Question about Rockford Fosgate Punch 801S Car Audio Amplifier
ONE CHANNEL NOT WORKING
I HAVE THE ROCKFORD 801S IM ONLY POWERING 1 IO" SUB WITH IT BUT IT DOSENT SEEM LIKE IT IS GETTING ENOUGH POWER I HAVE IT HOOKED UP TO THE LEFT CHANNEL AND IT THUMPS A LITTLE THEN I HOOK IT UP TO THE RIGHT CHANNEL AND ITIS EVEN LESS THE GAIN IS VERY HARD TO ADJUST THAT MAY BE THE PROBLEM BUT WHAT ELSE COULD IT BE THE RIGHT CHANNEL HARDLY PUTS OUT ANY POWER I SENT IT BACK TO ROCKFORD TO HAVE IT FIXED THEY SENT IT BACK TO ME AND SAID THERES NOTHING WRONG WITH IT BUT THE SAME THING IS HAPPENING I USED TO HAVE IT POWERING TWO TWELVES BUT ONLYONE WORKED NOW I WANT TO BRIDGE IT FOR THE ONE 10 SOME ONE HELP
    Sergeant:
  • 300 Answers
Please don't take offense, but some tips on submitting problems on Fixya:
  • Resist the urge to use all capital letters. Reserve them for frustrating yells :).
  • Use a period or two. It's very hard to read without them.
The easier to read, the better responses you'll get!
Anyway, back to the issue at hand.....
Definitely get a handle on the gain adjustment. Both channels should start with a gain at the 50% point. Also, you can try bridging the amp ("+" speaker outputs tied together, "-" speaker outputs tied together) and run the full 800W into the single 10" sub, but that is going to depend on what your sub is rated to handle.
The only other thing I can recommend is call around to a couple stereo shops and see if anyone can test the amp for output power. That'll verify whether there's really a problem on the one channel.
Posted on Mar 14, 2008
Hi, I was trying to replace my subs and during the process, the positive wire touched the negative wire and my amp turned off. I have the Punch 801s 2400 watt amp. Is there a way to reset it? I'm assuming...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping. A thumbs up would be greatly appreciated if this answer is helpful to you. GOD BLESS YOU.
Oct 17, 2013 | Rockford Fosgate Punch 801S Car Audio...
Why do i need to open my gain up to 3/4 to full turn inoder to achieve a loud bass?Im using punch 2400 amp and 2 12" kicker.
the amp may not be powerful or your setting on the cd player is not right try adjusting the cd player. turning the gain all the way up will damage your subs even go above halfway
Sep 19, 2010 | Rockford Fosgate Punch 801S Car Audio...
On the 801s there are 2 power holes and two ground wire holes why...
basically it is so you can get better power and ground connections.
Oct 20, 2009 | Rockford Fosgate Punch 801S Car Audio...
Will my car handle a rockford fosgat 801s power load?
Hello dreww1005,
If your alternator and battery are in good condition, you probably don't need a capacitor. At maximum output, the 801S will need to draw a little over 30 amps at 12.8V. The specifications call for 8-gauge power and ground wiring and a 40A primary fuse. The Vibe's electrical system should be able to handle it OK.
Hope this helps.
May 08, 2009 | Rockford Fosgate Punch 801S Car Audio...
Amp or something cutting out.
Power caps store power from the battery and they feed constant power to the amp so you dont get no drainage! this could be one reason..
have you bridged both subs and wat gauge wire are you using.
these amps can only handle one bridged sub at 4ohms and this amp is recommended that u use 8gauge or higher. if your running to subs i normally reccomend using 4 gauge power wire as you get more rms power feed to the amp
you can get a power cap or anyother accersory cheap online at my suppliers.. caraudiosecurity << click to enter >> hope this helps and please rate me :)
Apr 22, 2009 | Rockford Fosgate Punch 401S Car Audio...
Is it enough to power to 12 volge=ahagen 12oowatss dual 4 ohms
your Volfenhag 12" subs are rated at 1200 watts they are only 600 watts rms and the Rockford punch p4004 is only 200 watts rms so the answer is yes it will work but if you get a amplifier that pushes out 500 - 600 watts rms you will love the sound from subs
there is nothing wrong with the Rockford amp it just wont pound out the bass as hard but the good news is you will never blow the subs with it
when buying amps or subs make sure to look at rms rating that is the true power they actually have ie. (sub box says 1200 watt you think powerful but if you divide it in 1/2 you actually get 600 watts rms) don't get me wrong that's a nice rating. for a sub but you will want to match that number with the amps rms rating or lower. The RMS is what makes the car pound the higher the RMS the better
hope this helps
Mar 05, 2009 | Rockford Fosgate Punch P4004 Car Audio...
I have a rockford fosgate p250.2 amp hooked up to two 12' subs but the amp is not powering on... instead the protect light is on and im not sure if its because its so cold outside... please help and thank...
Remove the load from the amplifier (subs) and the RCAs
Retry.
If the light stays on, there are internal problems with the amplifier, and it needs to be serviced.
If the amplifier works normally, attach the RCA's and power on again.
If it remains on, connect one sub, and then the other.
Your amplifier is a 2 channel amplifier rated at
60 Watt - 4 Ohm - 2 channel(s)
125 Watt - 2 Ohm - 2 channel(s)
250 Watt - 4 Ohm - 1 channel(s)
Your amplifier is not rated for a 2 ohm mono load.
If you have Single voicecoil subs wired in parallel, you have a 2 ohm mono load - your amplifier will eventually fail.
Jan 16, 2009 | Rockford Fosgate Punch P2502 Car Audio...
Will not power
are u sure you didn't blow a fuse? check the fuses to make sure you did not blow one because the amp will not work in that case. make sure you are not over working your amp as well because it seems like that amp is not big enough to power all four of those subs. usually 4 channel amps are used to power speakers not subs. what is the rms on your subs and amp? i could better tell whether your amp is big enough. thanks hoped this helped
Jun 24, 2008 | Rockford Fosgate Punch 301S Car Audio...
Rockford 750X
sorry bath you mous change the amplifayer integration
Jul 21, 2007 | Rockford Fosgate Power 750X Car Audio...
Rockford Fosgate Punch 801S Car Audio Amplifier Logo
174 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
