2002 Land Rover Freelander Logo
Posted on Mar 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My head gasket has just gone. the oil and water are mixing and there is a build up of thickish light pink substance in the water bottle. what is the cheapest option of repair. both water hoses were replaced within the last year. thanx
GQ-ROD
Level 3:
  • Land Rover Master 635 Answers
  • Posted on Mar 29, 2010
GQ-ROD
Land Rover Master
Level 3:
Answers
635
Questions
Helped
155934
Points
1315
There is NO CHEAP repair, oil and water will mix and look like chocolate or pink pudding then you will seize your engine when you go to start it. Don't start it and either have it towed and repaired at the cost of over $1000.00 or junk it.
My Mercedes C280 C-Class mixed water and oil
Blown head gasket, usually caused by over heating.
Replace the head gasket.
Engine oil mixing into coolant
The only place, oil and water share a gasket is the cylinder head gasket, oil and water galleries run through the engine block and head via the head gasket. The cylinder pressure will be OK, it's the oil pressure that's putting the oil in the coolant, the gasket has gone between the water and oil galleries or there is an internal crack (unlikely). A coolant pressure test should show it up.
White milky substance in oil on dipstick when i checked it
You have a blown head gasket. Water is bypassing your head gasket and has mixed with your oil. Take to your mechanic, will have to resurface cylinder head, new gaskets, water pump, timing belts.
Y is water cuming out of da water bottle when hot I put new water pump and did da head never send 4r presure test but ders no signs of oil and water mixing and my fans on all da time but heat gage go pass...
You can have a head gasket problem or head problem without oil and water mixing, it is very likely to be the gasket but if you are driving it like it, will ruin the head if it's aluminium!!
2answers
There is a white creamy substance around the oil cap what would cause this
The white creamy solution is oil mixed with water. Take out your dipstick and check for the same substance, if so, you have a blown head gasket. If not, it's just condensed water in your valve cover that mixes with the oil, witch isn't really a problem. Have a nice day!
3helpful
3answers
What causes the white milky subtance under oil cap. How do you prevent it?
The milky white substance is water mixing with oil. Oil normally mixes with water in your engine from a blown head gasket, but if your not having any problems with your car I have seen where a little water gets under the oil cap from washing the engine down. Hope this helps.
Rattling noise from my clio engine?
Was the car using much coolant before you forgot to replace the coolant bottle cap?
The clinking noise you describe - that may be 'pinking'.. a noise caused by an incorrect air/fuel mix .. and also a symptom of a blown head gasket. Another symptom of a blown head gasket is white smoke (steam...) from the exhaust.
First, check your engine oil on the dipstick. If the oil is a creamy grey colour this indicates a blown head gasket. The creamy grey colour is caused by coolant finding its way into the oil system.
Fill up your coolant bottle with coolant. Leave the cap off, and start the engine and let it tick over for 10 minutes. As the engine warms up air will escape from the coolant level - keep topping up as necessary.
Keep your eye open for extreme bubbling in the coolant bottle - violent bubbling in the coolant bottle is caused by exhaust gases finding their way into the cooling system via a defective head gasket.
If there's no violent bubbling, replace the coolant bottle cap when the engine has ticked over for a few minutes..
... and then begin to look for leaks as the engine ticks over. Look under the car to see if there's any falling fluid. Check around the radiator and the hoses. Check that the coolant bottle itself isn't leaking.
You say your car isn't overheating - that's a positive. One symptom of a blown head gasket is overheating.
However, your coolant is going somewhere and you should try and find out where ... If it isn't a leak from somewhere, it may well be the head gasket.
Prices? To have a cylinder head gasket fixed costs around £500 - £1000 British pounds. A coolant bottle costs around £30 (look on Ebay)
If the head gasket is leaking/defective you can try a modern sealant/repair, which I am told are now quite good. Have a look on Ebay:
3 229results for cylinder head sealant
Top Land Rover Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Land Rover Expert? Answer questions, earn points and help others
