Question about Eureka 2961AVZ Bagless Upright Vacuum
Euerka Smart Boss upright
The life of a belt on my vacum cleaner is about 30 minutes. It becomes frayed on the outside part and after about 30 minute of use, the brush-bar doesn't turn because the belt has increased in diamter....there is no tenion by the belt to m ake the braush bar rotate.
It appear that the pulleys may be mis-aligned.
How do I fx this problem?
We have enoyed our Smart boss emmenely until this started happening a few months ao.
Is it fixable? If so, what is a guesstimate on the repair cost?
...and how much are your belts and bags? I will buy tthen from you if you can help me fix my problem.
thanks
tom
its a Eyreka Smart Boss model # 4870
  • 30 Answers
Price of Belt: $ 7.49 from www3.sears.com
Part No. 61110A
Price of Bag: $7.99 for a pack of 3.
Part No. 61115A or Eureka Bag Type RR
Estimated Repair Cost: $75-90 pending parts and labor rates
The likely possibility is that the belt was installed wrong. Without seeing the unit myself, I cannot say if the pulleys are mis-aligned. I will get back to you if I find any new information.
Posted on Mar 14, 2008
6ya staff
SOURCE:
Replace belt on DC 27 Dyson vacum cleaner
Upright /undo screws holding the rotating brush,and then
remove the brush and cleaner refit using new belt.
Jul 29, 2014 | Dyson DC27 Total Clean Vacuum Cleaner
I have a windtunnel vacum cleaner. When I
It might be a slipping rubber belt, is the brush roller moving when you look underneath? If it's a self propelled machine there might be another slipping belt. Friction from fast rubbing rubber can smell like it is burning.
Jan 16, 2010 | Hoover Company Wind Tunnel U53019 Upright...
I have a Eureka 'The Boss Smart Vac'. The beater
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Eureka The Boss Smart Replacement Belts
Owner's Guide (3,666K download)
Dec 09, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
My Eureka Boss vacuum belt keeps breaking
I have been searching the machine for something which could be rubbing against the belt to cause it to fray and break as often as it does. So far, I haven't found anything. I have heard that the belts, called ribbon belts, are terrible! I find that the belts break faster when I use the hose. I haven't found a way to make a belt last longer.
Jul 03, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
How to replace a belt on a Kirby G4 vacum
Here's how you replace the belt on all Kirby Generation Upright Vacuum Cleaners;
Jan 25, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
How do i open my cleaner to put a belt on
Thank you for your fast reply, I took off the screws on the lid and replaced the belt with no problem
Mar 14, 2008 | Fantom Vacums CW600 Upright Vacuum
Looking for Eureka belt 70646A for a Eureka The Boss upright
I just replaced the belt on my Eureka The Boss Smart Vac (Model 4870D). I purchased a namebrand Eureka R belt from a local vendor. I did my best to follow the instructions printed on the bottom of the machine. I turned on the vacuum cleaner and the belt brush was spinning! I dropped it into vacuuming floor mode and the belt wouldn't spin no matter what level I put it on.
I called the manufacturer (1-800-282-2886) and spoke with a very nice woman on the phone. While I was speaking with her I noticed that a silver screw was lodged within the "brush roll control" yellow selector switch. With some shaking it became dislodged and I was able to put the "brush roll control" into the hard floors setting and turn the "carpet height adjustment" all the way to the right, so that it was facing the word "low." I then followed the instructions for replacing the belt again.. (1) remove base plate (2) remove brush roll (3) place new belt around motor shaft and then around brush roll (4) insert left side of brush roll before right side (5) rotate brush roll to be sure belt is centered (6) replace base plate, making sure to insert under 4 little tabs before securing with screws.
It appears that it is very important that the carpet height and brush control adjustment are set to their highest point possible (hardwood setting) in order to get the brush to roll in a carpet setting.
"R" is the correct belt for the 4870 and should be correct for all other 4800 models.
Thank you for posting your problem to this website. If I hadn't seen that others were having trouble, I would have just given up. I hope this long post helps someone that was in my situation.
Mar 08, 2008 | Vacuums
Belt broke
The belt number is 60957, There should be some screws that you remove from the bottom and the whole bottom nozzle will come apart, then you can change the belt.
Feb 27, 2008 | Eureka Boss SuperLite Bagless Upright...
Eureka the Boss bagless
Sounds like you have a clog somewhere. Check the filter inside the dust compartment, if is very dirty it won't allow ait to flow thru, Part #62132, DCF-H filter. Check the hose, take it off if you can and drop something in it to see if it comes out the other end, if it doesn't, then the hose is clogged. Check bown by the brush roll, the inlet may be plugged. Also if the belt is more then say 6 months old, you may want to replace it, I am sure it is strertched, part #61120B, extended life belt.
Jan 23, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Kirby G6 drive mode
look under the vacume cleaner and take off the cover make, shure the belt is where it needs to be, you should have a setting on the vacume cleaner that gives you an addjustment for the carpet your on, raze it up.
Nov 26, 2007 | Kirby G6 Bagged Upright Vacuum
Eureka 2961AVZ Bagless Upright Vacuum Logo
90 people viewed this question
Top Eureka Vacuums Experts
Alan Matzke
Alan Matzke
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
