DVD holder tray in CPU unit.
DVD tray holder in CPU unit keeps going in and out with or without a disc inside after being powered on. Please advise.
  • 88 Answers
This could be due to a sticky eject button on the front of the drive or a damaged PCB inside it. If it's the latter the only way around it is to replace the drive.
Posted on Mar 14, 2008
SOURCE:
When I turn on my Sony DVP-SR200P DVD player and press the eject button it's turns the DVD player off.
turn on first the dvd player and wait to read a disc inside if no disc inside the tray it will say disc error. if the unit doesn't turn off, eject now the the cd tray. if get turn off, remove the cover then check for an stuck up gear or obstruction in the cd tray assembly. you can check also the power supply board which may have unusual parts like bulged or burnt component parts.
Oct 06, 2012 | Televison & Video
Tray keeps moving
Check inside the tray to make sure no obstacles are preventing the tray from opening fully.Also try a good cleaning disc; dust may be inside the unit.Check and make sure that the button on the front of the panel is not jammed or moved slightly, and is using a full range of movement. Push the putton, and see if it moves solidly. Lastly each manufacturer has Firmware upgrades for the controller chip that runs the tray.You can go to the website of the Manufacturer of the unit, and type in the Model number and make sure that your Firmware does not have an update.
Jan 19, 2010 | Televison & Video
DVD disc tray will not open
Without knowing the model for the unit, it makes it a little difficult to troubleshoot, but usually the easiest way to get one of these to open up is to try resetting them. This is done on MOST DVD players by unplugging them for about 30 seconds while you hold the power button down to discharge any power that might be held in the unit, then plugging the unit back in and trying to eject it again. Keep in mind, that if the unit was moved (or even if something caused the unit to shift, like a person jumping near it) then the problem could be the dvd has become dislodged from the tray. Many dvd players will have a small hole on the front (usually below the tray) where if you insert a paper clip in about a half inch, will eject the tray part way, and then you can gently pull it out the rest of the way (making sure you do not keep pulling if you feel resistence as the dvd might have skipped out of the tray track). IF worse comes to worse and you don't have a warrenty on the unit, many dvd players can be opened by removing 1-2 screws from the left and right sides, and possibly 1-4 screws from the back of the unit (look around the edges, the screws near the ports on the back usually holds those ports in place and do not need to be removed to take the case off). Once the screws are removed you would pull back and up on the case to open the dvd player. Keep in mind, this voids a MFG warranty. Once the case is off you should be able to see the dvd and remove it unless you have a cheap dvd player which has an enclosed drive. Remove the dvd and with the case still off, plug the power in (DO NOT TOUCH ANYTHING INSIDE WHILE THE POWER IS PLUGGED IN) and try hitting the eject button on the front. IF it ejects now, you should be good to go, just put the case back on. IF it doesn't eject, then your motor is probably bad (or something is blocking the track) and it is usually safer/easier at this point to just go buy a new dvd drive.
Jul 31, 2009 | Toshiba DVR3 DVD Recorder/VCR
The tray to my DVD player would not open. It says
Hi there! First of all, what is the brand name of the DVD Player? Don't know what advise you got but here are a few suggestions. The most common would be the little black rubber belt may have snapped or is worn out. This will result in total mechanical failure. The tray opens and closes and the the mech inside also needs to lift to bring the eye to the disc to start reading. If this motion inside does not occur when the tray is closed it can say " bad disc" or "blocked".It may also be a processing fault which in most cases will not be economical to repair. My advise is to first check the belt. Depending on the value of your machine it may be worth referring to a repairer. Regards and good luck, JUS004.
Jun 09, 2009 | Cyberhome CH-DVR1500 DVD Recorder
TT320 DOESN'T WORK
SIMPLE....THE TRUTECH WENT IN THE TRASH AND I BOUGHT A NEW DVD PLAYER.....END OF STORY!
Jul 07, 2008 | TruTech TT320
Have a phillips DVDR model#3455H.Inserted dvdrw disc recorded with videos recorded on it in my computer. Disc works fine in my pioneer dvdr but when I put it in the phillips it will not load and it will...
The electronic procedure:
Switch off the unit at the wall plug. On the front panel, hold in the <RECORD> and <EJECT> buttons at the same time, and keeping them held, switch on the power at the wall again. Keep holding the buttons until the disc tray opens.
Apr 03, 2008 | Televison & Video
Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
Mar 09, 2008 | Panasonic DMR-HS2 DVD Recorder
Disk holder will not open when open/close button pushed
a switch outside or inside is broken, dirty, or somewhat that get inside a switch.
Jan 13, 2008 | Emerson EWD2203 DVD Player/VCR
Sanyo 6100 dvd player-disc tray automatically opens whenever power is on.
you should try inspecting & servicing the tray transport mech first and then the tray sense swt.
Dec 08, 2006 | Sanyo DVW-6100 DVD Player/VCR
Open Questions:
Computers & Internet Logo
32 people viewed this question
Ekse
Alun Cox
