Question about Intermec CK30
Ck 30 problem
Low memory - what is the cause and how do you fix the problem
  • Stuart Pilkington-Way
    Stuart Pilkington-Way May 11, 2010
    Is this flash storage or actual RAM?
  • 47 Answers
Upgrade your memory
Posted on Mar 17, 2008
What could cause it to hesitate when it gets hot?
DO'NT JUMP THE GUN & START THROWING PARTS IN. DID YOU CK THE FUEL PSI, EMERG. BK STICKING, FREEZING CALIPER? CK THE BKS, SCAN THE ECM, CLOGGED INJECTOR, BAD THERMOSTAT, COOLANT SENSOR, LOW COOLANT ETC. START WITH PC SCAN & EMISSIONS CK.. THE LIST GOES ON. GOOD LUCK
Feb 07, 2016 | 2001 Nissan Frontier XE-V6
What could cause a 2001 nissan frontier to hesitate when it gets hot
Feb 07, 2016 | 2001 Nissan Frontier Crew Cab
Starter turns to slow to start new battery new starter cables good starter gets hot
ck to see if your engine has a compression release to allow it to start , they work by oil pressure on exhaust valve , low at first start and high at end of start cycle , this could be cause of this happening , also diesels need to have at least 12 rpm before they start (turn fuel on) , so starter /battery needs to be spot on for it all to work
Jan 21, 2016 | Diesel Garden
Colling fan stays on while riding
locate and check the temperature sensor, it may be shorted inside causing it to run all the time. also ck. the relay, once it tells it to come on the relay may stick inside. causing it to run all the time.
Jun 21, 2013 | Motorcycles
How to fix a 1994 toyota camry **** transmision or what can be causing it ?
ck fluid level, see if fluid burnt, if low fill, if dirty or burnt replace fluid if this dont help have scanned for any trans codes. if no codes then trans needs ck by a dealer or trans shop.
Aug 14, 2012 | 2004 Toyota Camry
I have 501R model Sub-Zero refrigerator. There is ice formation on inside back panel
ice build up is cused by the falure of the defrost system. . ck the heater and defrost timer . timer is most common . also clean the air coil and ck fan speed up on top. if dirty if could cause longer run times and this also could be causing the problem and the door seals must be in good cond. hope this helps mm
Oct 03, 2010 | Refrigerators
What is a/c pressure on a 1999 kenworth when fully charged with a c 15 cat 550 hp tx KIETH.
low side psi will run about 30 psi, hi side pressure will go as high as 350 psi then the pressure switch will kick the engine fan on then drop psi down to 120-150 psi
Jan 15, 2010 | Q-Logic QLE4060C-CK Network Adapter
I have a Bosch Dsihwasher - model SGS53A. The lower washer rota arm is not turning. I have checked that water outlets are not blocked in the arm - all clear. The up arm turn normally. Steve
arms rotate by water volune and pressure / ck to see if the screen in bottom and the cup sreeen is clean . if not clean it with a stiff nylon brush reinstall and try it again // also ck water level if too low this would cause problem .. float or pressure sw causes low water . or water valve filter screens .. hope this helps let me know .. **** .
Dec 04, 2009 | Washing Machines
Dishes suddenly are coming out cloudy (mineral spots?) even though we use the rinse agent products. can something else cause this?
heater may not be comming on . ck it / low water tempt will cause this / bad dertg will also do this .. ck the washarm holes they must be clear ( open ) .run tap till hot then start dw / ck drain to disposal it should have drain loop to prevent back up / this will smell bad and make dishes cloudy . / hop these will help .. mm
Dec 03, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Neptune water level
ck drain hose level ..end should be 30-36 inches from floor also be sure hose fits loosely in standpipe ..possible water is siphoning out after fill up since these are low water use machines any drop in water level can cause problems
Sep 29, 2008 | Maytag MAH6500 Neptune Front Loading...
Intermec CK30 Logo
133 people viewed this question
Top Intermec Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Tom Chichester
Joseph Wright
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
