FixYa.com
Tags:
Ricoh Aficio CL7000 Laser Printer
Ricoh cl 7000
posted by jdover64 on Mar 14, 2008
Can this machine be used as a standalone printer ( connect a cat 5 cable from laptop to ricoh ethernet port or does it require a router for use?) I have tried this approach but my laptop cannot see the copier
Comment by jdover64, posted on Mar 14, 2008
Many Thanks That solved the problem immediately!!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
Benimur
Rank:Guru Guru
Rating: 87%, 2197 votes
To my understanding since this model is a print server by itself, should you want to connect it straight to a laptop and not through a hub or router, perhaps you can try using a cross-over cat5 networking cable instead of the regular straight through.
Additionally, the IP adds of the printer and laptop should be near (192.168.15.16/printer and 192.168.15.xx/laptop).
Alternately, the printer will allow also connections by parallel, USB and bluetooth.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Comment by Benimur, posted on Mar 15, 2008
Glad to be of assistance and appreciate the rating too.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Printers problems?
Fuser oil unit
My printer says replace fuser... Answer This...
network printer installation...
i am facing problem in vista... Answer This...
Ricoh CL7000 Duplex Problem
Hi, I am having prolems with... Answer This...
Ricoh Aficio CL5000 Laser...
Ricoh Aficio CL5000 Laser... Answer This...
Wrong drivers
I used to be able to print... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
