Question about Epson RX620 All-In-One InkJet Photo Printer
Printer problem I have a problem with Epson RX620 telling my I have Scanner problem and to see documentation, where do I find documentation? Mario Thumudo thumudom@comcast.net
  • 1 more comment
  • spookyloopy May 22, 2008
    scanner error occurred please see documention
  • Gordon Walz Aug 18, 2008
    Epson scanner RX620 suddenly gives a loud shriek when powering up and will NOT SCAN atho it will print text. No real error message on the LCD screen either. I have restarted computer and have same problem. Problem first appeaed when scanning slides.
    Ideas anyone?
    Regards.
    gordon........ g.walz@sasktel.net
  • almetrik Aug 31, 2008
    Although I haven't scanned anything into my Epson RX620 for a month I now get a message on the printer display that says that a scanner error occurred and to see the documentation (which was no help). Also there is an occasional one second long grinding noise, so I keep it turned off.
Thanks for the info. I found a site that I was able to download the manual. There wasn't any information in the manual that cured the problem. The problem went away on its own. I did reinstall the printer, so maybe it won't happen again. Thanks again. Marty1932
Posted on Apr 09, 2008
Hi, If you haven't got the service and manual document for the printer go to www.epson.com and download the document from that website.
From your discription of your problem, it sounds as though all of your software isn't installed properly.Try re-installing your software again from disc.
Posted on Apr 07, 2008
My epson stylus photo rx620 has a scanner erro and is not printing
Generally, the 1st best troubleshooting step is to uninstall the printer drivers, unplug the usb cable then download and install the latest driver from the manufacturer's web site, then re-connect the printer when prompted to in the installation of the new driver.
Sep 26, 2011 | Epson Stylus Photo RX620 All-In-One InkJet...
Ink out. Press the OK button to replace the cartridge. So I do and I get, Open the scanner unit, replace the appropriate ink cartridges and Close the scanner unit. This after I filled the ink cartridges.
Here are a couple of sites that will help you replace your cartridges.
Documents & Manuals
http://files.support.epson.com/htmldocs/rx620_/rx620_rf/index.htm
Replacing Ink Cartridge
http://files.support.epson.com/htmldocs/rx620_/rx620_rf/ink_4.htm
Precautions on Ink Cartridge Replacement http://files.support.epson.com/htmldocs/rx620_/rx620_rf/ink_3.htm
Hope this is of some help. Bud
Mar 30, 2010 | Epson RX620 All-In-One InkJet Photo...
Scanner error occurred please see documentation
turn the printer off, lift the scanner, make sure the transportation lock is in the unlock position, if it is in the lock position, toggle it to the unlock
Feb 11, 2010 | Epson Stylus Photo RX620 All-In-One InkJet...
My scanner :makes a loud noise when trying to scan or copy
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I need more information to offer a definitive solution, but I can give you some information that might help diagnose the problem.
Unless you forgot and tried to use it locked…then unlocked it after, it seems unlikely that changing the ink could directly affect anything related to the scanner. So especially if it still scans and now just makes more noise then before, we can reasonably say it isn’t a faulty locking mechanism and that the gears are probably not stripped, which would either stop it or not. So you’re looking at either something simple like the gear assembly being dry, shifted slightly, etc. or the safety by the lock that makes noise to tell you the device is locked is stuck somehow. The one can be tested by removing the little plastic safety that makes the noise when the scanner is turned on and locked; the other you might be able to test with some WD40 and see if it runs quieter.
Aug 24, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
ERROR Scanner error occurred. please see documentation
Hi
Open the glass cover on top of printer, check a switch for lock and unlock on left or right hand side of the printer. toggle it to unlock position, turn it back on and check if there are errors still.
Keep me posted.
Nov 14, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
Epson Rx620
The user's manual said: "Turn this product off, and then back on. Then make sure the transportation lock is released. If the error message still appears, contact your dealer."
If you open the lid, there is a transporation lock on the lower left. Make sure you unlock it before you turn on the machine.
Hope this helps.
Jun 17, 2008 | Epson RX620 All-In-One InkJet Photo...
Scanner error
look for the trans lock its located on the lower left corner of the scanner glass make sure it is on the unlock position
Jan 29, 2008 | Epson Stylus Photo® RX620 InkJet Printer
Epson RX620 All-In-One InkJet Photo Printer Logo
100 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
