Question about Dishwashers
Dishlex DX302 : Water not heating
Our machine is not heating the water. I have confirmed that the heater unit has a internal resistance of 26ohms and is getting 240v on the active side. However it is only getting 85v across it's active and neutral that goes back to the control board. I am guessing that the control board needs replacing as the resistance from G5 to G6 is only 2Kohms instead of the 6Kohms as mentioned in your previous post.
I was hoping to get a copy of the wiring diagram to confirm, before having to purchase a new control board.
  • 8 more comments
  • fixyafan Mar 21, 2008
    Hi
    Thanks for the advice, in the intrim I had replaced the control board which fixed the problem.
    However I would still like a copy of the service manual for the next time. My e-mail address is
    lifeco@unwired.com.au
    Thanks again
  • pmeacock Jun 27, 2008
    Water not heating properly as well. Would you please send a copy of a wiring diagram as well to pmeacock@e-wire.net.au
    Much Appreciated
  • toddy2731 Aug 31, 2008
    Hi I have the same problem too. Can someone please send me manual also to st.bartlett@bigpond.com Thanks in advance. Tony
  • homer21 Aug 31, 2008
    Hi I also have no hot water and 26 ohms on the heating element and think maybe that I should replace the circuit board
  • laubstar Oct 28, 2008
    hi, i have the same problem and was wondering if i could get a copy of the circuit diagram.
    laubstar@hotmail.com
  • wayno357 Mar 13, 2009
    Yep, same problem. No heat. I put washing dishes way up there with watching grass grow so I'm pretty keen to fix this problem.
    Could you send me the Service manual and circuit diagram for the Electrolux DX302.
    wayneandboo@yahoo.com.au
    Thanks
  • bte19280 Apr 20, 2009
    I have no hot water, I checked the resistance of heater element 26 ohms. Could I possibly get the manual emailed, bte19280@bigpond.net.au thanks for your help !!
  • Annom5000 Mar 27, 2012
    Hi there, I'm not sure if this post is still active, but I am having the cat same problem. From reading previous posts I suspect same solder problem on circuit board! I was wondering if you could please me the service manual and wiring diagram so I can have a look and try fix it? Model is a white Electrolux dishlex dx302 as others.. Email address is jimmigazza@hotmail.com thanks so much!
  • nick Oct 14, 2012
    Hi FixyaI also have the same issue heating /drying not working on Electolus DX302, I have attempted to remove the controll board and have not been able to get the board out of the casing once it was opened up, so do not know if it is just the dry solder joint or not .Is it worth buying a replacement controll board ,,,is this possible,thanks for the threads and help.
  • wgibbons570
    wgibbons570 Jan 07, 2013
    email cct to w@gibbo.net.au please
  • 49 Answers
It sounds like the control board is faulty. have you checked for dry solder joints on the control board? also it is important the check the resistance of the taco on the wash motor. last of all don't worry to much about the 2k ohms of the temp sensor as it can vary lots depending on the temperature.
if you give me ur email i can send you the service manual and wiring diagram.
Posted on Mar 18, 2008
  • 3 Answers
Hi
mine had this exact same problem - it turns out that the relay on the control board had not been soldered on properly. mine has shorted out over time, and caused a lot of charing of the localised area. i checked the relay, it was okay, so have resoldered the board and all is working for now.
i called Electrolux - 1800 001 218 - to report the problem, as i believe there are too many peoplew reporting this issue for it to be a one off. i was also concerned about a fire risk, as the charing on mine was considerable.
too be blunt, Electrolux didn't seem to care too much, unless if i wanted to pay to have someone come look at it, despite the fact that i am an electrician.
Electrolux currently say that this is the first time this problem has been reported - despite that fact they are aware of this thread. i would encourage anyone whoi has this fault to call the above number and report your problems to them, as i believe a recall may be waranted, and, should your unit have serious problems (fire) it is on record.
Electrolux currently have a recall on a couple of other dishwashers due to the fact they pose potential fire risks - see www.recalls.gov.au
Posted on Nov 06, 2008
  • nospam570 Oct 17, 2010
    Dishlex 302
    Usual problem - not heating / drying.
    Check back of computer board. A solder seems to have burnt out / off. Resoldered and now working again. It's a worry that the first one melted or burnt off though.
