The handle is the problem. cannot seem to remove it. The refer is a kenmore model no. 25368842791. The doors now open from left to right and we need them to open from right to left. But, need some guidance on removing the handles on both the refer and the freezer.
Thank you
SOURCE: door handle loose on 10656542400 kenmore
hi there is a small cap at each end of the door . pry off with a small screw driver and tighten the screws thanks the appliance doc
SOURCE: Removing refrigerator door handles
You might try checking to see if the screw head is actually on the handle, but hidden by the handles cover. Look at the side and see if you notice a seam. This can be pried open and the screw head will be seen.
SOURCE: On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
SOURCE: Bottom Freezer door handle
I had the same problem. It took me an hour to figure out that the bottom freezer handles clips onto the door using butterfly clips. To tighten the clips you have to remove the handle by sliding it to the right (or left??) It snaps right out with a quick **** exposing the clips underneath. A quick tightening of the clips and the handle snaps back in.
