printer that is meant for holding the cartridges. It keeps on moving and spreading the ink on the paper throughout the process of printing. If this rod is jammed because of any reason, you face a carriage jam. As mentioned above, the main function of the carriage rod is to spread the ink, so obviously any clog or ink failure will lead to a poor print quality. If rollers of your printer are leaving marks on the document, then you need to clean them with a wet cleaning pad. Never use the chemical cleaners such as benzine, thinner, or alcohol to clean the rollers. In extreme cases you might need to replace an old cartridge of your Lexmark Printer with a newer one. Once you get a new cartridge for your printer, you need to be very careful while replacing it, otherwise it might cause a carriage jam.fix Lexmark Carriage Jam .
Sep 18, 2010 | Lexmark Office Equipment & Supplies
Printer stopped printing; amber teardrop is flashing; no paper jam; cartridges should not be empty. Shouldn't there be a notice of low ink before it just stops printing? Or, the printed pages be faint? All...
The top access door on the printer might be open, or there might be something wrong with the print cartridge.
  1. Check to make sure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door opens, the print carriage moves so the yellow arrow on top of the print carriage points to a drawing of a cartridge inside the cover. Each drawing describes a symptom.
Jan 09, 2010 | HP DeskJet 5550 InkJet Printer
Ink Cartridge problem? (HP designjet 5500 ps 42")
you are correct, this is usually caused by the contacts going bad on the carriage assembly. try cleaning the contacts, if this does not help, than you need to replace the carriage assembly. hope this helped.
Jun 17, 2009 | HP DesignJet 5500PS InkJet Printer
Carriage jam on HP Officejet J5780 All-in-One
We have several of these in our company and the most common "Carriage Jam" cause is a glob of black ink in the bay on the right side. Once glob is removed, and "Carriage Jam" message appears again, press OK, and it prints fine from then on. Today the black ink glob was flat on top. Watch out for leaky cartridges, as the design of the particular HP device provides a nice catch pan for the tri-color ink cartridge, but not for the black one, so a leaky cartridge, besides being expensive and wasteful, can goop up the bay causing the carriage jam error message to try to get you to take a closer look.
Jan 09, 2009 | HP Officejet J5780 All-In-One InkJet...
Epson Stylus Photo R320 InkJet Printer
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 21, 2008 | Epson Stylus Photo R320 InkJet Printer
Printer shows Carriage Jam, but I can't find it.
many reason coses carriage jam bout i think that the in coder belt faulty
Mar 23, 2008 | HP Photosmart C4150 All-In-One InkJet...
Ink and paper lights flashing red and I cannot print
No body wants to take it to repairs, we all hate spending money if it can be avoideded. Do't fret. First, i would bet you have a paper jam that you have missed. This would stop the carriage and head cleaning. Open up the cover as if replacing ink. Get a torch and really thoroughly check for tiny paper jams or ujo's(unidentified jamming objects)check where paper goes too. Now close cover turn off, unplug, all cables, replug, turn on, try printing now. Post back if no good. Cheers lilacgerry
Aug 27, 2007 | Epson Stylus C84 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
83 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
