remove steering column plastic set seat all the way back remove linkage indicator line(little wire cord to stering column on a hook) under dash remove the molding from stereo to driver door remove dash cluster look for cluster lights replace...reverse process...
For 1993 Ford Taurus 3.0L FI 6cyl the Flasher is located in front seating area, driver side, under dash, driver side of steering column, mounted behind instrument panel .
Usually if the blower motor resistor is bad, the fan will still work on "HIGH". The resistor is usually only a few inches away from the blower motor, look under the dash on the passenger side.
you have to remove the dash. i suggest you go to an auto parts store and buy an after market tech manual. by the way everything under that smooth dash is sharp and give yourself a good weekend to complete. GOOD LUCK.
this usually happens when you are on a tilt with the car, ive got a 93 taurus gl 3.0 and whenever im on a slant, it is extremely hard to shift in or out of park, you really have to give it some muscle and it will go, its just the way the car is i dont think there is a legitimate fix for it.
