Question about Crosley Refrigerators
Rewiring Crosley Shelvador
Hi I'm trying to rewire a Crosley Shelvador Electrosaver fridge, it is an old model and not sure how the wiring connects as old wires were cut off and what left is faded. not sure where earth, live and negative go or where they should connect on the fridge. it has a square adaptor that reads "control" on one end and lamp on the other, which connects between the thermostat controller and the light. the cable that is on there is three core, black, green and looks like yellow?? these are two prong connectors.
SOURCE:
  • 11 Answers
SOURCE: PTC relay on compressor
Try to find the "secret" wiring diagram.  Almost all refrigerators have a hidden paper wiring diagram.  It is usually tucked into a slot under the refrig, behind the front grill, or otherwise on the inside of the lower rear cardboard fan cover, or sometimes inside the back area near the fan.  While you're in there, it's a good practice to clean the coils.
Posted on Oct 23, 2007
Crossedwires
  • 44 Answers
SOURCE: how to wire hunter 44155
Go to the hunter web site. They will have the proper wiring diagrams on the site. If you cannot do that pick up a basic wiring book at your local electric parts supplier. the place you got the thermostat would be a good start. I do know that menards has some books in the electric area that would be a great help to you. You also will need to be sure that the thermostat is able to handle both air and heat. many only do heat. If this does not help let me know and I will try and get more information to you
Posted on Feb 09, 2008
  • 1073 Answers
SOURCE: refrigerant pressures
normal 3 lbs on low side
Posted on May 28, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Posted on Oct 12, 2008
  • 102 Answers
SOURCE: rewiring a travel trailer
You need to first decide what all you want inside as far as electrical features such as lights, outlets, fridge, stove , tv etc.. decide their locations then calculate the load it will pull and design the electrical circuits. Sound tough but it's not that bad
Posted on Dec 04, 2008
I have a crosley shelvador fridge. the original power cord melted. i replaced the cord and all the wiring...not operating anymore. i have looked everywhere for the model and serial # but cant find it.
Why did the cord melt has to be a serious electrical issue like a frozen refrigerant pump motor, that means the fridge is done and should be replaced. If you wan to repair it contact a local appliance repair shop that sells used/rebuild fridges and has scraped parts, you may be able to find used parts for it.
Feb 14, 2017 | Crosley Refrigerators
How muc`h is a door handle for a Crosley Shelvador 1952 model?
The one shown in the link below is $20.90. However, you will need your exact model number to be sure it's the right one.
Crosley Refrigerator Handle 218428101
Dec 09, 2014 | Crosley Refrigerators
Rewiring my dynascan model 21 cobra cb
look at where they were connected and solder new wire in.
Mar 02, 2014 | Cobra 29 LTD CB Radio
Rewiring a 50cc roketa scooter
lights and relay wire
Jun 27, 2013 | Motorcycles
I have ordered replacement switch for my 1/2" Makita model #DP4700. Switch #651314-6. I'm confused as to rewiring the switch wires. There are 2 wires in the housing, both back, one appears to connect...
If the part is an exact replacement for what you have, what is the issue. U just replace it in the exact same way that the old switch is wired.
Sep 19, 2017 | Drills
Rewiring 1959 chevy el camino
Are you needing advice, links, tricks, or all of the above?
If it's advice you want:
If you are not buying an after market harness and all of the oem wiring is intact replace one wire at a time from the component all the way back to the fuse box. Its tedious but, it's a sure fire way to get it right the first time.
Secondly, I'd by a haynes manual or some other wiring diagram. Study it for at least a couple weeks or until you are completely comfortable taking on the task.
Color code your wires and label both the old and new ones with paper tape and a permanent marker so that you know what each one is for.
Last but not least, make sure that the battery is disconnected... ;o)
Jun 01, 2009 | 1982 Chevrolet El Camino
Rewiring a travel trailer
Sep 25, 2008 | Electronics - Others
WIRING
why did the wiring burn?Id have the heat exchanger inspected before rewiring.better to be safe.
Sep 17, 2008 | Intertherm P3RA-048K Air Conditioner
Rewiring an old pioneer stereo.the radio was installed where it powers without the ignition being on.the battery was draining. figured it had to be the radio. pulled radio. the red power(acc wire) was...
hello...if you are sure that the red wire is acc it should be connected to the acc connection of the ignitionkey.or maybe the lighter positive...and the other to the battery"always 13.8 v"...then the memory will function properly of the radio and you will not drain your battery...please tell me what happens...good luck ...Ron
Mar 07, 2008 | Audio Players & Recorders
Refrigerators Logo
148 people viewed this question
Top Crosley Refrigerators Experts
Colin Stickland
Colin Stickland
John Tripp
John Tripp
Marvin
Marvin
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
