Question about Canon MP970 Photo All-In-One InkJet Printer
Programming codes for Canon MP970
I need to give printer directions from within my software. How do I obtain the codes to select printer tray etc.
Hi
I think you need to enter to the service mode
to enable the CD Printer Tray ????
Or what do you mean ????
Let me know...
Posted on Sep 02, 2008
SOURCE:
I con not use my printer Canon MP970. There is 5100 error. I have no idea how to fix it and why it happens.
hi,
please browse the following
www.printerproblemsolved.co.uk/I have problems with paper feed and cannot seems to be able to sort it out, I would like to open .... my printer come up with a error code 5100 canon mp970 .
May 28, 2011 | Canon MP970 Photo All-In-One InkJet...
Error 6A00 on the Canon Pixma MP970
Hello and Welcome
The 6A00 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,I usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon Pixma MP970 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
I forget myself so here goes, the purge unit,called a spittoon assembly in an HP,lexmark & other ink jet printers,is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.That is why you 'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow
I hope it will be surely helpful for you. If you want to get support on Call then Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
Please rate my solution as Four Thumbs given below to this solution if it was helpful.
Thank you for using FixYa
Mar 12, 2011 | Canon PIXMA MP970 InkJet Printer
How i put the cd tray in the printer
install the software for the canon solution menu and it nearly gives you pictures of what to do. In a nut shell use the cd label print from the canon solution menu and when you hit print it prompts you what to do. Put the cd on the black tray hiden under the front of the printer. Open the front grey trap door. Reach in and pull down a the black inner tray. There is a small curved half circle cutout for your finger to pull this down. Don't be scared to pull it down it won't break. Place the cd holder with the arrow pointing into the printer and advance it up to the point equal with the arrow on the black tray bit that you just pulled down. Fire off the print button and and the machine autochecks the position and does the rest for you.
Oct 13, 2009 | Canon MP970 Photo All-In-One InkJet...
How do I switch to the bottom paper tray, my top tray is feeding the paper through crooked, and I can't get my project printed
Look for a button that says "feed switch" each press changes from one tray to the other. usually a LED shows which one is selected.
Aug 12, 2009 | Canon MP970 Photo All-In-One InkJet...
MP970 won't take paper from rear tray
Replace the printer is the best suggestion unless this is a very high end unit.
May 19, 2017 | Canon MP970 Photo All-In-One InkJet...
No usb cord in box
this is straight from canon.com
dot.gif PIXMA MP970 All-In-One Printer dot.gif Power Cord dot.gif Print Head dot.gif Ink Tanks:
PGI-5 Black
CLI-8 (Black/Cyan/Magenta/Yellow/Photo Cyan/Photo Magenta) dot.gif Document Kit: Cross Sell Sheet
Easy Setup Instructions
Network Setup Guide
Quick Start Guide
Setup Software & User's Guide CD-ROM so it looks like you'll have to purchase a usb cord.
Mark
Apr 30, 2009 | Canon MP970 Photo All-In-One InkJet...
NEED PRINTABLE PDF FILE OF REPAIR MANUAL FOR CANON MP970
Here you go:
http://www.tradebit.com/filedetail.php/4981055-canon-pixma-mp970-printer-service-manual
Jan 27, 2009 | Canon MP970 Photo All-In-One InkJet...
Canon MP970 Photo All-In-One InkJet Printer Logo
116 people viewed this question
Clive
Clive
old marine
old marine
Ekse
