Question about Acer AL1916W 19" LCD Monitor
Monitor too bright
The white balance on my monitor is off. Everything looks over exposed. Blue is light blue, red borders pink, yellow and gray are near invisible. I have messed with the contrast, the brightness, the gamma, but nothing seems to work.
  • tmg019 Mar 14, 2008
    I just hooked the monitor up to another computer and it worked fine, Any ideas on why my computer would change the settings as such?
  • 55 Answers
Your video card (or driver) is probably to blame.
Try hooking a new monitor up to the computer to test this.
If so, try the advanced settings in control panel. Many cards give you the ability to manually alter the picture.
If that doesn't fix it, replace the card.
Posted on Mar 15, 2008
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
Wiring diagram for the door of a 95 ford explorer
Windows Up LF=Red/Yellow, RF=White/Yellow, LR=Gray/Orange, RR=Red/Black
Windows Down LF=Tan/Blue, RF=Tan/Blue, LR=Yellow/Blue, RR=Yellow/Black
Door Trigger Black/Light Blue Driver's Kick Panel
Door Lock Pink/Yellow (-) Driver's Kick Panel
Door Unlock Pink/Green (-) W/o Keyless Reverse Polarity
There are no GPS wires in the door of that vehicle.
Apr 13, 2011 | GPS
Radio was removed from my 91 Seville and replaced with aftermarket CD player radio. I would like to use this radio in my shop. I have 12 DC supply and speakers and antenna. Note: There is no place to plug...
This should be the wire combination for your car: nstant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Front Speakers
Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Speakers continued
Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Apr 13, 2011 | Car Audio & Video
I need speaker wire color codes from in dash the colors i have are blue and white gray black tan green and black brown and green white and pink blue and pinik
This should be what you need
Constant 12v+ Wire: Green/Violet
Switched 12v+ Wire: Yellow/Black
Ground Wire: Black/Light Green
Illumination Wire: Light Blue/Red
Antenna Trigger: Orange/Blue
Amp Trigger Wire: Blue (If Equipped)
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Dec 26, 2010 | 1995 Ford Explorer
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
Wiring schematics for a kenwood kdc-mp145 to a 1998 ford ranger
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Sep 21, 2010 | Car Audio & Video
Hi my monitor has bright colours on it and i cant make out what im doin its really bright and hurts my eyes
Turn off the pc but leave the monitor on. unhook the monitor from the pc. the screen SHOULD run a "self test" with a moving white green red blue box. if that box is on a bare black screen and there are no bright spots or cracks or anything weird looking, then the screen itself is ok. If however, you see odd shades of blue and pink and it looks cracked or scratched or has lines in it, then it is time to replace that screen.
Nov 10, 2009 | Dell E173FP 17" LCD Monitor
I am looking for a stero wiring diagram for a 1997 ford f150
Constant 12V+ Green/Purple
Switched 12V+ Black/Pink
Ground Black/Green
Illumination Light Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 6" x 8" Doors
Left Front (+) Gray/Light Blue
Left Front (-) Tan/Yellow
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Rear Speakers 6" x 8" Rear Corners
Left Rear (+) Orange/Light Green
Left Rear (-) Light Blue/White
Right Rear (+) Orange/Red
Right Rear (-) Brown/Pink
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 03, 2009 | 1997 Ford F150 Regular Cab
What is the color code for the stereo wires in an 08 land rover l
Battery BROWN/LIGHT GREEN(+)IGNITION SWITCH HARNESS
Ignition 1 WHITE (-) IGNITION SWITCH HARNESS
Accessory 1 WHITE/PINK (-) IGNITION SWITCH HARNESS
Starter 1 WHITE/RED (-) IGNITION SWITCH HARNESS
Tachometer WHITE (-) AT IGNITION COIL
Speed Sense YELLOW/GREEN (AC) AT MODULE UNDER PASSENGER SEAT
Parking Lights ORANGE/RED (-) AT MODULE UNDER PASSENGER SEAT
Brake Lights GREEN/BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Power Unlock BLACK (-) AT MOTOR IN DRIVERS DOOR
PowerLock BLUE (-) AT MOTOR IN DRIVERS DOOR
All Door Trigger VIOLET/GRAY (-) IN HARNESS TO RIGHT OF STEERING COLUMN
Trunk Trigger VIOLET/YELLOW (-) AT MODULE UNDER PASSENGER SEAT
Hood Trigger VIOLET/WHITE (-) AT MODULE UNDER PASSENGER SEAT
Headlights-Lo BLUE (-) AT MODULE UNDER PASSENGER SEAT
Wipers-Lo PINK/LIGHT GREEN(-) AT MODULE UNDER PASSENGER SEAT
Trnk Release WHITE (-) AT TRUNK RELEASE SWITCH
Battery RED/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground TAN (-) RADIO HARNESS
Illumination GRAY/BLUE (+) RADIO HARNESS
LF Speaker (+) BLUE/WHITE
LF Speaker (-) TAN/WHITE
RF Speaker (+) RED
RF Speaker (-) TAN/RED
LR Speaker (+) RED/GREEN
LR Speaker (-) TAN/GREEN
RR Speaker (+) BLUE
RR Speaker (-) TAN/BLUE
Radio Security YES
(thats for 07 but shoe to what u need)
Aug 24, 2009 | Alpine Car Audio & Video
The 3 colors wires that hook into my pc are yellow, red & blue, but the colors on the pc are: pink, white and blue is there a color match up?
I suspect you've got the audio and video cables mixed up.
Video inputs on monitor will be yellow for video and red/blue for audio. PC end of cable will be round and connect to your video card. Or .. you should have a cable with a 15 pin mini D on both ends or a DVB cable.
The pink, white and blue connectors on your pc are audio connections for speakers/headphones.
Google is your friend
The ... Google is your friend
Jul 07, 2009 | Acer AL1951Cs 17 inch LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
183 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
