I have a plasma tv need help
I have a magnavox 42 inch model # 42mf230a/37 suddenly i have a 6 inch black line running from top to bottom almost in the center of the screen.you can still see the picture on either side of the line but everything behiind the black line is blacked out.. do you know what this is and about how expensive the repair could be
    Sergeant:
  • 261 Answers
Sounds like panel is bad or driver ic is bad on the board directly below the black line. Good luck on the repair. Any questions, we can do a chat and go from there. GURU JAY
Posted on Mar 22, 2008
42" magnavox plasma tv lost
The power supply feed deferent voltages to the TV and the Problem is the electrolytic caps need change out on the power supply module, or you can go to www.partstor.com and get a new one.
Aug 30, 2011 | Televison & Video
My magnavox model# 42mf230a/37 tv turns on I get good sound and picture but it has a 4inc black line onleft side edge of screen
Black lines on Plasma TV are cause by either the buffer boards or the logic board. OR your screen is bad. the only way to find out is the replace the boards. I would start with the Buffer boards. The buffer boards are located on the bottom of the screen attached by ribbon cables to the screen. look at the bar and replace the board that lines up with it. You can find parts fro this TV at www.interliquidparts.com You have to get the actual part number from the part on your TV to get the correct one.
Jun 13, 2011 | Televison & Video
My 42mf230a/37 plasma tv has sound but no picture
Check the power supply, Y and Z sustain boards caps, fuses, burnt parts first.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Dec 23, 2010 | Philips 42MF230A/37 42 in. Plasma HDTV
Magnavox plasma tv model 42mf230a/37 sound but ni
Replace lower scan converter PCB, which plugged into Y-Sustainer Board, located to the left of the display if you poke back cover open. There are 2 of them, but in some models might be the one, long PCB.don't wait to fix it! otherwise, you will knock out Y-
Sustainer and upper scan converter. That will cause you to spend few hundreds to fix it.
Good luck,
Alex's TV Service,
Philadelphia,
Pa, 215-806-5980.
Jan 21, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
42' plasma magnavox model # 42MF230A has no picture and no sound
I had the same problem with an Insignia 42" 1080p. Turn off the tv power and disconnect all cables (i started with power cable, then HD cables then HDMI). Wait 30 seconds with nothing plugged in, then I plugged everything back in (in reverse order) and it works fine.
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Horizontal lines on screen
well if they run all the way up and are on every input through then menu the panel is NG, some panels are around $500 now.
Jul 26, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Magnavox 42MF230A/37 Plasma TV should i fix it? ?
you will need that part to repair yours. i recomend using the heatsinks from yours. u need to check the FETs on the board that drives that one before u power it up, or u could damage the new part.
Dec 05, 2008 | Philips Magnavox 42MF521D/37 Television
Display problem for magnavox 42" model 42mf230a/37
first make sure its not an input problem or from an external source.Disconnect all inputs and see if lines are present with no inputs to tv.if lines affect menu and or ON SCREEN DISPAY (top) there is a good chance (SSB) board could be bad .I would start with this board first ,lvds cable (second) and last the logic board (comes only with new LCD)
Jun 23, 2008 | Televison & Video
Magnavox plasma tv model 42mf230A/37
I guess they are just built to fail. Mine was less than a year old, but they are sending me the exact same unit. Uggghhh
Mar 29, 2008 | Televison & Video
42 inch magnavox #42mf230a/37
One of the driver IC'S has gone bad. Need to replace just the driver IC or the board that the IC is on and that should solve your problem. If that doesn't do it, then the BAD NEWS IS THAT THE PANEL IS BAD. Replacement is you only option then. Good luck. GURU JAY.
Mar 16, 2008 | Televison & Video
Televison & Video Logo
406 people viewed this question
Top Televison & Video Experts
Electro Med Services...
