Sanyo plc-xp18n need i /o board unit was hit with ball computer inputs not working video inputs work
Smd connecor (back left side) on the i/o had gotten broke lose.
Posted on Mar 24, 2008
6ya staff
SOURCE:
Sanyo plc-xe20 no picture
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Apr 13, 2013 | Sanyo PLC-XE20 (Chassis XE2000)...
Sanyo PLC-XU33 multimedia projector. Starts up, goes through countdown, stays on for a minuit after that, then bulb goes out and it goes into shutdown?????? Rob,
hi,
check the video inputs. if there is no video input then the projector will goes off after count down.
also check that is the lamp replace light lights up or not. if its lights then you have to change the lamp and then reset the lamp hour.
ok
Jan 19, 2011 | Sanyo PLC XU33 Multimedia Projector
Bright spot in center of lens, out of focus
diffuser (fly-eye) lens fried or broken and needs to be replaced.
Oct 06, 2009 | Sanyo PLC XP18N Multimedia Projector
Sanyo plc sw20a dose not work with my laptop what
you need to activate the external monitor port on your laptop.
Oct 04, 2009 | Sanyo PLC SW20A Multimedia Projector
How to get tv working on the projector
It depends, check if your TV has Video Line Out (yellow pin) jack at rear then hook it in external video source/ input of multimedia projector to watch TV picture through projector.
Thanks.
Sep 22, 2009 | Sanyo PLC XU35 Multimedia Projector
How do I change the input from the DVI-I input to the 15
I found the online manual and followed the instructions to set to "auto" input. Everything works fine.
It had been a discouraging ordeal trying to locate a new DVI cable (which came with the projector)
and as it turns out the 15 pin cable works fine. Thank you.
Rick
Jun 11, 2009 | Sanyo PLC XU50 Multimedia Projector
I have a Sanyo PLC xu38 projector broken receptical.
you should find a new db15 female connector, and install on to pcb, this required good knowledge of soldering...
Apr 20, 2009 | Sanyo PLC XU48 Multimedia Projector
Connecting my pc to a sanyo plc sw30 projector
never mind the usb, u need to only connect the video output ( yellow rcs connector ) to the vido input of the projector & it will work fine!!!
Dec 29, 2008 | Sanyo PLC-SW30 Multimedia Projector
USB Driver for PLC SU70 Sanyo Multimedia Projector
Ok kumar i did some research on your problem.
Im not real savvy with projectors, but im going to try and lead you into the right direction. Now when you connect your projector to your computer, you need to go to your input settings on your projector and put them on "auto". In your product manual it says the computer should automatically detect the projector. Now if the projector isnt displaying a proper screen then you need to to go into the manual settings and adjust the settings.
Now i want you to goto this website:
http://www.aboutprojectors.com/pdf/sanyo-plc-xu73-manual.pdf
This is the manual for your projector. Scroll down to the table of contents and click on the bold letters COMPUTER INPUT click that and read a little about the way your computer connects to the projector. I hope this helps, please let me know an update. thnx
-robert
Jan 17, 2008 | Sanyo PLC-XU73 Multimedia Projector
Open Questions:
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
