Question about Whirlpool LHW0050PQ Front Load Washer
Locked washer door
Door on my washer ( LHW0050PQ) won't unlock.
    Sergeant:
  • 351 Answers
Try hitting it where the lock is but you may have to replace the lock.
Posted on Mar 21, 2008
There is a 2 min delay before the door will unlock when you go to stop ??
Posted on May 14, 2008
SOURCE:
Door won't unlock and the washer will not start to fill.
Check and see if the door is jammed or there is fault in the lock.
Click this link for tips to reset the lock: Door lock
Check the continuity of the door switch and see if the harness connects to the control board to trigger the start cycle when the door is closed.
Jan 21, 2013 | Maytag MHWE200XW Washer
My Electrolux "Kelly Ripa" washer just completed a load, but did not unlock the door. How can I get the door open? The manual was no help.
check inside your pump filter first see if there is anything in there....this might be causeing your door to stay locked
May 08, 2010 | Whirlpool LHW0050PQ Front Load Washer
I have a whi lhw0050pq washer and it wont work
Yes, the door latch actuates a switch that tells it that the door is closed. until that is fixed, the unit will not run. Hope this helps!
Dec 11, 2009 | Whirlpool Washing Machines
Locked Door
I got so made that i just ripped it open by pulling on the flimsy handle and it actually bent the spring thats under the decorative round door cover just enough that it now works perfect. The door cover feel off and i did break the underside of the handle but i was a ble to snap everything back on. The handle cover went back on too.
Dec 16, 2008 | Whirlpool LHW0050PQ Front Load Washer
Door lock - controller
Control board sends power to door lock and unlock door. Control Board is most likely the problem. Have you tried unplugging machine for 5 minutes and then plugging back in?
Sep 23, 2017 | Whirlpool LHW0050PQ Front Load Washer
Hotpoint WML520P
you should not have to press anything to open the door,it should unlock on its own..it may take up 5mins for the lock to disengage after stop.do not force,if it does not open call for service..good luck
Sep 24, 2008 | Whirlpool LHW0050PQ Front Load Washer
DOOR IS LOCKED
remove bottom panel reach up to lock area pull down on small tab
Jul 12, 2008 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
296 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
