Question about Philips 32PT6441/37 32" TV
Vert deflection problem
I have a Slvania 27" tv that had no vert deflection I replaced the vert. ic and got the picture back, but now I have an over scan on the top 1/3 of the screen. Mod # STR22278 (CHIP REPLACED WAS A "LA78041") it seems like a bad cap. in the vert. cir. any quick fixes
  • Karl Berger Mar 14, 2008
    thank you Jaime867 I have been out of the repair business for about 8 years.
    Genius:
  • Philips Master
  • 1,550 Answers
Check the 50v 100mf.
Posted on Mar 20, 2008
  • 2,326 Answers
You are correct about having a dry or leaky capacitor that is causing those lines to show on the top of the screen.
Check the caps with low capacitance like 1uf, 10uf, 47uf, etc.
No quicker fix for this one until you change the capacitors.
Hope this helps.
Posted on Mar 14, 2008
Flat line on Toshiba tube tv
It could be the vertical output IC, but there may be other possible causes which include:
- bad solder contacts on deflection yoke connectors or dirty connector contacts (on the circuit board and / or on the picture tube neck)
- bad solder contacts on the vertical output IC or associated components (check for little cracks in the solder around the pins, these are so called "cold" or bad / broken contacts)
- power loss to the vertical output IC - check for any burned resistors or other components around that IC, assuming you know which one it is - see which ICs are connected to the wires going to the deflection yokes (coils) on the picture tube neck and check them well.
You need to resolder any bad contacts, clean any dirty pins on the connectors and replace any burnt out components (assuming you can still determine the type or value of the component).
Since you mentioned the problem occurs once in a while, this means that the IC probably fails when it warms up, which can often happen if there are loose connections or bad solder contacts.
Anyway, it could turn out to be a faulty IC, i just suggested a few other things that can be fixed quite easily, and possibly without the need to replace any of the components.
regards
3rq8 (Triarcuate)
Sep 09, 2009 | Toshiba 27AF41 27" TV
H line problem
I think you are describing 'no vertical deflection.' If all you have on the screen is a single horizontal line, the vertical deflection circuit (or IC) has died. Unless you have service documentation on hand, I can't give a part number to replace but this is typically not an expensive failure and if the set was OK before, it is worth having repaired.
Jul 05, 2009 | Sansui 27" TV
No vertical deflection -Horizontal line on tv
check or re solder the ic of vert. defl.
Jun 09, 2009 | Sansui 27" TV
Won,t turn on.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. check the vertical deflection IC and circuit
Nov 05, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Distorted picture
Vertical deflection circuit has a problem. Overwrapping is from a bad electrolytic capacitor. The vertical coil is the larger of the two coils around the CRTs yoke. Follow its two wires down to the connector on the main board and follow the traces there to get to a heat sinked IC with maybe a dozen pins on it. (Get the service lit if you want but this is how I do it) This is the I.C. that drives the vertical deflection. Replace all the caps in the vicinity.
Hope Ya Fix It!
Jan 23, 2008 | Philips 27PT5441 27" TV
JVC AV-27790 - single horizontal line
Since Intermitant always inspect the vert ckt for bad solder connections. If not replace the output IC they're cheap and most likely the problem If you still have lines on the top or bottom I would replace all of the electrolytic capacitors in the vert ckt also. Without much test equipment rebuilding the whole little ckt is the best way to go.
Apr 24, 2007 | JVC AV-27790 27" TV
Picture problems
you have a vert sweep colapse. Fisrt thing is to get a schematic diagram and find the vert. output Ic and the clamper diode. Measure the voltage on both sides. If its low then its apossibility that the Ic was drawing loads of current and blew out the b+ feed resistor. Look on the schematic and trace back the voltage line from the vert output ic back to the sweep power supply on the secondary of the flyback transformer. check the limiter resistor to the feed and if its open replace the cap right there the resistor as well as the vertical output Ic ALL AT ONCE!!! If you dont you will cause it to go out again in a short time. Good Luck.. If you post the vert part of the schematic I will be more then happy to assist you with this repair.
May 01, 2006 | Symphonic SC3813 13 in. TV/VCR Combo
Fixing horizontal line problem
If hitting the set gets the vert to come back then you have bad solder connections on the vert. outputs.. If it dosent then your gonna need to measure the voltage first on the vert output IC see if its about 24 or so volts If it is replace the IC. If its not the replace the vert B+ drive capacitor off the flyback xformer. If you cant find these things then your gonna need to get a schemtic from sams photo facts and post the vertical section and I will tell you or assist youin this repair. If you have had experience in soldering and curcuit work your already ahead in the repair. post the schematic.
Apr 23, 2006 | Panasonic CT-27G23 27" TV
Horizontal Line
you have a vert sweep problem. Probably the vertical output Ic the B+ going to the vert out IC or in rare cases the deflection yolk could be bad but not likly.
Thin horizontal line
Defective components in vertical deflection and output circuit inclusive of vertical output device, coupling capacitors, and yoke connectors. Passive devices such as electrolytic capacitors, coils, and resistors to/from power supply circuits. If your tele is more than 10 years old dump it and get a newer product. $100 USD is a fair price to diagnose and attempt service, depending on age and configuration. Older products may not have replacment parts available at any repair cost. There may be a pot for adjusting the vertical size. If so, it may be dirty. If you can find it, try adjusting it which could clean it. BE CAREFUL -voltages are very high.
Mar 20, 2006 | Sharp 27H-S60 TV
Philips 32PT6441/37 32" TV Logo
105 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
