Question about HP LaserJet 2420 Printer
HP 2420dn out of paper
Recently when the printer runs out of paper and it is reloaded it will not remove the out of paper message. It will not print manually or other wise. Nothing seems to be physically wrong with the printer. Any ideas?
    New Friend:
  • 159 Answers
To perform a cold reset
1. Turn the printer off.
2. Hold down the SELECT ( ) button, and then turn the printer on. Continue holding down
the SELECT ( ) button until all three printer control-panel lights flash once and then
remain on. This might take up to 10 seconds.
3. After the message SELECT LANGUAGE appears on the display, press the
UP ARROW ( ) button or the DOWN ARROW ( ) button until COLD RESET is highlighted.
4. Press the SELECT ( ) button. The printer performs a cold reset and then continues its
power-on sequence.
5. Check all I/O settings and reset any customer-set printer configuration values.
ENWW Printer resets and power-on modes 163
Posted on Mar 16, 2008
  • Hashem Nashash
    Hashem Nashash Mar 16, 2008
    To initialize NVRAM
    1. Remove any installed accessories (for example, a stapler/stacker).
    2. Turn the printer off.
    3. Hold down the DOWN ARROW ( ) button, and then turn the printer on. Continue holding
    down the DOWN ARROW ( ) button until all three printer control-panel lights flash once and
    then remain on. This might take up to 10 seconds.
    4. Press the UP ARROW ( ) button.
    5. Press the PAUSE/RESUME button. The display should show SKIP DISK LOAD.
    6. Press the UP ARROW ( ) button until NVRAM INIT is highlighted.
    7. Press the SELECT ( ) button. The printer initializes NVRAM and then continues its poweron
    sequence.
    Hard-disk initialization
    CAUTION A hard-disk initialization erases and reformats the printer hard disk. Perform a hard-disk
    initialization only if an error code on the control panel indicates an EIO disk error. Always try
    initializing the hard disk before replacing it.
    NOTE Before performing a hard-disk initialization, print a menu map and a configuration page (see
    Menu map and Configuration page). Use the information on the configuration page to reset
    any customer-set printer configuration values that the hard-disk initialization procedure
    changes.
    To initialize the hard disk
    2. Hold down the PAUSE/RESUME button, and then turn the printer on. Continue holding down
    the PAUSE/RESUME button until all three printer control-panel lights flash once and then
    3. Press the BACK ARROW ( ) button. The display should show INITIALIZE DISK.
    4. Press the SELECT ( ) button. The printer initializes the hard disk and continues its power
Duplex printing in HP 2420dn on Mac OS X Lion 10.7.4
According to the specs, this printer does not have a duplex unit and therefore cannot print double sided prints.
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 17, 2012 | HP LaserJet 2420 Printer
Hi. Whenever I try to print the printer HP 2420dn rolls out a warm sheet of paper with no ink on it. Any ideas?
Probably you have problem with cartridge. Try to remove it and then put it back. If you have another cartridge try it. If this not helps you, then you have problem s with your printer
pifonski
Feb 19, 2011 | HP LaserJet 2420 Printer
Tell me please hp laserjet printer 2420 paper tray setting
    1. Remove the packing material from the printer.
      1. Remove the all orange tape from the outside of the printer.
    1. Load all paper trays.
      1. Pull the paper trays completely out of the printer.
    2. Press the blue tab on the rear paper length guide and adjust the rear guide so that the pointer matches the size of the paper to be loaded. c00318778.gif
    3. Move the side width guides outward to match the desired paper size. c00318779.gif
    4. Add the media to the paper trays, make sure that it is flat in the tray at all four corners. Keep the media below the height tabs on the sides and rear of the tray. Push down on the metal lift plate to lock it in place. c00318780.gif
    6. Install the print cartridge.
      1. Remove the print cartridge from the packaging.
    7. Rock the print cartridge back and forth several times to "mix" the toner. c00318783.gif
    8. Pull the sealing tape from the end of the print cartridge to remove the entire length of the tape. c00318784.gif
    12. Connect the LAN cable (optional). (HP LaserJet 2420n, 2420dn, 2430tn, and 2430dtn models only) c00318788.gif
    Jan 13, 2011 | HP LaserJet 2420 Printer
    Paper sensor faulty - printer doesn't recognise when paper is loaded
    Cannot print from the glass top. The top load area keeps running and then the message says to reload the original. Push OK and go in circles. Maybe the paper sensor is missing?
    May 15, 2010 | HP Officejet Pro L7680 All-In-One Printer
    Does not print, get error message
    unplug, wait a minute, replug in. try it
    check cartridges and rollers to insure nothing is blocking the printing formation.
    is there too much paper in the tray?
    hp has an awesome trouble shooting web site as a last choice.
    Apr 29, 2010 | HP LaserJet 2420dn Printer
    Intermittent problem with my 2420dn not printing from tray 2
    Chances are you could have a formatter Board Problem the eprom on this board.
    Yup common problem, here's what I would do, I would reload the drivers one more time if this doesn't resolve the issue then possible problem witht the formatter, the formatter is what communicates with your computer and the printer at the same time.and it also converts the cumputer language to anaolg so your printer can process your printing requests.
    Jul 24, 2009 | Office Equipment & Supplies
    Weird toner issues
    Hi Kelli.i would replace the drum unitand toner!
    Mar 31, 2008 | HP LaserJet 2420dn Printer
    HP 2420dn printing gray and shadows
    maybe the scan unit need to clean first you most sure that the toner cartridge is original and new then start clean th scan unit reflector d9b88f3.jpg
    Mar 12, 2008 | HP LaserJet 2420dn Printer
    HP LaserJet 2420 Printer Logo
    177 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