    Something wrong with this setup.
    Cheers,
    A.
  • Jim Hanigan May 24, 2013
    Here's hoping that this post is still active as my DX302 has developed a non-heating problem abd I would appreciate a manual and wiring diagram too please. seamus.43@gmail.com
I have had a similar problem and yes, the problem is the load side connection between the power relay and the circuit board. I have resoldered it and laid over that part of the board circuit, heavier wire to reduce local heating. Unfortunately, the problem arises again from time to time.
It's just a very poor piece of electrical design !
I believe the only permanent solution is to insert a secondary relay between the circuit board and the heater feeder wire in order to reduce the current (and hence potential to overheat that section of the circuit board. I am considering fitting a relay with a 240 volt ac coil but to simplify wiring but need to get a wiring diagram in order to arrange the neutral side connection for the pull in coil.
A circuit diagram would be VERY helpful.
Posted on Jun 28, 2013
DISHLEX DX302 REPLACE HEATING ELEMENT
Remove the device and then restart again
Jan 25, 2014 | Dishwashers
My bocsh 830es water heater will be running normal then will kick into a A3 mode no more hot water
Check for a green wire near the top right of your machine. It would loop back to itself with a little black heat shrink on it. This should be far away from the heat exchanger. if its near it, I would recommend pulling it out of the wire clips, and relocating it to behind the control unit on the right side of the machine. Keep it away from heat....its a resistor, and will pop random A3 codes if the heat increases its resistance. Reset your code and you'll be good to go.
Jan 01, 2014 | Bosch Therm 830 ES NG Internal Tankless...
Hello - I have an Electrolux Dishlex DX302 dishwasher. The washer works okay - but it doesn't always empty the contents of the dishwashing powder in to the dishwasher. It is often wet and stuck in the
If you have hard water, you should reduce the amount of detergent you use. Here's a map showing water hardness in the USA. http://www.citriclean.net/why-citriclean/
Nov 23, 2013 | Dishwashers
I have a Electrolux Dishlex DX302 and the last few washes I have notice that on the ususal cycle it is not heating (steaming) at the end. The dishes are still coming out half clean. I am not sure why the...
Doubble check the settings on your machine.
It is a long way from my heater to the washer. Hot water is essential to the operation of any model machine. I always get hot water to the sink (by running the hot water, of course) before I start the washer. I can tell when I fail to do this.
Just a thought, I hope this aids your situation.
Of course your washer heater may have failed ... You can check it using a volt/ohm meter.
Thanks for your question this morning @ FixYa.com
Jul 12, 2011 | Electrolux Dishwashers
Dishlex dx302 - not heating water
If it is the old model about 15 years old (i own one myself) it is the water inlet it may be leaking.
I had the same troubles and i installed a new pipe on the dishwasher and now it heats fine. All you need to do is get a new pipe (you can get them from the dump) off of an old dishwasher and put it on yours but make sure it doesnt leak first.
If you have more questions please dont hesitate to ask im more than happy to help
Jacob McNamara
Aug 10, 2008 | Dishwashers
Vulcan dishlex 750 eco taking alot longer to complete wash cycle.
How is the water flow into the machine. Are all your inline filters clean?
Apr 05, 2017 | Dishwashers
Water not getting hot
there is no thermostat but there is a temp sensor (ntc probe). if you check the Resistance between terminal g5 and g6 you should get 6.03 k ohm at 20 degrese Celsius.
it sounds to me like the control board needs replacing.
i can send you a wiring diagram and full diagnostics in pdf format if you give me an email address
Feb 20, 2008 | Dishwashers
Dishlex dx 302 heat drying
Found I had no hot water in my Dishlex DX302 and did a google search and found this page.
My problem was found to be the same as the others; one of the solder joints on the relay on the control board had arced off.
You could see the burn mark on the board and cover where it had been arcing.
Soldered it back together, and now it seems to be going good again.
Now my only problem is a damaged door seal, which means a small water leak; I have used part of a rubber glove to bridge the gap, and it reduces the water leak.
Sep 22, 2007 | Dishwashers
Dishwashers Logo
3,662 people viewed this question
Top Dishwashers Experts
